[petsc-users] Fwd: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Fande Kong fdkong.jd at gmail.com
Thu Jan 30 14:49:47 CST 2020
Hi All,
It looks like a bug for me.
PETSc was still trying to detect lgrind even we set "--with-lgrind=0". The
configuration log is attached. Any way to disable lgrind detection.
Fande
---------- Forwarded message ---------
From: Tomas Mondragon <tom.alex.mondragon at gmail.com>
Date: Thu, Jan 30, 2020 at 9:54 AM
Subject: Re: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
To: moose-users <moose-users at googlegroups.com>
Configuration log is attached
You received this message because you are subscribed to the Google Groups
"moose-users" group.
To unsubscribe from this group and stop receiving emails from it, send an
email to moose-users+unsubscribe at googlegroups.com.
To view this discussion on the web visit
https://groups.google.com/d/msgid/moose-users/1a976f38-4944-425f-af72-f5ce7ce3ac85%40googlegroups.com
<https://groups.google.com/d/msgid/moose-users/1a976f38-4944-425f-af72-f5ce7ce3ac85%40googlegroups.com?utm_medium=email&utm_source=footer>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200130/8f3f9b11/attachment-0001.html>
Starting configure run at Fri, 24 Jan 2020 17:01:13 -0600
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --download-hypre=downloaded_thirdParty_tarballs/hypre-93baaa8c9.tar.gz --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=downloaded_thirdParty_tarballs/fblaslapack-v3.4.2-p2.tar.gz --download-metis=downloaded_thirdParty_tarballs/metis-v5.1.0-p7.tar.gz --download-ptscotch=downloaded_thirdParty_tarballs/scotch-v6.0.9.tar.gz --download-parmetis=downloaded_thirdParty_tarballs/parmetis-v4.0.3.tar.gz --download-superlu_dist=downloaded_thirdParty_tarballs/superLU-DIST-v6.2.0.tar.gz --download-mumps=downloaded_thirdParty_tarballs/mumps-v5.2.1-p2.tar.gz --download-scalapack=downloaded_thirdParty_tarballs/scalapack-v2.1.0-p1.tar.gz --download-slepc=downloaded_thirdParty_tarballs/slepc-bf89b9d.tar.gz --with-mpi=1 --with-cxx-dialect=C++11 --with-fortran-bindings=0 --with-sowing=0 --with-batch=1 --with-cudac=0 --with-lgrind=0
Working directory: /p/work2/tmondrag/moose/petsc
Machine platform:
('Linux', 'r20i4n17', '4.12.14-95.29-default', '#1 SMP Thu Aug 1 15:34:33 UTC 2019 (47e48a4)', 'x86_64', 'x86_64')
Python version:
2.7.13 (default, Jan 11 2017, 10:56:06) [GCC]
TEST configureExternalPackagesDir from config.framework(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/framework.py:911)
TESTING: configureExternalPackagesDir from config.framework(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/framework.py:911)
TEST configureDebuggers from config.utilities.debuggers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/debuggers.py:21)
TESTING: configureDebuggers from config.utilities.debuggers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/debuggers.py:21)
  Find a default debugger and determine its arguments
Running Executable WITHOUT threads to time it out
Executing: uname -s
stdout: Linux
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/gdb...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/gdb...not found
Checking for program /usr/local/krb5/bin/gdb...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/gdb...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/gdb...not found
Checking for program /opt/clmgr/sbin/gdb...not found
Checking for program /opt/clmgr/bin/gdb...not found
Checking for program /opt/sgi/sbin/gdb...not found
Checking for program /opt/sgi/bin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/bin/gdb...found
              Defined make macro "GDB" to "/usr/bin/gdb"
            Defined "USE_DEBUGGER" to ""gdb""
Executing: uname -s
stdout: Linux
            Defined make macro "DSYMUTIL" to "true"
    child config.utilities.debuggers 0.009440
TEST configureDirectories from PETSc.options.petscdir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
          Version Information:
          #define PETSC_VERSION_RELEASE    0
          #define PETSC_VERSION_MAJOR      3
          #define PETSC_VERSION_MINOR      12
          #define PETSC_VERSION_SUBMINOR   3
          #define PETSC_VERSION_PATCH      0
          #define PETSC_VERSION_DATE       "unknown"
          #define PETSC_VERSION_GIT        "unknown"
          #define PETSC_VERSION_DATE_GIT   "unknown"
          #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_ PETSC_VERSION_EQ
          #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
          #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
          #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
    child PETSc.options.petscdir 0.004710
TEST getDatafilespath from PETSc.options.dataFilesPath(/p/work2/tmondrag/moose/petsc/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(/p/work2/tmondrag/moose/petsc/config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
    child PETSc.options.dataFilesPath 0.000588
TEST configureGit from config.sourceControl(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/git...found
              Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.4.4
    child config.sourceControl 0.004862
TEST configureInstallationMethod from PETSc.options.petscclone(/p/work2/tmondrag/moose/petsc/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(/p/work2/tmondrag/moose/petsc/config/PETSc/options/petscclone.py:20)
          lib/petsc/bin/maint exists. This appears to be a repository clone
          .git directory exists
Executing: ['git', 'describe', '--match=v*']
stdout: v3.12.3-632-gaf591a4
Executing: ['git', 'log', '-1', '--pretty=format:%H']
stdout: af591a4651ec8b1ecff5c03491370c0e4ac5c3a7
Executing: ['git', 'log', '-1', '--pretty=format:%ci']
stdout: 2020-01-24 13:29:59 -0600
Executing: ['git', 'branch']
stdout:
* (HEAD detached from 5ea3abf)
  master
            Defined "VERSION_GIT" to ""v3.12.3-632-gaf591a4""
            Defined "VERSION_DATE_GIT" to ""2020-01-24 13:29:59 -0600""
            Defined "VERSION_BRANCH_GIT" to ""(HEAD detached from 5ea3abf)""
    child PETSc.options.petscclone 0.053460
TEST setNativeArchitecture from PETSc.options.arch(/p/work2/tmondrag/moose/petsc/config/PETSc/options/arch.py:31)
TESTING: setNativeArchitecture from PETSc.options.arch(/p/work2/tmondrag/moose/petsc/config/PETSc/options/arch.py:31)
TEST configureArchitecture from PETSc.options.arch(/p/work2/tmondrag/moose/petsc/config/PETSc/options/arch.py:43)
TESTING: configureArchitecture from PETSc.options.arch(/p/work2/tmondrag/moose/petsc/config/PETSc/options/arch.py:43)
  Checks PETSC_ARCH and sets if not set
        No previous hashfile found
          Setting hashfile: arch-moose/lib/petsc/conf/configure-hash
          Deleting configure hash file: arch-moose/lib/petsc/conf/configure-hash
          Unable to delete configure hash file: arch-moose/lib/petsc/conf/configure-hash
    child PETSc.options.arch 0.077474
TEST setInstallDir from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:35)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
            Defined make macro "PREFIXDIR" to "/p/home/tmondrag/WORK/moose/petsc/arch-moose"
TEST saveReconfigure from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:80)
TESTING: saveReconfigure from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:80)
TEST cleanConfDir from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:73)
TESTING: cleanConfDir from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:73)
TEST configureInstallDir from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:57)
TESTING: configureInstallDir from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:57)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
          Changed persistence directory to /p/home/tmondrag/WORK/moose/petsc/arch-moose/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:93)
TESTING: restoreReconfigure from PETSc.options.installDir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/installDir.py:93)
    child PETSc.options.installDir 0.004305
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/p/work2/tmondrag/moose/petsc/config/PETSc/options/externalpackagesdir.py:22)
    child PETSc.options.externalpackagesdir 0.000327
TEST configureCLanguage from PETSc.options.languages(/p/work2/tmondrag/moose/petsc/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(/p/work2/tmondrag/moose/petsc/config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
          C language is C
            Defined "CLANGUAGE_C" to "1"
            Defined make macro "CLANGUAGE" to "C"
    child PETSc.options.languages 0.001302
TEST printEnvVariables from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1718)
TESTING: printEnvVariables from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1718)
          **** printenv ****
CPPFLAGS=-I/app/unsupported/COST/tcltk/8.6.4/gnu//include
I_MPI_CC=gcc
ARCHIVE_HOST=gold.erdc.hpc.mil
LESS=-M -I -R
PBS_NODENUM=0
ENVIRONMENT=BATCH
PBS_O_LANG=en_US.UTF-8
XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
BASH_FUNC_module%%=() {  eval `/usr/share/Modules/$MODULE_VERSION/bin/modulecmd bash $*`
BC_ACCELERATOR_NODE_CORES=28
KRB5HOME=/usr/local/krb5
SHELL=/bin/bash
MPI_LAUNCH_TIMEOUT=300
BC_STANDARD_NODE_CORES=36
XDG_DATA_DIRS=/usr/share
BC_NODE_TYPE=STANDARD
HISTSIZE=1000
CSI_HOME=/app
LESS_ADVANCED_PREPROCESSOR=no
MANPATH=/app/unsupported/COST/tcltk/8.6.4/gnu//man:/usr/local/krb5/share/man:/p/home/apps/hpe/mpt-2.19/man:/p/home/apps/gnu_compiler/7.2.0/share/man:/usr/local/man:/usr/share/man:/opt/c3/man:/opt/pbs/default/share/man:/opt/clmgr/man:/opt/sgi/share/man:/app/unsupported/local/man:/usr/share/catman:/usr/catman:/usr/man
BC_BIGMEM_NODE_CORES=32
JAVA_HOME=/usr/lib64/jvm/java
PROFILEREAD=true
ARCHIVE_HOME=/erdc1/tmondrag
FPATH=/p/home/apps/hpe/mpt-2.19/include
MPIF90_F90=gfortran
SDK_HOME=/usr/lib64/jvm/java
PBS_NODEFILE=/var/spool/PBS/aux/3741873.jim10
CXX=g++
HOSTNAME=r20i4n17
PBS_QUEUE=itl
PETSC_ARCH=arch-moose
PBS_JOBID=3741873.jim10
MAIL=/var/spool/mail/tmondrag
MACHTYPE=x86_64-suse-linux
BC_PHI_NODE_CORES=0
JAVA_ROOT=/usr/lib64/jvm/java
MINICOM=-c on
CSHEDIT=emacs
LESSOPEN=lessopen.sh %s
PBS_O_LOGNAME=tmondrag
CPATH=/p/home/apps/hpe/mpt-2.19/include:/p/home/apps/gnu_compiler/7.2.0/include
USER=tmondrag
INPUTRC=/etc/inputrc
I_MPI_F77=gfortran
PET_HOME=/app/unsupported/PETtools/CE
CENTER=/gpfs/cwfs/tmondrag
LANGUAGE=en_US.UTF-8
SHLVL=2
ALSA_CONFIG_PATH=/etc/alsa-pulse.conf
CPU=x86_64
PETSC_DIR=/p/home/tmondrag/WORK/moose/scripts/../petsc
PBS_O_PATH=/app/unsupported/COST/git/2.4.4/gnu//bin:/app/unsupported/COST/tcltk/8.6.4/gnu//bin:/usr/local/krb5/bin:/p/home/apps/hpe/mpt-2.19/bin:/p/home/apps/gnu_compiler/7.2.0/bin:/opt/clmgr/sbin:/opt/clmgr/bin:/opt/sgi/sbin:/opt/sgi/bin:/usr/local/krb5/bin:/usr/local/krb5/libexec:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/games:/opt/c3/bin:/opt/pbs/default/bin:/sbin:/bin:/pbs/SLB:/app/unsupported/local/bin:/app/mpiutil
MODULESHOME=/usr/share/Modules/3.2.10
PBS_JOBCOOKIE=0000000076EA4204000000003DDB8E59
JAVA_BINDIR=/usr/lib64/jvm/java/bin
INFOPATH=/p/home/apps/gnu_compiler/7.2.0/share/info
DAAC_HOME=/app/DAAC
PBS_O_HOST=jim07.ib0.ice-x.erdc.hpc.mil
PROJECTS_HOME=/app/unsupported
PKG_CONFIG_PATH=/app/unsupported/COST/tcltk/8.6.4/gnu//lib/pkgconfig
GPG_TTY=not a tty
XNLSPATH=/usr/X11R6/lib/X11/nls
PBS_O_MAIL=/var/mail/tmondrag
TMPDIR=/p/work2/tmondrag
MODULEPATH=/app/unsupported/COST/modules:/p/home/apps/modulefiles/devel:/p/home/apps/modulefiles/apps:/p/home/apps/modulefiles/unsupported:/usr/share/modules:/usr/share/Modules/$MODULE_VERSION/modulefiles:/usr/share/modules/modulefiles:/p/home/tmondrag/my_modules
BC_HOST=jim
PBS_O_SHELL=/bin/bash
XDG_CONFIG_DIRS=/etc/xdg
I_MPI_CXX=g++
OMP_NUM_THREADS=1
PBS_JOBDIR=/p/home/tmondrag
CMAKE_LIBRARY_PATH=/app/unsupported/COST/git/2.4.4/gnu//lib:/app/unsupported/COST/tcltk/8.6.4/gnu//lib
COST_MODULES_DIR=/app/unsupported/COST/modules
BC_NODE_ALLOC=1
COLORTERM=1
QEMU_AUDIO_DRV=pa
_LMFILES_=/p/home/apps/modulefiles/devel/compiler/gcc/7.2.0:/p/home/apps/modulefiles/devel/mpi/sgimpt/2.19:/p/home/apps/modulefiles/unsupported/costinit:/app/unsupported/COST/modules/tcltk/gnu/8.6.4:/app/unsupported/COST/modules/git/gnu/2.4.4
PAGER=less
ACCOUNT=ERDCV9100CDAG
MODULE_VERSION=3.2.10
I_MPI_F90=gfortran
HOME=/p/home/tmondrag
LD_LIBRARY_PATH=/app/unsupported/COST/dependencies/openssl/1.0.2n/gnu/lib:/app/unsupported/COST/dependencies/curl/7.43.0/gnu/lib:/app/unsupported/COST/git/2.4.4/gnu//lib:/app/unsupported/COST/tcltk/8.6.4/gnu//lib:/p/home/apps/hpe/mpt-2.19/lib:/p/home/apps/gnu_compiler/7.2.0/lib64
LANG=en_US.UTF-8
LIBRARY_PATH=/p/home/apps/hpe/mpt-2.19/lib
KRB5_HOME=/usr/local/krb5
NCPUS=1
G_BROKEN_FILENAMES=1
SAMPLES_HOME=/usr/local/cac/Example_Codes
F90=gfortran
PBS_O_WORKDIR=/p/home/tmondrag/WORK/moose
_=./configure
OSTYPE=linux
PBS_TASKNUM=1
PBS_ACCOUNT=ERDCV9100CDAG
PBS_O_SYSTEM=Linux
BC_MPI_TASKS_ALLOC=1
BC_CORES_PER_NODE=36
CC=gcc
NNTPSERVER=news
G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-15,CP1252
HOST=r20i4n17
MPT_VERSION=2.19
GIT_HOME=/app/unsupported/COST/git/2.4.4/gnu/
F77=gfortran
FROM_HEADER=
LESSCLOSE=lessclose.sh %s %s
PBS_MOMPORT=15003
C3_RSH=ssh -oConnectTimeout=10 -oForwardX11=no
MPICXX_CXX=g++
JRE_HOME=/usr/lib64/jvm/java/jre
MORE=-sl
WORKDIR2=/p/work1/tmondrag
PBS_O_HOME=/p/home/tmondrag
HOSTTYPE=x86_64
LOGNAME=tmondrag
BC_MEM_PER_NODE=121856
PATH=/app/unsupported/COST/git/2.4.4/gnu//bin:/app/unsupported/COST/tcltk/8.6.4/gnu//bin:/usr/local/krb5/bin:/p/home/apps/hpe/mpt-2.19/bin:/p/home/apps/gnu_compiler/7.2.0/bin:/opt/clmgr/sbin:/opt/clmgr/bin:/opt/sgi/sbin:/opt/sgi/bin:/usr/local/bin:/usr/bin:/bin:/usr/games:/opt/c3/bin:/opt/pbs/default/bin:/sbin:/bin:/pbs/SLB:/app/unsupported/local/bin:/app/mpiutil
PETTT_HOME=/app/unsupported/PETtools/CE
PBS_ENVIRONMENT=PBS_BATCH
CMAKE_INCLUDE_PATH=/app/unsupported/COST/tcltk/8.6.4/gnu//include
SDL_AUDIODRIVER=pulse
LDFLAGS=-L/app/unsupported/COST/git/2.4.4/gnu//lib -L/app/unsupported/COST/tcltk/8.6.4/gnu//lib
MPICC_CC=gcc
COST_HOME=/app/unsupported/COST
MODULE_VERSION_STACK=3.2.10
I_MPI_FC=gfortran
MPI_ROOT=/p/home/apps/hpe/mpt-2.19
USE_PCM_DB=2
LESSKEY=/etc/lesskey.bin
TZ=US/Central
JDK_HOME=/usr/lib64/jvm/java
WORKDIR=/p/work2/tmondrag
WINDOWMANAGER=
AUDIODRIVER=pulseaudio
PYTHONSTARTUP=/etc/pythonstart
OLDPWD=/p/home/tmondrag/WORK/moose
LOADEDMODULES=compiler/gcc/7.2.0:mpi/sgimpt/2.19:costinit:tcltk/gnu/8.6.4:git/gnu/2.4.4
PBS_O_QUEUE=itl
PWD=/p/home/tmondrag/WORK/moose/petsc
PBS_JOBNAME=PETSc_rebuild
TEST resetEnvCompilers from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1725)
TESTING: resetEnvCompilers from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1725)
                  ***** WARNING: CC (set to gcc) found in environment variables - ignoring
                   use ./configure CC=$CC if you really want to use that value ******
                  ***** WARNING: CXX (set to g++) found in environment variables - ignoring
                   use ./configure CXX=$CXX if you really want to use that value ******
                  ***** WARNING: F77 (set to gfortran) found in environment variables - ignoring
                   use ./configure F77=$F77 if you really want to use that value ******
                  ***** WARNING: F90 (set to gfortran) found in environment variables - ignoring
                   use ./configure F90=$F90 if you really want to use that value ******
                  ***** WARNING: CPPFLAGS (set to -I/app/unsupported/COST/tcltk/8.6.4/gnu//include) found in environment variables - ignoring
                   use ./configure CPPFLAGS=$CPPFLAGS if you really want to use that value ******
                  ***** WARNING: LDFLAGS (set to -L/app/unsupported/COST/git/2.4.4/gnu//lib -L/app/unsupported/COST/tcltk/8.6.4/gnu//lib) found in environment variables - ignoring
                   use ./configure LDFLAGS=$LDFLAGS if you really want to use that value ******
TEST checkEnvCompilers from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1755)
TESTING: checkEnvCompilers from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1755)
TEST checkMPICompilerOverride from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1688)
TESTING: checkMPICompilerOverride from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1688)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1709)
TESTING: requireMpiLdPath from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1709)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkInitialFlags from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:458)
TESTING: checkInitialFlags from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:458)
  Initialize the compiler and linker flags
          Initialized CFLAGS to
          Initialized LDFLAGS to
          Initialized CUDAFLAGS to
          Initialized CXXFLAGS to
          Initialized CXX_CXXFLAGS to
          Initialized FFLAGS to
          Initialized CPPFLAGS to
          Initialized FPPFLAGS to
          Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
          Initialized CXXPPFLAGS to
          Initialized CC_LINKER_FLAGS to []
          Initialized CXX_LINKER_FLAGS to []
          Initialized FC_LINKER_FLAGS to []
          Initialized CUDAC_LINKER_FLAGS to []
          Initialized sharedLibraryFlags to []
          Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:628)
TESTING: checkCCompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:628)
  Locate a functional C compiler
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/mpicc...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/mpicc...not found
Checking for program /usr/local/krb5/bin/mpicc...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/mpicc...found
              Defined make macro "CC" to "mpicc"
                          All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny
                        All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 1
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
Executing: mpicc --version
stdout:
gcc (GCC) 7.2.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
          Since MPI c compiler starts with mpi, force searches for other compilers to only look for MPI compilers
TEST checkCPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:667)
TESTING: checkCPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:667)
  Locate a functional C preprocessor
              Defined make macro "CPP" to "mpicc -E"
Preprocessing source:
#include <stdlib.h>
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Preprocess stderr before filtering::
Preprocess stderr after filtering::
TEST checkCUDACompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:703)
TESTING: checkCUDACompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:703)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:743)
TESTING: checkCUDAPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:743)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:842)
TESTING: checkCxxCompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:842)
  Locate a functional Cxx compiler
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/mpicxx...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/mpicxx...not found
Checking for program /usr/local/krb5/bin/mpicxx...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/mpicxx...found
              Defined make macro "CXX" to "mpicxx"
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Executing: mpicxx --version
stdout:
g++ (GCC) 7.2.0
TEST checkCxxPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:883)
TESTING: checkCxxPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:883)
  Locate a functional Cxx preprocessor
              Defined make macro "CXXPP" to "mpicxx -E"
#include <cstdlib>
Executing: mpicxx -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
TEST checkFortranCompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:984)
TESTING: checkFortranCompiler from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:984)
  Locate a functional Fortran compiler
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/mpif90...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/mpif90...not found
Checking for program /usr/local/krb5/bin/mpif90...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/mpif90...found
              Defined make macro "FC" to "mpif90"
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Executing: mpif90 --version
stdout:
GNU Fortran (GCC) 7.2.0
TEST checkFortranPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1021)
TESTING: checkFortranPreprocessor from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1021)
  Locate a functional Fortran preprocessor
              Defined make macro "FPP" to "mpif90 -E"
            Deleting "FPP"
              Defined make macro "FPP" to "mpif90 --use cpp32"
            Deleting "FPP"
TEST checkFortranComments from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1043)
TESTING: checkFortranComments from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1043)
  Make sure fortran comment "!" works
Successful compile:
Source:
      program main
! comment
      end
          Fortran comments can use ! in column 1
TEST checkLargeFileIO from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1174)
TESTING: checkLargeFileIO from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1174)
TEST checkArchiver from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1273)
TESTING: checkArchiver from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1273)
  Check that the archiver exists and can make a library usable by the compiler
Executing: ar -V
stdout:
GNU ar (GNU Binutils; SUSE Linux Enterprise 12) 2.32.0.20190909-9.36
Copyright (C) 2019 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
                Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/ar...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/ar...not found
Checking for program /usr/local/krb5/bin/ar...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/ar...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/ar...not found
Checking for program /opt/clmgr/sbin/ar...not found
Checking for program /opt/clmgr/bin/ar...not found
Checking for program /opt/sgi/sbin/ar...not found
Checking for program /opt/sgi/bin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/bin/ar...found
              Defined make macro "AR" to "/usr/bin/ar"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/ranlib...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/ranlib...not found
Checking for program /usr/local/krb5/bin/ranlib...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/ranlib...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/ranlib...not found
Checking for program /opt/clmgr/sbin/ranlib...not found
Checking for program /opt/clmgr/bin/ranlib...not found
Checking for program /opt/sgi/sbin/ranlib...not found
Checking for program /opt/sgi/bin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
              Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconf1.a /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- 'c'
          Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
Successful compile:
Source:
int foo(int a) {
  return a+1;
              Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -L/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -lconf1
            Defined make macro "AR_FLAGS" to "cr"
            Defined make macro "AR_LIB_SUFFIX" to "a"
TEST checkSharedLinker from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1387)
TESTING: checkSharedLinker from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1387)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: Linux
          Checking shared linker mpicc using flags ['-shared']
              Defined make macro "LD_SHARED" to "mpicc"
          Trying C compiler flag
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest  -shared   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
            Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
void  foo(void){
  fprintf_ptr(stdout,"hello");
  return;
void bar(void){foo();}
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconftest.so  -shared  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o: relocation R_X86_64_PC32 against symbol `fprintf_ptr' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: nonrepresentable section on output
          Rejected C compiler flag  because it was not compatible with shared linker mpicc using flags ['-shared']
Executing: mpicc --help | head -n 20
stdout:
Usage: gcc [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase.
  --help                   Display this information.
  --target-help            Display target specific command line options.
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...].
                           Display specific types of command line options.
  (Use '-v --help' to display command line options of sub-processes).
  --version                Display compiler version information.
  -dumpspecs               Display all of the built in spec strings.
  -dumpversion             Display the version of the compiler.
  -dumpmachine             Display the compiler's target processor.
  -print-search-dirs       Display the directories in the compiler's search path.
  -print-libgcc-file-name  Display the name of the compiler's companion library.
  -print-file-name=<lib>   Display the full path to library <lib>.
  -print-prog-name=<prog>  Display the full path to compiler component <prog>.
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path.
  -print-multi-directory   Display the root directory for versions of libgcc.
  -print-multi-lib         Display the mapping between command line options and
          Trying C compiler flag -fPIC
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fPIC
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest  -shared   -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconftest.so  -shared  -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if (ret) {}
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o  -L/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -lconftest
          Using shared linker mpicc with flags ['-shared'] and library extension so
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
TEST checkPIC from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1121)
TESTING: checkPIC from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1121)
  Determine the PIC option for each compiler
          Trying Cxx for PIC code without any compiler flag
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
stderr:
          Rejected Cxx compiler flag  because shared linker cannot handle it
Executing: mpicxx --help | head -n 20
stdout:
Usage: g++ [options] file...
Options:
          Trying Cxx compiler flag -fPIC for PIC code
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers   -fPIC   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fPIC
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
          Accepted Cxx compiler flag -fPIC for PIC code
          Trying FC for PIC code without any compiler flag
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o: relocation R_X86_64_PC32 against symbol `xx_' can not be used when making a shared object; recompile with -fPIC
          Rejected FC compiler flag  because shared linker cannot handle it
Executing: mpif90 --help | head -n 20
stdout:
Usage: gfortran [options] file...
Options:
          Trying FC compiler flag -fPIC for PIC code
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -fPIC
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
          Accepted FC compiler flag -fPIC for PIC code
TEST checkSharedLinkerPaths from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1499)
TESTING: checkSharedLinkerPaths from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1499)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
Executing: uname -s
stdout: Linux
Executing: mpicc -V
          Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest  -Wl,-rpath,/p/work2/tmondrag/moose/petsc   -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
            Valid C linker flag -Wl,-rpath,/p/work2/tmondrag/moose/petsc
Executing: uname -s
stdout: Linux
Executing: mpicc -V
          Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest  -Wl,-rpath,/p/work2/tmondrag/moose/petsc   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
            Valid Cxx linker flag -Wl,-rpath,/p/work2/tmondrag/moose/petsc
Executing: uname -s
stdout: Linux
Executing: mpicc -V
          Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest  -Wl,-rpath,/p/work2/tmondrag/moose/petsc   -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o
            Valid FC linker flag -Wl,-rpath,/p/work2/tmondrag/moose/petsc
TEST checkLibC from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1534)
TESTING: checkLibC from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1534)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
          Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1580)
TESTING: checkDynamicLinker from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1580)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                        All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.headers
#include <dlfcn.h>
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.headers  /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
              Defined "HAVE_DLFCN_H" to "1"
              Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
                            All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.libraries
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -ldl
                Defined "HAVE_LIBDL" to "1"
            Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
          Checking dynamic linker mpicc using flags ['-shared']
              Defined make macro "DYNAMICLINKER" to "mpicc"
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest  -shared   -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconftest.so  -shared  -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include <dlfcn.h>
#include <stdio.h>
int main() {
void *handle = dlopen("/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
  printf("Could not load symbol\n");
  return -1;
if ((*foo)()) {
  printf("Invalid return from foo()\n");
  return -1;
if (dlclose(handle)) {
  printf("Could not close library\n");
  return -1;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    -fPIC /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -ldl
          Using dynamic linker mpicc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1629)
TESTING: output from config.setCompilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/setCompilers.py:1629)
  Output module data as defines and substitutions
            Substituting "CC" with "mpicc"
            Substituting "CFLAGS" with " -fPIC"
            Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
            Substituting "CPP" with "mpicc -E"
            Substituting "CPPFLAGS" with ""
            Substituting "CXX" with "mpicxx"
            Substituting "CXX_CXXFLAGS" with " -fPIC"
            Substituting "CXXFLAGS" with ""
            Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
            Substituting "CXXPP" with "mpicxx -E"
            Substituting "CXXPPFLAGS" with ""
            Substituting "FC" with "mpif90"
            Substituting "FFLAGS" with " -fPIC"
            Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
            Substituting "LDFLAGS" with ""
            Substituting "LIBS" with "-ldl "
            Substituting "SHARED_LIBRARY_FLAG" with "-shared"
    child config.setCompilers 7.550401
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:36)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:36)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:52)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:52)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
Executing: uname -s
stdout: Linux
            Defined make rule "shared_arch" with dependencies "shared_linux" and code []
            Defined make macro "SONAME_FUNCTION" to "$(1).so.$(2)"
            Defined make macro "SL_LINKER_FUNCTION" to "-shared -Wl,-soname,$(call SONAME_FUNCTION,$(notdir $(1)),$(2))"
            Defined make macro "BUILDSHAREDLIB" to "yes"
            Defined "USE_SHARED_LIBRARIES" to "1"
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:94)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:94)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
            Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:100)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(/p/work2/tmondrag/moose/petsc/config/PETSc/options/sharedLibraries.py:100)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
    child PETSc.options.sharedLibraries 0.007385
TEST configureIndexSize from PETSc.options.indexTypes(/p/work2/tmondrag/moose/petsc/config/PETSc/options/indexTypes.py:30)
TESTING: configureIndexSize from PETSc.options.indexTypes(/p/work2/tmondrag/moose/petsc/config/PETSc/options/indexTypes.py:30)
            Defined make macro "PETSC_INDEX_SIZE" to "32"
    child PETSc.options.indexTypes 0.000857
TEST configureCompilerFlags from config.compilerFlags(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilerFlags.py:72)
  Get the default compiler flags
              Defined make macro "C_VERSION" to "gcc (GCC) 7.2.0"
                Defined make macro "MPICC_SHOW" to "gcc -I/p/home/apps/hpe/mpt-2.19/include -lpthread /usr/lib64/libcpuset.so.1 /usr/lib64/libbitmask.so.1 -L/p/home/apps/hpe/mpt-2.19/lib -lmpi"
          Trying C compiler flag -Wall
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wall
          Trying C compiler flag -Wwrite-strings
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wwrite-strings
          Trying C compiler flag -Wno-strict-aliasing
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-strict-aliasing
          Trying C compiler flag -Wno-unknown-pragmas
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -Wno-unknown-pragmas
          Trying C compiler flag -fstack-protector
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fstack-protector
          Trying C compiler flag -mfp16-format=ieee
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -mfp16-format=ieee   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 1
stderr:
gcc: error: unrecognized command line option ���-mfp16-format=ieee���
Source:
int main() {
  return 0;
              Rejecting compiler flag -mfp16-format=ieee  due to nonzero status from link
PETSc Error: No output file produced
          Rejected C compiler flag -mfp16-format=ieee
          Trying C compiler flag -fvisibility=hidden
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -fvisibility=hidden
          Trying C compiler flag -g
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -g
          Trying C compiler flag -O
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag -O
              Defined make macro "Cxx_VERSION" to "g++ (GCC) 7.2.0"
                Defined make macro "MPICXX_SHOW" to "g++ -I/p/home/apps/hpe/mpt-2.19/include -lpthread /usr/lib64/libcpuset.so.1 /usr/lib64/libbitmask.so.1 -L/p/home/apps/hpe/mpt-2.19/lib -lmpi++ -lmpi"
          Trying Cxx compiler flag -Wall
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wall
          Trying Cxx compiler flag -Wwrite-strings
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wwrite-strings
          Trying Cxx compiler flag -Wno-strict-aliasing
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-strict-aliasing
          Trying Cxx compiler flag -Wno-unknown-pragmas
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -Wno-unknown-pragmas
          Trying Cxx compiler flag -fstack-protector
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fstack-protector
          Trying Cxx compiler flag -fvisibility=hidden
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -fvisibility=hidden
          Trying Cxx compiler flag -g
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -g
          Trying Cxx compiler flag -O
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -O
              Defined make macro "FC_VERSION" to "GNU Fortran (GCC) 7.2.0"
                Defined make macro "MPIFC_SHOW" to "gfortran -I/p/home/apps/hpe/mpt-2.19/include -I/p/home/apps/gnu_compiler/7.2.0/include -I/p/home/apps/hpe/mpt-2.19/include -lpthread /usr/lib64/libcpuset.so.1 /usr/lib64/libbitmask.so.1 -L/p/home/apps/hpe/mpt-2.19/lib -lmpi"
          Trying FC compiler flag -Wall
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wall
          Trying FC compiler flag -ffree-line-length-0
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -ffree-line-length-0   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -ffree-line-length-0
          Trying FC compiler flag -Wno-unused-dummy-argument
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -Wno-unused-dummy-argument
          Trying FC compiler flag -g
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -g
          Trying FC compiler flag -O
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag -O
    child config.compilerFlags 1.136165
TEST checkRestrict from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:138)
TESTING: checkRestrict from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:138)
  Check for the C/CXX restrict keyword
Executing: mpicc -V
                      All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.compilers
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.c:5:20: warning: unused variable ���x��� [-Wunused-variable]
 float * __restrict x;;
Source:
int main() {
  return 0;
          compilers: Set C restrict keyword to __restrict
            Defined "C_RESTRICT" to "__restrict"
TEST checkCFormatting from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:391)
TESTING: checkCFormatting from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:391)
  Activate format string checking if using the GNU compilers
TEST checkCInline from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:108)
TESTING: checkCInline from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:108)
  Check for C inline keyword
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
          compilers: Set C Inline keyword to inline
            Defined "C_INLINE" to "inline"
TEST checkDynamicLoadFlag from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:402)
TESTING: checkDynamicLoadFlag from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:402)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);dlopen(libname, RTLD_NOW);dlopen(libname, RTLD_LOCAL);dlopen(libname, RTLD_GLOBAL);
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -ldl
            Defined "HAVE_RTLD_LAZY" to "1"
            Defined "HAVE_RTLD_NOW" to "1"
            Defined "HAVE_RTLD_LOCAL" to "1"
            Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:202)
TESTING: checkCLibraries from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:202)
  Determines the libraries needed to link with C compiled code
Successful compile:
Source:
#include <stdio.h>
void asub(void)
{char s[16];printf("testing %s",s);}
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.F90
Successful compile:
Source:
      program main
      print*,'testing'
      stop
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o -ldl
          C libraries are not needed when using Fortran linker
Successful compile:
Source:
#include <stdio.h>
void asub(void)
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc
Successful compile:
Source:
 int main(int argc,char **args)
{return 0;}
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o -ldl
          C libraries are not needed when using C++ linker
TEST checkDependencyGenerationFlag from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1345)
TESTING: checkDependencyGenerationFlag from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1345)
  Check if -MMD works for dependency generation, and add it if it does
          Trying C compiler flag -MMD -MP
            Defined make macro "C_DEPFLAGS" to "-MMD -MP"
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -MMD -MP  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
  return 0;
          Trying Cxx compiler flag -MMD -MP
            Defined make macro "CXX_DEPFLAGS" to "-MMD -MP"
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  -fPIC -MMD -MP  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
  return 0;
TEST checkC99Flag from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1390)
TESTING: checkC99Flag from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1390)
  Check for -std=c99 or equivalent flag
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c:7:11: warning: variable ���x��� set but not used [-Wunused-but-set-variable]
     float x[2],y;
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
    for (int i=0; i<2; i++){
      x[i] = i*j*y;
  return 0;
          Accepted C99 compile flag:
            Defined "HAVE_C99" to "1"
Executing: mpicc -V
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc: In function ���int main()���:
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:5:20: warning: unused variable ���x��� [-Wunused-variable]
Source:
int main() {
  return 0;
          compilers: Set Cxx restrict keyword to __restrict
            Defined "CXX_RESTRICT" to "__restrict"
TEST checkCxxOptionalExtensions from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:421)
TESTING: checkCxxOptionalExtensions from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:421)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O    -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
  return 0;
TEST checkCxxInline from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:123)
TESTING: checkCxxInline from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:123)
  Check for C++ inline keyword
Running Executable WITHOUT threads to time it out
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
          compilers: Set Cxx Inline keyword to inline
            Defined "CXX_INLINE" to "inline"
TEST checkCxxLibraries from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:533)
TESTING: checkCxxLibraries from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:533)
  Determines the libraries needed to link with C++ from C and Fortran
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
{std::vector<int> v;
try  { throw 20;  }  catch (int e)  { std::cout << "An exception occurred";  }}
Successful compile:
Source:
{return 0;}
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o -ldl
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o: in function `asub()':
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `__cxa_allocate_exception'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `typeinfo for int'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `__cxa_throw'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `__cxa_begin_catch'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `std::cout'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.cc:7: undefined reference to `__cxa_end_catch'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o: in function `__static_initialization_and_destruction_0':
/p/home/apps/gnu_compiler/7.2.0/include/c++/7.2.0/iostream:74: undefined reference to `std::ios_base::Init::Init()'
/usr/bin/ld: /p/home/apps/gnu_compiler/7.2.0/include/c++/7.2.0/iostream:74: undefined reference to `std::ios_base::Init::~Init()'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o:(.data.DW.ref._ZTIi[DW.ref._ZTIi]+0x0): undefined reference to `typeinfo for int'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o:(.data.DW.ref.__gxx_personality_v0[DW.ref.__gxx_personality_v0]+0x0): undefined reference to `__gxx_personality_v0'
Executing: uname -s
stdout: Linux
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Successful compile:
Source:
{return 0;}
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o -lstdc++ -ldl
          compilers: C++ requires -lstdc++ to link with C compiler
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
Successful compile:
Source:
      program main
      print*,'testing'
      stop
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o -lstdc++ -ldl
          C++ libraries are not needed when using FC linker
TEST checkCxxDialect from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:449)
TESTING: checkCxxDialect from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:449)
  Determine the Cxx dialect supported by the compiler [and correspoding compiler option - if any].
    -with-cxx-dialect can take options:
      auto: use highest dialect configure can determine
      cxx17: [future?]
      cxx14: gnu++14 or c++14
      cxx11: gnu++11 or c++11
      0: disable CxxDialect check and use compiler default
          checkCxxDialect: checking CXX11 with flag:
            Defined "HAVE_CXX_DIALECT_CXX11" to "1"
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O   -fPIC  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.cc
Successful compile:
Source:
          #include <random>
          #include <iostream>
          #include <complex>
          template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
          const double x = dist(mt);
          std::cout << x;
  return 0;
Executing: mpicxx -V
TEST checkFortranNameMangling from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:838)
TESTING: checkFortranNameMangling from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:838)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
          compilers: Fortran name mangling is underscore
            Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
stdout:
            Defined "FORTRAN_CHARLEN_T" to "int"
TEST checkFortranNameManglingDouble from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:879)
TESTING: checkFortranNameManglingDouble from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:879)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
Successful compile:
Source:
void d1_chk__(void){return;}
Successful compile:
Source:
      program main
       call d1_chk()
      end
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o: in function `MAIN__':
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.F90:2: undefined reference to `d1_chk_'
TEST checkFortranLibraries from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:889)
TESTING: checkFortranLibraries from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:889)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
stderr:
/p/home/apps/hpe/mpt-2.19/include/mpif.h:561:54:
         integer MPI_STATUSES_IGNORE(MPI_STATUS_SIZE,1)
                                                      1
Warning: Unused variable ���mpi_statuses_ignore��� declared at (1) [-Wunused-variable]
Source:
      program main
#include <mpif.h>
      call MPI_Allreduce()
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -lstdc++ -ldl
Successful compile:
Source:
subroutine asub()
      print*,'testing'
      return
      end
Successful compile:
Source:
{return 0;}
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o: in function `asub_':
/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.F90:2: undefined reference to `_gfortran_st_write'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.F90:2: undefined reference to `_gfortran_transfer_character_write'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.F90:2: undefined reference to `_gfortran_st_write_done'
          Fortran code cannot directly be linked with C linker, therefore will determine needed Fortran libraries
Successful compile:
Source:
      program main
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest  -v   -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -lstdc++ -ldl
stderr:
Driving: gfortran -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest -v -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -lstdc++ -ldl -I/p/home/apps/hpe/mpt-2.19/include -I/p/home/apps/gnu_compiler/7.2.0/include -I/p/home/apps/hpe/mpt-2.19/include -lpthread /usr/lib64/libcpuset.so.1 /usr/lib64/libbitmask.so.1 -L/p/home/apps/hpe/mpt-2.19/lib -lmpi -l gfortran -l m -shared-libgcc
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /p/home/u4immtww/gcc-7.2.0/configure --prefix=/p/home/apps/gnu_compiler/7.2.0 --enable-languages=c,c++,fortran,go
Thread model: posix
gcc version 7.2.0 (GCC)
Reading specs from /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64/libgfortran.spec
rename spec lib to liborig
COLLECT_GCC_OPTIONS='-o' '/p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest' '-v' '-fPIC' '-Wall' '-ffree-line-length-0' '-Wno-unused-dummy-argument' '-g' '-O' '-I' '/p/home/apps/hpe/mpt-2.19/include' '-I' '/p/home/apps/gnu_compiler/7.2.0/include' '-I' '/p/home/apps/hpe/mpt-2.19/include' '-L/p/home/apps/hpe/mpt-2.19/lib' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
COMPILER_PATH=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/
LIBRARY_PATH=/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/p/home/apps/hpe/mpt-2.19/lib/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../:/lib/:/usr/lib/
 /p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/collect2 -plugin /p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/liblto_plugin.so -plugin-opt=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/lto-wrapper -plugin-opt=-fresolution=/p/work2/tmondrag/cceWXJkS.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lquadmath -plugin-opt=-pass-through=-lm -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --eh-frame-hdr -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest /usr/lib/../lib64/crt1.o /usr/lib/../lib64/crti.o /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/crtbegin.o -L/p/home/apps/hpe/mpt-2.19/lib -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/p/home/apps/hpe/mpt-2.19/lib -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../.. /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o -lstdc++ -ldl -lpthread /usr/lib64/libcpuset.so.1 /usr/lib64/libbitmask.so.1 -lmpi -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/crtend.o /usr/lib/../lib64/crtn.o
          compilers: Checking arg Driving:
          compilers: Unknown arg Driving:
          compilers: Checking arg gfortran
          compilers: Unknown arg gfortran
          compilers: Checking arg -o
          compilers: Unknown arg -o
          compilers: Checking arg /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest
          compilers: Unknown arg /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest
          compilers: Checking arg -v
          compilers: Unknown arg -v
          compilers: Checking arg -fPIC
          compilers: Unknown arg -fPIC
          compilers: Checking arg -Wall
          compilers: Unknown arg -Wall
          compilers: Checking arg -ffree-line-length-0
          compilers: Unknown arg -ffree-line-length-0
          compilers: Checking arg -Wno-unused-dummy-argument
          compilers: Unknown arg -Wno-unused-dummy-argument
          compilers: Checking arg -g
          compilers: Unknown arg -g
          compilers: Checking arg -O
          compilers: Unknown arg -O
          compilers: Checking arg /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o
          compilers: Unknown arg /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o
          compilers: Checking arg -lstdc++
          compilers: Found library: -lstdc++
          compilers: Checking arg -ldl
          compilers: Found library: -ldl
          compilers: Checking arg -I/p/home/apps/hpe/mpt-2.19/include
          compilers: Found include directory: /p/home/apps/hpe/mpt-2.19/include
          compilers: Checking arg -I/p/home/apps/gnu_compiler/7.2.0/include
          compilers: Found include directory: /p/home/apps/gnu_compiler/7.2.0/include
          compilers: Checking arg -lpthread
          compilers: Found library: -lpthread
          compilers: Checking arg /usr/lib64/libcpuset.so.1
          compilers: Unknown arg /usr/lib64/libcpuset.so.1
          compilers: Checking arg /usr/lib64/libbitmask.so.1
          compilers: Unknown arg /usr/lib64/libbitmask.so.1
          compilers: Checking arg -L/p/home/apps/hpe/mpt-2.19/lib
          compilers: Found library directory: -L/p/home/apps/hpe/mpt-2.19/lib
          compilers: Checking arg -lmpi
          compilers: Found library: -lmpi
          compilers: Found canonical library: -lgfortran
          compilers: Found canonical library: -lm
          compilers: Checking arg -shared-libgcc
          compilers: Unknown arg -shared-libgcc
          compilers: Checking arg Using
          compilers: Unknown arg Using
          compilers: Checking arg built-in
          compilers: Unknown arg built-in
          compilers: Checking arg specs.
          compilers: Unknown arg specs.
          compilers: Checking arg COLLECT_GCC=gfortran
          compilers: Unknown arg COLLECT_GCC=gfortran
          compilers: Checking arg COLLECT_LTO_WRAPPER=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/lto-wrapper
          compilers: Unknown arg COLLECT_LTO_WRAPPER=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/lto-wrapper
          compilers: Checking arg Target:
          compilers: Unknown arg Target:
          compilers: Checking arg x86_64-pc-linux-gnu
          compilers: Unknown arg x86_64-pc-linux-gnu
          compilers: Checking arg Configured
          compilers: Unknown arg Configured
          compilers: Checking arg with:
          compilers: Unknown arg with:
          compilers: Checking arg /p/home/u4immtww/gcc-7.2.0/configure
          compilers: Unknown arg /p/home/u4immtww/gcc-7.2.0/configure
          compilers: Checking arg --prefix=/p/home/apps/gnu_compiler/7.2.0
          compilers: Unknown arg --prefix=/p/home/apps/gnu_compiler/7.2.0
          compilers: Checking arg --enable-languages=c,c++,fortran,go
          compilers: Unknown arg --enable-languages=c,c++,fortran,go
          compilers: Checking arg Thread
          compilers: Unknown arg Thread
          compilers: Checking arg model:
          compilers: Unknown arg model:
          compilers: Checking arg posix
          compilers: Unknown arg posix
          compilers: Checking arg gcc
          compilers: Unknown arg gcc
          compilers: Checking arg version
          compilers: Unknown arg version
          compilers: Checking arg 7.2.0
          compilers: Unknown arg 7.2.0
          compilers: Checking arg (GCC)
          compilers: Unknown arg (GCC)
          compilers: Checking arg Reading
          compilers: Unknown arg Reading
          compilers: Checking arg from
          compilers: Unknown arg from
          compilers: Checking arg /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64/libgfortran.spec
          compilers: Unknown arg /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64/libgfortran.spec
          compilers: Checking arg rename
          compilers: Unknown arg rename
          compilers: Checking arg lib
          compilers: Unknown arg lib
          compilers: Checking arg to
          compilers: Unknown arg to
          compilers: Checking arg liborig
          compilers: Unknown arg liborig
          compilers: Checking arg COLLECT_GCC_OPTIONS=
          compilers: Unknown arg COLLECT_GCC_OPTIONS=
          compilers: Checking arg COMPILER_PATH=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/
          compilers: Skipping arg COMPILER_PATH=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/
          compilers: Checking arg LIBRARY_PATH=/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/p/home/apps/hpe/mpt-2.19/lib/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../:/lib/:/usr/lib/
          compilers: Skipping arg LIBRARY_PATH=/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/p/home/apps/hpe/mpt-2.19/lib/:/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../:/lib/:/usr/lib/
          compilers: Checking arg /p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/collect2
          compilers: Unknown arg /p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/collect2
          compilers: Checking arg -plugin
          compilers: Unknown arg -plugin
          compilers: Checking arg /p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/liblto_plugin.so
          compilers: Unknown arg /p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/liblto_plugin.so
          compilers: Checking arg -plugin-opt=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/lto-wrapper
          compilers: Unknown arg -plugin-opt=/p/home/apps/gnu_compiler/7.2.0/libexec/gcc/x86_64-pc-linux-gnu/7.2.0/lto-wrapper
          compilers: Checking arg -plugin-opt=-fresolution=/p/work2/tmondrag/cceWXJkS.res
          compilers: Unknown arg -plugin-opt=-fresolution=/p/work2/tmondrag/cceWXJkS.res
          compilers: Checking arg -plugin-opt=-pass-through=-lgcc_s
          compilers: Unknown arg -plugin-opt=-pass-through=-lgcc_s
          compilers: Checking arg -plugin-opt=-pass-through=-lquadmath
          compilers: Unknown arg -plugin-opt=-pass-through=-lquadmath
          compilers: Checking arg -plugin-opt=-pass-through=-lm
          compilers: Unknown arg -plugin-opt=-pass-through=-lm
          compilers: Checking arg -plugin-opt=-pass-through=-lc
          compilers: Unknown arg -plugin-opt=-pass-through=-lc
          compilers: Checking arg --eh-frame-hdr
          compilers: Unknown arg --eh-frame-hdr
          compilers: Checking arg -m
          compilers: Unknown arg -m
          compilers: Checking arg elf_x86_64
          compilers: Unknown arg elf_x86_64
          compilers: Checking arg -dynamic-linker
          compilers: Unknown arg -dynamic-linker
          compilers: Checking arg /lib64/ld-linux-x86-64.so.2
          compilers: Unknown arg /lib64/ld-linux-x86-64.so.2
          compilers: Checking arg /usr/lib/../lib64/crt1.o
          compilers: Unknown arg /usr/lib/../lib64/crt1.o
          compilers: Checking arg /usr/lib/../lib64/crti.o
          compilers: Unknown arg /usr/lib/../lib64/crti.o
          compilers: Checking arg /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/crtbegin.o
          compilers: Unknown arg /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/crtbegin.o
          compilers: Already in lflags so skipping: -L/p/home/apps/hpe/mpt-2.19/lib
          compilers: Checking arg -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0
          compilers: Found library directory: -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0
          compilers: Checking arg -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/../../../../lib64
          compilers: Found library directory: -L/p/home/apps/gnu_compiler/7.2.0/lib64
          compilers: Checking arg -L/lib/../lib64
          compilers: Checking arg -L/usr/lib/../lib64
          compilers: Already in lflags: -lstdc++
          compilers: Already in lflags: -ldl
          compilers: Already in lflags: -lpthread
          compilers: Already in lflags: -lmpi
          compilers: Checking arg -lgfortran
          compilers: Found library: -lgfortran
          compilers: Checking arg -lgcc_s
          compilers: Found library: -lgcc_s
          compilers: Found system library therefore skipping: -lgcc
          compilers: Checking arg -lquadmath
          compilers: Found library: -lquadmath
          compilers: Already in lflags: -lgcc_s
          compilers: Checking arg -lc
          compilers: Found system library therefore skipping: -lc
          compilers: Checking arg /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/crtend.o
          compilers: Unknown arg /p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0/crtend.o
          compilers: Checking arg /usr/lib/../lib64/crtn.o
          compilers: Unknown arg /usr/lib/../lib64/crtn.o
          compilers: Libraries needed to link Fortran code with the C linker: ['-lstdc++', '-ldl', '-lpthread', '-Wl,-rpath,/p/home/apps/hpe/mpt-2.19/lib', '-L/p/home/apps/hpe/mpt-2.19/lib', '-lmpi', '-lgfortran', '-lm', '-Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0', '-L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0', '-Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib64', '-L/p/home/apps/gnu_compiler/7.2.0/lib64', '-Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib', '-L/p/home/apps/gnu_compiler/7.2.0/lib', '-lgfortran', '-lm', '-lgcc_s', '-lquadmath']
          compilers: Libraries needed to link Fortran main with the C linker: []
          compilers: Check that Fortran libraries can be used with C as the linker
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -lstdc++ -ldl -lpthread -Wl,-rpath,/p/home/apps/hpe/mpt-2.19/lib -L/p/home/apps/hpe/mpt-2.19/lib -lmpi -lgfortran -lm -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib64 -L/p/home/apps/gnu_compiler/7.2.0/lib64 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib -L/p/home/apps/gnu_compiler/7.2.0/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -lstdc++ -ldl -lpthread -Wl,-rpath,/p/home/apps/hpe/mpt-2.19/lib -L/p/home/apps/hpe/mpt-2.19/lib -lmpi -lgfortran -lm -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib64 -L/p/home/apps/gnu_compiler/7.2.0/lib64 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib -L/p/home/apps/gnu_compiler/7.2.0/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 1
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
collect2: error: ld returned 1 exit status
          compilers: Check that Fortran libraries can be used with C++ as linker
          compilers: Fortran libraries can be used from C++
Successful compile:
Source:
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -lstdc++ -ldl -lpthread -Wl,-rpath,/p/home/apps/hpe/mpt-2.19/lib -L/p/home/apps/hpe/mpt-2.19/lib -lmpi -lgfortran -lm -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib64 -L/p/home/apps/gnu_compiler/7.2.0/lib64 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib -L/p/home/apps/gnu_compiler/7.2.0/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -lstdc++ -ldl -lpthread -Wl,-rpath,/p/home/apps/hpe/mpt-2.19/lib -L/p/home/apps/hpe/mpt-2.19/lib -lmpi -lgfortran -lm -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -L/p/home/apps/gnu_compiler/7.2.0/lib/gcc/x86_64-pc-linux-gnu/7.2.0 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib64 -L/p/home/apps/gnu_compiler/7.2.0/lib64 -Wl,-rpath,/p/home/apps/gnu_compiler/7.2.0/lib -L/p/home/apps/gnu_compiler/7.2.0/lib -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
TEST checkFortranLinkingCxx from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1310)
TESTING: checkFortranLinkingCxx from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1310)
  Check that Fortran can link C++ libraries
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
Successful compile:
Source:
      program main
       call d1chk()
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O /p/work2/tmondrag/petsc-N5i8ny/config.compilers/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilers/cxxobj.o  /p/work2/tmondrag/petsc-N5i8ny/config.compilers/confc.o  -lstdc++ -ldl
          compilers: Fortran can link C++ functions
TEST setupFrameworkCompilers from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1455)
TESTING: setupFrameworkCompilers from config.compilers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilers.py:1455)
    child config.compilers 5.133946
TEST configureClosure from config.utilities.closure(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/closure.py:17)
TESTING: configureClosure from config.utilities.closure(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/closure.py:17)
  Determine if Apple ^close syntax is supported in C
                        All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure/conftest.c:6:6: error: expected identifier or ���(��� before ���^��� token
 int (^closure)(int);;
Source:
#include <stdio.h>
int main() {
  return 0;
              Compile failed inside link
    child config.utilities.closure 0.035873
TEST checkFortranTypeSizes from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:56)
TESTING: checkFortranTypeSizes from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:56)
  Check whether real*8 is supported and suggest flags which will allow support
                    All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90:2:21:
       real*8 variable
                     1
Warning: Unused variable ���variable��� declared at (1) [-Wunused-variable]
Source:
      program main
      real*8 variable
      end
TEST checkFortranPreprocessor from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:73)
TESTING: checkFortranPreprocessor from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:73)
  Determine if Fortran handles preprocessing properly
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O    /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
          compilers: Fortran uses  preprocessor
TEST checkFortranDefineCompilerOption from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:96)
TESTING: checkFortranDefineCompilerOption from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:96)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  -DTesting  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
            Defined make macro "FC_DEFINE_FLAG" to "-D"
          compilers: Fortran uses -D for defining macro
TEST checkFortran90 from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:146)
TESTING: checkFortran90 from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:146)
  Determine whether the Fortran compiler handles F90
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -lstdc++ -ldl
            Defined "USING_F90" to "1"
          Fortran compiler supports F90
TEST checkFortran90FreeForm from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:159)
TESTING: checkFortran90FreeForm from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:159)
  Determine whether the Fortran compiler handles F90FreeForm
       We also require that the compiler handles lines longer than 132 characters
Successful compile:
Source:
      program main
      INTEGER, PARAMETER ::        int = SELECTED_INT_KIND(8);              INTEGER (KIND=int) :: ierr;       ierr                            =        1
      end
            Defined "USING_F90FREEFORM" to "1"
          Fortran compiler supports F90FreeForm
TEST checkFortran2003 from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:173)
TESTING: checkFortran2003 from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:173)
  Determine whether the Fortran compiler handles F2003
Successful compile:
Source:
      module Base_module
        type, public :: base_type
           integer :: A
         contains
           procedure, public :: Print => BasePrint
        end type base_type
      contains
        subroutine BasePrint(this)
          class(base_type) :: this
        end subroutine BasePrint
      end module Base_module
      program main
      use,intrinsic :: iso_c_binding
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
            Defined "USING_F2003" to "1"
          Fortran compiler supports F2003
TEST checkFortran90Array from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:208)
TESTING: checkFortran90Array from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:208)
  Check for F90 array interfaces
Executing: mpif90 -V
          compilers: Using --with-batch, so guess that F90 uses a single argument for array pointers
TEST checkFortranModuleInclude from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:295)
TESTING: checkFortranModuleInclude from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:295)
  Figures out what flag is used to specify the include path for Fortran modules
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest   -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/configtest.o -lstdc++ -ldl
          compilers: Fortran module include flag -I found
TEST checkFortranModuleOutput from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:361)
TESTING: checkFortranModuleOutput from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:361)
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -module /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-module���; did you mean ���-mhle���?
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module  compile failed
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -module:/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-module:/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir���
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -module: compile failed
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -fmod=/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
stderr:
gfortran: error: unrecognized command line option ���-fmod=/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir���
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -fmod= compile failed
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -J/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/confdir  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran/conftest.F90
Successful compile:
Source:
      module configtest
      integer testint
          compilers: Fortran module output flag -J found
TEST checkFortranTypeStar from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:135)
TESTING: checkFortranTypeStar from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:135)
  Determine whether the Fortran compiler handles type(*)
Successful compile:
Source:
      program main
      interface
      subroutine a(b)
      type(*) :: b(:)
      end subroutine
      end interface
      end
            Defined "HAVE_FORTRAN_TYPE_STAR" to "1"
          Fortran compiler supports type(*)
TEST checkFortranTypeInitialize from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:125)
TESTING: checkFortranTypeInitialize from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:125)
  Determines if PETSc objects in Fortran are initialized by default (doesn't work with common blocks)
            Defined "FORTRAN_TYPE_INITIALIZE" to " = -2"
          Initializing Fortran objects
TEST configureFortranFlush from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:116)
TESTING: configureFortranFlush from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:116)
Successful compile:
Source:
      program main
      call flush(6)
      end
            Defined "HAVE_FORTRAN_FLUSH" to "1"
TEST checkDependencyGenerationFlag from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:406)
TESTING: checkDependencyGenerationFlag from config.compilersFortran(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/compilersFortran.py:406)
          Trying FC compiler flag -MMD -MP
            Defined make macro "FC_DEPFLAGS" to "-MMD -MP"
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  -MMD -MP  /p/work2/tmondrag/petsc-N5i8ny/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
    child config.compilersFortran 2.903161
TEST checkStdC from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:105)
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Preprocessing source:
#include <string.h>
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.headers  /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
#include <stdlib.h>
TEST checkStat from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
TEST checkSysWait from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
            Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
#include <time.h>
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
#include <sys/time.h>
              Defined "HAVE_SYS_TIME_H" to "1"
TEST checkMath from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:201)
TESTING: checkMath from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:201)
  Checks for the math headers and defines
Checking for header: math.h
#include <math.h>
Successful compile:
Source:
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
          Found math #defines, like M_PI
TEST check from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: setjmp.h
#include <setjmp.h>
            Defined "HAVE_SETJMP_H" to "1"
Checking for header: dos.h
#include <dos.h>
Possible ERROR while running preprocessor: exit code 1
stdout:
# 1 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/confdefs.h" 1
# 2 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c" 2
# 1 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conffix.h" 1
# 3 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c" 2
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory
 #include <dos.h>
compilation terminated.
Source:
#include <dos.h>
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory
 #include <dos.h>
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: dos.h: No such file or directory #include <dos.h>          ^~~~~~~compilation terminated.:
Checking for header: fcntl.h
#include <fcntl.h>
            Defined "HAVE_FCNTL_H" to "1"
Checking for header: float.h
#include <float.h>
            Defined "HAVE_FLOAT_H" to "1"
Checking for header: io.h
#include <io.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory
 #include <io.h>
Source:
#include <io.h>
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory
 #include <io.h>
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: io.h: No such file or directory #include <io.h>          ^~~~~~compilation terminated.:
Checking for header: malloc.h
#include <malloc.h>
            Defined "HAVE_MALLOC_H" to "1"
Checking for header: pwd.h
#include <pwd.h>
            Defined "HAVE_PWD_H" to "1"
Checking for header: strings.h
#include <strings.h>
            Defined "HAVE_STRINGS_H" to "1"
Checking for header: unistd.h
#include <unistd.h>
            Defined "HAVE_UNISTD_H" to "1"
Checking for header: sys/sysinfo.h
#include <sys/sysinfo.h>
            Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: machine/endian.h
#include <machine/endian.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: machine/endian.h: No such file or directory #include <machine/endian.h>          ^~~~~~~~~~~~~~~~~~compilation terminated.:
Checking for header: sys/param.h
#include <sys/param.h>
            Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: sys/procfs.h
#include <sys/procfs.h>
            Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
#include <sys/resource.h>
            Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: sys/systeminfo.h
#include <sys/systeminfo.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: sys/systeminfo.h: No such file or directory #include <sys/systeminfo.h>          ^~~~~~~~~~~~~~~~~~compilation terminated.:
Checking for header: sys/times.h
#include <sys/times.h>
            Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: sys/utsname.h
#include <sys/utsname.h>
            Defined "HAVE_SYS_UTSNAME_H" to "1"
Checking for header: sys/socket.h
#include <sys/socket.h>
            Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/wait.h
Checking for header: netinet/in.h
#include <netinet/in.h>
            Defined "HAVE_NETINET_IN_H" to "1"
Checking for header: netdb.h
#include <netdb.h>
            Defined "HAVE_NETDB_H" to "1"
Checking for header: Direct.h
#include <Direct.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory
 #include <Direct.h>
Source:
#include <Direct.h>
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory
 #include <Direct.h>
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: Direct.h: No such file or directory #include <Direct.h>          ^~~~~~~~~~compilation terminated.:
#include <time.h>
Checking for header: Ws2tcpip.h
#include <Ws2tcpip.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: Ws2tcpip.h: No such file or directory #include <Ws2tcpip.h>          ^~~~~~~~~~~~compilation terminated.:
Checking for header: sys/types.h
            Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: WindowsX.h
#include <WindowsX.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: WindowsX.h: No such file or directory #include <WindowsX.h>          ^~~~~~~~~~~~compilation terminated.:
#include <float.h>
Checking for header: ieeefp.h
#include <ieeefp.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
Source:
#include <ieeefp.h>
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory
 #include <ieeefp.h>
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: ieeefp.h: No such file or directory #include <ieeefp.h>          ^~~~~~~~~~compilation terminated.:
Checking for header: stdint.h
#include <stdint.h>
            Defined "HAVE_STDINT_H" to "1"
Checking for header: pthread.h
#include <pthread.h>
            Defined "HAVE_PTHREAD_H" to "1"
Checking for header: inttypes.h
#include <inttypes.h>
            Defined "HAVE_INTTYPES_H" to "1"
Checking for header: immintrin.h
#include <immintrin.h>
            Defined "HAVE_IMMINTRIN_H" to "1"
Checking for header: zmmintrin.h
#include <zmmintrin.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: zmmintrin.h: No such file or directory #include <zmmintrin.h>          ^~~~~~~~~~~~~compilation terminated.:
#include <setjmp.h>
#include <dos.h>
stdout:
# 1 "<built-in>"
stderr:
 #include <dos.h>
Source:
#include <dos.h>
 #include <dos.h>
#include <fcntl.h>
#include <float.h>
#include <io.h>
stdout:
# 1 "<built-in>"
stderr:
 #include <io.h>
Source:
#include <io.h>
 #include <io.h>
#include <malloc.h>
#include <pwd.h>
#include <unistd.h>
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
Source:
#include <netdb.h>
#include <Direct.h>
stdout:
# 1 "<built-in>"
stderr:
 #include <Direct.h>
Source:
#include <Direct.h>
 #include <Direct.h>
#include <time.h>
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
Source:
#include <float.h>
#include <ieeefp.h>
stdout:
# 1 "<built-in>"
stderr:
 #include <ieeefp.h>
Source:
#include <ieeefp.h>
 #include <ieeefp.h>
#include <stdint.h>
stdout:
# 1 "<built-in>"
stderr:
Source:
TEST checkRecursiveMacros from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:216)
TESTING: checkRecursiveMacros from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:216)
  Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Successful compile:
Source:
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
  return 0;
    child config.headers 2.168840
TEST configureCacheDetails from config.utilities.cacheDetails(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
  Try to determine the size and associativity of the cache.
                        All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
  return 0;
Skipping determination of LEVEL1_DCACHE_LINESIZE in batch mode, using default 32
            Defined "LEVEL1_DCACHE_LINESIZE" to "32"
    child config.utilities.cacheDetails 0.053318
TEST check_struct_sigaction from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:43)
TESTING: check_struct_sigaction from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:43)
  Checks if "struct sigaction" exists in signal.h. This check is for C89 check.
Checking for type: struct sigaction
                        All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.types
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c
Possible ERROR while running compiler:
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:11:18: warning: unused variable ���a��� [-Wunused-variable]
 struct sigaction a;;
Source:
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
int main() {
  return 0;
struct sigaction found
            Defined "HAVE_STRUCT_SIGACTION" to "1"
TEST check__int64 from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:49)
TESTING: check__int64 from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:49)
  Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Possible ERROR while running compiler: exit code 1
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:11:1: error: unknown type name ���__int64���; did you mean ���__int64_t���?
 __int64 a;;
 __int64_t
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:11:9: warning: unused variable ���a��� [-Wunused-variable]
 __int64 a;;
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
__int64 a;;
  return 0;
__int64 found
TEST checkSizeTypes from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:55)
TESTING: checkSizeTypes from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:55)
  Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:11:8: warning: unused variable ���a��� [-Wunused-variable]
 size_t a;;
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
size_t a;;
  return 0;
size_t found
TEST checkFileTypes from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:65)
TESTING: checkFileTypes from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:65)
  Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
 mode_t a;;
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
mode_t a;;
  return 0;
mode_t found
Checking for type: off_t
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:11:7: warning: unused variable ���a��� [-Wunused-variable]
 off_t a;;
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
off_t a;;
  return 0;
off_t found
TEST checkIntegerTypes from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:60)
TESTING: checkIntegerTypes from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:60)
  Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
 int32_t a;;
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
int32_t a;;
  return 0;
int32_t found
TEST checkPID from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:71)
TESTING: checkPID from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:71)
  Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
 pid_t a;;
Source:
#include <stdlib.h>
#include <stddef.h>
int main() {
pid_t a;;
  return 0;
pid_t found
TEST checkUID from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:75)
TESTING: checkUID from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:75)
  Checks for uid_t and gid_t, and defines them if necessary
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.types  /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c
TEST checkC99Complex from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:82)
TESTING: checkC99Complex from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:82)
  Check for complex numbers in in C99 std
       Note that since PETSc source code uses _Complex we test specifically for that, not complex
Running Executable WITHOUT threads to time it out
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:6:17: warning: variable ���x��� set but not used [-Wunused-but-set-variable]
 double _Complex x;
Source:
#include <complex.h>
int main() {
double _Complex x;
 x = I;
  return 0;
stderr:
 double _Complex x;
Source:
int main() {
double _Complex x;
 x = I;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.o -lstdc++ -ldl
            Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:93)
TESTING: checkCxxComplex from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:93)
  Check for complex numbers in namespace std
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  -fPIC   /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.o -lstdc++ -ldl
            Defined "HAVE_CXX_COMPLEX" to "1"
TEST checkFortranKind from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:114)
TESTING: checkFortranKind from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:114)
  Checks whether selected_int_kind etc work USE_FORTRANKIND
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.F90
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.F90:4:43:
         real(kind=selected_real_kind(10)) d
                                           1
Warning: Unused variable ���d��� declared at (1) [-Wunused-variable]
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.F90:3:45:
         integer(kind=selected_int_kind(10)) i
                                             1
Warning: Unused variable ���i��� declared at (1) [-Wunused-variable]
Source:
      program main
      end
            Defined "USE_FORTRANKIND" to "1"
TEST checkConst from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:126)
TESTING: checkConst from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:126)
  Checks for working const, and if not found defines it to empty string
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:25:5: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
     if (x[0]);
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:26:5: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
     { /* SCO 3.2v4 cc rejects this.  */
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:25:10: warning: ���x[0]��� is used uninitialized in this function [-Wuninitialized]
     if (x[0]);
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:30:9: warning: ���t��� is used uninitialized in this function [-Wuninitialized]
       *t++ = 0;
/p/work2/tmondrag/petsc-N5i8ny/config.types/conftest.c:46:25: warning: ���b��� is used uninitialized in this function [-Wuninitialized]
       struct s *b; b->j = 5;
Source:
int main() {
    /* Ultrix mips cc rejects this.  */
    typedef int charset[2]; const charset x;
    /* SunOS 4.1.1 cc rejects this.  */
    char const *const *ccp;
    char **p;
    /* NEC SVR4.0.2 mips cc rejects this.  */
    struct point {int x, y;};
    static struct point const zero = {0,0};
    /* AIX XL C 1.02.0.0 rejects this.
    It does not let you subtract one const X* pointer from another in an arm
    of an if-expression whose if-part is not a constant expression */
    const char *g = "string";
    ccp = &g + (g ? g-g : 0);
    /* HPUX 7.0 cc rejects these. */
    ++ccp;
    p = (char**) ccp;
    ccp = (char const *const *) p;
    /* This section avoids unused variable warnings */
    if (zero.x);
    if (x[0]);
      char *t;
      char const *s = 0 ? (char *) 0 : (char const *) 0;
      *t++ = 0;
      if (*s);
    { /* Someone thinks the Sun supposedly-ANSI compiler will reject this.  */
      int x[] = {25, 17};
      const int *foo = &x[0];
      ++foo;
    { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
      typedef const int *iptr;
      iptr p = 0;
      ++p;
    { /* AIX XL C 1.02.0.0 rejects this saying
      "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
      struct s { int j; const int *ap[3]; };
    { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
      const int foo = 10;
      /* Get rid of unused variable warning */
      if (foo);
  return 0;
TEST checkSizeof from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:182)
TESTING: checkSizeof from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:182)
  Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: short
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(short)==2)*2-1];
            Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(int)==4)*2-1];
            Defined "SIZEOF_INT" to "4"
Checking for size of type: enum
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(enum{ENUM_DUMMY})==4)*2-1];
            Defined "SIZEOF_ENUM" to "4"
Checking for size of type: long
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(long)==8)*2-1];
            Defined "SIZEOF_LONG" to "8"
Checking for size of type: void *
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(void *)==8)*2-1];
            Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: long long
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(long long)==8)*2-1];
            Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: size_t
Successful compile:
Source:
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
char assert_sizeof[(sizeof(size_t)==8)*2-1];
            Defined "SIZEOF_SIZE_T" to "8"
TEST checkVisibility from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:216)
TESTING: checkVisibility from config.types(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/types.py:216)
Successful compile:
Source:
int main() {
__attribute__((visibility ("default"))) int foo(void);;
  return 0;
            Defined "USE_VISIBILITY_C" to "1"
Successful compile:
Source:
int main() {
  return 0;
            Defined "USE_VISIBILITY_CXX" to "1"
    child config.types 1.678735
TEST configureMemAlign from PETSc.options.memAlign(/p/work2/tmondrag/moose/petsc/config/PETSc/options/memAlign.py:29)
TESTING: configureMemAlign from PETSc.options.memAlign(/p/work2/tmondrag/moose/petsc/config/PETSc/options/memAlign.py:29)
  Choose alignment
            Defined "MEMALIGN" to "16"
          Memory alignment is 16
    child PETSc.options.memAlign 0.001174
TEST check from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:157)
TESTING: check from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:157)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
            Checking for functions [handle_sigfpes] in library ['fpe'] []
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -lfpe -lstdc++ -ldl
stderr:
/usr/bin/ld: cannot find -lfpe
            Checking for functions [socket] in library ['socket', 'nsl'] []
Successful compile:
Source:
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -lsocket -lnsl -lstdc++ -ldl
stderr:
/usr/bin/ld: cannot find -lsocket
Successful compile:
Source:
int main() {
  return 0;
stderr:
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
  return 0;
stderr:
TEST checkMath from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:264)
TESTING: checkMath from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:264)
  Check for sin() in libm, the math library
            Checking for functions [sin floor log10 pow] in library [''] []
Successful compile:
Source:
#include <stdio.h>
double sin(double);
static void _check_sin() { double x,y; scanf("%lf",&x); y = sin(x); printf("%f",y);
#include <stdio.h>
double floor(double);
static void _check_floor() { double x,y; scanf("%lf",&x); y = floor(x); printf("%f",y);
#include <stdio.h>
double log10(double);
static void _check_log10() { double x,y; scanf("%lf",&x); y = log10(x); printf("%f",y);
#include <stdio.h>
double pow(double, double);
static void _check_pow() { double x,y; scanf("%lf",&x); y = pow(x,x); printf("%f",y);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o   -lstdc++ -ldl
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o: undefined reference to symbol 'log10@@GLIBC_2.2.5'
/usr/bin/ld: /lib64/libm.so.6: error adding symbols: DSO missing from command line
            Checking for functions [sin floor log10 pow] in library ['m'] []
Successful compile:
Source:
#include <stdio.h>
double sin(double);
#include <stdio.h>
#include <stdio.h>
#include <stdio.h>
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -lm -lstdc++ -ldl
              Defined "HAVE_LIBM" to "1"
          CheckMath: using math library ['libm.a']
TEST checkMathErf from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:283)
TESTING: checkMathErf from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:283)
  Check for erf() in libm, the math library
            Checking for functions [erf] in library ['libm.a'] []
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c: In function ���_check_erf���:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5:74: warning: variable ���y��� set but not used [-Wunused-but-set-variable]
 static void _check_erf() { double (*checkErf)(double) = erf;double x = 0,y; y = (*checkErf)(x); }
Source:
#include <math.h>
int main() {
_check_erf();;
  return 0;
          erf() found
            Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:292)
TESTING: checkMathTgamma from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:292)
  Check for tgamma() in libm, the math library
            Checking for functions [tgamma] in library ['libm.a'] []
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c: In function ���_check_tgamma���:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5:83: warning: variable ���y��� set but not used [-Wunused-but-set-variable]
 static void _check_tgamma() { double (*checkTgamma)(double) = tgamma;double x = 0,y; y = (*checkTgamma)(x); }
Source:
#include <math.h>
int main() {
_check_tgamma();;
  return 0;
          tgamma() found
            Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:301)
TESTING: checkMathFenv from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:301)
  Checks if <fenv.h> can be used with FE_DFL_ENV
            Checking for functions [fesetenv] in library ['libm.a'] []
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
  return 0;
            Defined "HAVE_FENV_H" to "1"
TEST checkMathLog2 from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:309)
TESTING: checkMathLog2 from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:309)
  Check for log2() in libm, the math library
            Checking for functions [log2] in library ['libm.a'] []
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c: In function ���_check_log2���:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5:81: warning: unused variable ���y��� [-Wunused-variable]
 static void _check_log2() { double (*checkLog2)(double) = log2; double x = 2.5, y = (*checkLog2)(x); }
Source:
#include <math.h>
int main() {
_check_log2();;
  return 0;
          log2() found
            Defined "HAVE_LOG2" to "1"
TEST checkRealtime from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:318)
TESTING: checkRealtime from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:318)
  Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
            Checking for functions [clock_gettime] in library [''] []
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
  return 0;
          realtime functions are linked in by default
TEST checkDynamic from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:334)
TESTING: checkDynamic from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:334)
  Check for the header and libraries necessary for dynamic library manipulation
            Checking for functions [dlopen] in library ['dl'] []
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -ldl -lstdc++ -ldl
              Defined "HAVE_LIBDL" to "1"
Checking for header: dlfcn.h
#include <dlfcn.h>
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.headers  /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
              Defined "HAVE_DLFCN_H" to "1"
    child config.libraries 1.576837
TEST configureLibraryOptions from PETSc.options.libraryOptions(/p/work2/tmondrag/moose/petsc/config/PETSc/options/libraryOptions.py:37)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(/p/work2/tmondrag/moose/petsc/config/PETSc/options/libraryOptions.py:37)
  Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE, PETSC_USE_FORTRAN_KERNELS, and PETSC_USE_AVX512_KERNELS
            Defined "USE_LOG" to "1"
Executing: mpicc -qversion
            Defined "USE_MALLOC_COALESCED" to "1"
            Defined "USE_INFO" to "1"
            Defined "USE_CTABLE" to "1"
            Defined "USE_BACKWARD_LOOP" to "1"
            **********Checking if running on BGL/IBM detected
              Checking for functions [bgl_perfctr_void] in library [''] []
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
  return 0;
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o: in function `_check_bgl_perfctr_void':
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5: undefined reference to `bgl_perfctr_void'
              Checking for functions [ADIOI_BGL_Open] in library [''] []
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
  return 0;
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o: in function `_check_ADIOI_BGL_Open':
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5: undefined reference to `ADIOI_BGL_Open'
            *********BGL/IBM test failure
            Defined "USE_AVX512_KERNELS" to "1"
            Defined "Alignx(a,b)" to "  "
TEST configureISColorValueType from PETSc.options.libraryOptions(/p/work2/tmondrag/moose/petsc/config/PETSc/options/libraryOptions.py:95)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(/p/work2/tmondrag/moose/petsc/config/PETSc/options/libraryOptions.py:95)
  Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
            Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
            Defined "IS_COLORING_MAX" to "USHRT_MAX"
            Defined "IS_COLOR_VALUE_TYPE" to "short"
            Defined "IS_COLOR_VALUE_TYPE_F" to "integer2"
    child PETSc.options.libraryOptions 0.305376
    child config.atomics 0.000011
TEST checkSysinfo from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:106)
TESTING: checkSysinfo from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:106)
  Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
                          All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.functions
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.types  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.o -lstdc++ -ldl
              Defined "HAVE_SYSINFO" to "1"
stdout:
# 1 "<built-in>"
stderr:
Source:
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:9:4: error: #error "Cannot check sysinfo without special headers"
 #  error "Cannot check sysinfo without special headers"
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:13:30: warning: implicit declaration of function ���sysinfo��� [-Wimplicit-function-declaration]
 char buf[10]; long count=10; sysinfo(1, buf, count);
Source:
#ifdef HAVE_SYS_SYSINFO_H
#  include <sys/sysinfo.h>
#elif defined(HAVE_SYS_SYSTEMINFO_H)
#  include <sys/systeminfo.h>
#else
#endif
int main() {
  return 0;
TEST checkVPrintf from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:125)
TESTING: checkVPrintf from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:125)
  Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vprintf( "%d", Argp );
  return 0;
TEST checkVFPrintf from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:131)
TESTING: checkVFPrintf from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:131)
  Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
vfprintf(stdout, "%d", Argp );
  return 0;
TEST checkVSNPrintf from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:137)
TESTING: checkVSNPrintf from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:137)
  Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Successful compile:
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
vsnprintf(str,5, "%d", Argp );
  return 0;
            Defined "HAVE_VSNPRINTF" to "1"
TEST checkNanosleep from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:167)
TESTING: checkNanosleep from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:167)
  Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
 tp.tv_sec = 0;
 tp.tv_nsec = (long)(1e9);
 nanosleep(&tp,0);
  return 0;
            Defined "HAVE_NANOSLEEP" to "1"
TEST checkMemmove from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:173)
TESTING: checkMemmove from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:173)
  Check for functional memmove() - as MS VC requires correct includes to for this test
Successful compile:
Source:
#include <string.h>
int main() {
 char c1[1], c2[1] = "c";
 size_t n=1;
 memmove(c1,c2,n);
  return 0;
            Defined "HAVE_MEMMOVE" to "1"
TEST checkSignalHandlerType from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:143)
TESTING: checkSignalHandlerType from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:143)
  Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.types  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  -fPIC   /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.o -lstdc++ -ldl
            Defined "SIGNAL_CAST" to " "
TEST checkFreeReturnType from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:153)
TESTING: checkFreeReturnType from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:153)
  Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
 int ierr; void *p; ierr = free(p); return 0;
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:6:5: warning: variable ���ierr��� set but not used [-Wunused-but-set-variable]
Source:
#include <stdlib.h>
int main() {
  return 0;
TEST checkVariableArgumentLists from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:159)
TESTING: checkVariableArgumentLists from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:159)
  Checks whether the variable argument list functionality is working
Successful compile:
Source:
#include <stdarg.h>
int main() {
  va_list l1, l2;
  va_copy(l1, l2);
  return 0;
  return 0;
            Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:85)
TESTING: checkClassify from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:85)
  Recursive decompose to rapidly classify functions as found or missing
    To confirm that a function is missing, we require a compile/link
    failure with only that function in a compilation unit.  In contrast,
    we can confirm that many functions are present by compiling them all
    together in a large compilation unit.  We optimistically compile
    everything together, then trim all functions that were named in the
    error message and bisect the result.  The trimming is only an
    optimization to increase the likelihood of a big-batch compile
    succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _access snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _sleep lseek usleep dlclose gethostname clock access _snprintf dlerror fork getpagesize sbreak memalign getcwd gethostbyname readlink _set_output_format PXFGETARG strcasecmp dlopen drand48 socket popen getrusage _mkdir time stricmp]
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:16:6: warning: conflicting types for built-in function ���snprintf��� [-Wbuiltin-declaration-mismatch]
 char snprintf();
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:19:6: warning: conflicting types for built-in function ���bzero��� [-Wbuiltin-declaration-mismatch]
 char bzero();
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:34:6: warning: conflicting types for built-in function ���fork��� [-Wbuiltin-declaration-mismatch]
 char fork();
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:43:6: warning: conflicting types for built-in function ���strcasecmp��� [-Wbuiltin-declaration-mismatch]
 char strcasecmp();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _access();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _sleep();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char access();
char _snprintf();
char dlerror();
char fork();
char getpagesize();
char sbreak();
char memalign();
char getcwd();
char gethostbyname();
char readlink();
char _set_output_format();
char PXFGETARG();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char popen();
char getrusage();
char _mkdir();
char time();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
snprintf_will_always_fail_with_ENOSYS();
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
sleep_will_always_fail_with_ENOSYS();
#else
sleep();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub__mkdir) || defined (__stub____mkdir)
_mkdir_will_always_fail_with_ENOSYS();
#else
_mkdir();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
  return 0;
Possible ERROR while running linker: exit code 1
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.o: in function `main':
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:110: warning: the `getwd' function is dangerous and should not be used.
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:74: undefined reference to `_access'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:104: undefined reference to `_getcwd'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:122: undefined reference to `_lseek'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:134: undefined reference to `_sleep'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:176: undefined reference to `_snprintf'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:200: undefined reference to `sbreak'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:230: undefined reference to `_set_output_format'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:236: undefined reference to `PXFGETARG'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:278: undefined reference to `_mkdir'
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:290: undefined reference to `stricmp'
collect2: error: ld returned 1 exit status
Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock dlerror]
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:17:6: warning: conflicting types for built-in function ���bzero��� [-Wbuiltin-declaration-mismatch]
 char bzero();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char dlerror();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
dlerror();
#endif
  return 0;
                    Defined "HAVE_RAND" to "1"
                    Defined "HAVE_GETDOMAINNAME" to "1"
                    Defined "HAVE_REALPATH" to "1"
                    Defined "HAVE_DLSYM" to "1"
                    Defined "HAVE_BZERO" to "1"
                    Defined "HAVE_UNAME" to "1"
                    Defined "HAVE_USLEEP" to "1"
                    Defined "HAVE_DLCLOSE" to "1"
                    Defined "HAVE_GETHOSTNAME" to "1"
                    Defined "HAVE_CLOCK" to "1"
                    Defined "HAVE_DLERROR" to "1"
Checking for functions [fork getpagesize memalign gethostbyname readlink strcasecmp dlopen drand48 socket popen getrusage time]
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���fork��� [-Wbuiltin-declaration-mismatch]
 char fork();
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:18:6: warning: conflicting types for built-in function ���strcasecmp��� [-Wbuiltin-declaration-mismatch]
 char strcasecmp();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char fork();
char getpagesize();
char memalign();
char readlink();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char popen();
char getrusage();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
fork();
#endif
#else
getpagesize();
#endif
#else
memalign();
#endif
#else
gethostbyname();
#endif
#else
readlink();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
time();
#endif
  return 0;
                    Defined "HAVE_FORK" to "1"
                    Defined "HAVE_GETPAGESIZE" to "1"
                    Defined "HAVE_MEMALIGN" to "1"
                    Defined "HAVE_GETHOSTBYNAME" to "1"
                    Defined "HAVE_READLINK" to "1"
                    Defined "HAVE_STRCASECMP" to "1"
                    Defined "HAVE_DLOPEN" to "1"
                    Defined "HAVE_DRAND48" to "1"
                    Defined "HAVE_SOCKET" to "1"
                    Defined "HAVE_POPEN" to "1"
                    Defined "HAVE_GETRUSAGE" to "1"
                    Defined "HAVE_TIME" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_access'
Checking for functions [snprintf]
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:13:6: warning: conflicting types for built-in function ���snprintf��� [-Wbuiltin-declaration-mismatch]
 char snprintf();
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
  return 0;
                    Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_getcwd'
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: warning: the `getwd' function is dangerous and should not be used.
                    Defined "HAVE_GETWD" to "1"
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
  return 0;
                    Defined "HAVE_SLEEP" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_sleep'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
  return 0;
                    Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
  return 0;
                    Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
  return 0;
                    Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_set_output_format'
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `PXFGETARG'
Checking for functions [_mkdir]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _mkdir();
#ifdef __cplusplus
#endif
int main() {
#else
_mkdir();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `_mkdir'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.functions/conftest.c:24: undefined reference to `stricmp'
TEST checkMmap from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:179)
TESTING: checkMmap from config.functions(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/functions.py:179)
  Check for functional mmap() to allocate shared memory and define HAVE_MMAP
Successful compile:
Source:
#include <sys/mman.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
int main() {
int fd;
 fd=open("/tmp/file",O_RDWR);
 mmap((void*)0,100,PROT_READ|PROT_WRITE,MAP_SHARED,fd,0);
  return 0;
            Defined "HAVE_MMAP" to "1"
    child config.functions 4.459111
TEST configureMemorySize from config.utilities.getResidentSetSize(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
  Try to determine how to measure the memory usage
    child config.utilities.getResidentSetSize 0.000504
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
  Check for the mechanism to retrieve command line arguments in Fortran
            Checking for functions [] in library [''] []
Executing: mpif90 -c -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilersFortran -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.F90
Successful compile:
Source:
      program main
      integer i
      character*(80) arg
       i = command_argument_count()
       call get_command_argument(i,arg)
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o   -lstdc++ -ldl
            Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
    child config.utilities.fortranCommandLine 0.185642
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
  Checks if certain feature test macros are support
                      All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/config.functions  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros/conftest.c:4:10: fatal error: sysctl.h: No such file or directory
 #include <sysctl.h>
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
  return 0;
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros/conftest.c
Successful compile:
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
  return 0;
            Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
  return 0;
            Defined "_GNU_SOURCE" to "1"
    child config.utilities.featureTestMacros 0.210373
TEST configureMissingUtypeTypedefs from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:55)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:55)
   Checks if u_short is undefined
                      All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.c:6:9: warning: unused variable ���foo��� [-Wunused-variable]
 u_short foo;
Source:
int main() {
u_short foo;
  return 0;
TEST configureMissingFunctions from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:61)
TESTING: configureMissingFunctions from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:61)
  Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:79)
TESTING: configureMissingSignals from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:79)
  Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
  return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
  return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:96)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:96)
Successful compile:
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#if !defined(_GNU_SOURCE)
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
  return 0;
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  -fPIC   /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.cc
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing/conftest.o -lstdc++ -ldl
TEST configureMissingSrandPrototype from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:121)
TESTING: configureMissingSrandPrototype from config.utilities.missing(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/missing.py:121)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
  return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
int main() {
long int seed=10;
srand48_ptr(seed);
  return 0;
    child config.utilities.missing 1.579093
TEST configureFPTrap from config.utilities.FPTrap(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/utilities/FPTrap.py:27)
  Checking the handling of floating point traps
Checking for header: sigfpe.h
Preprocessing source:
#include <sigfpe.h>
Possible ERROR while running preprocessor: exit code 1
stdout:
# 1 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c"
# 1 "<built-in>"
# 1 "<command-line>"
# 31 "<command-line>"
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "<command-line>" 2
# 1 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/confdefs.h" 1
# 2 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c" 2
# 1 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conffix.h" 1
# 3 "/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c" 2
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory
 #include <sigfpe.h>
compilation terminated.
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory
 #include <sigfpe.h>
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: sigfpe.h: No such file or directory #include <sigfpe.h>          ^~~~~~~~~~compilation terminated.:
Checking for header: fpxcp.h
#include <fpxcp.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory
 #include <fpxcp.h>
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory
 #include <fpxcp.h>
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: fpxcp.h: No such file or directory #include <fpxcp.h>          ^~~~~~~~~compilation terminated.:
Checking for header: floatingpoint.h
#include <floatingpoint.h>
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: floatingpoint.h: No such file or directory #include <floatingpoint.h>          ^~~~~~~~~~~~~~~~~compilation terminated.:
    child config.utilities.FPTrap 0.058791
TEST configureScalarType from PETSc.options.scalarTypes(/p/work2/tmondrag/moose/petsc/config/PETSc/options/scalarTypes.py:40)
TESTING: configureScalarType from PETSc.options.scalarTypes(/p/work2/tmondrag/moose/petsc/config/PETSc/options/scalarTypes.py:40)
  Choose between real and complex numbers
          Scalar type is real
                        All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.c
Possible ERROR while running compiler:
stderr:
/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.c:6:21: warning: unused variable ���a��� [-Wunused-variable]
 double b = 2.0; int a = isnormal(b);
Source:
#include <math.h>
int main() {
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.o -lstdc++ -ldl
            Defined "HAVE_ISNORMAL" to "1"
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing -I/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes/conftest.c
stderr:
 double b = 2.0; int a = isnan(b);
Source:
#include <math.h>
int main() {
  return 0;
Running Executable WITHOUT threads to time it out
            Defined "HAVE_ISNAN" to "1"
stderr:
 double b = 2.0; int a = isinf(b);
Source:
#include <math.h>
int main() {
  return 0;
            Defined "HAVE_ISINF" to "1"
TEST configurePrecision from PETSc.options.scalarTypes(/p/work2/tmondrag/moose/petsc/config/PETSc/options/scalarTypes.py:81)
TESTING: configurePrecision from PETSc.options.scalarTypes(/p/work2/tmondrag/moose/petsc/config/PETSc/options/scalarTypes.py:81)
  Set the default real number precision for PETSc objects
Checking C compiler works with __float128
            Checking for functions [logq] in library ['quadmath'] []
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing -I/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c: In function ���_check_logq���:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5:43: warning: ���f��� is used uninitialized in this function [-Wuninitialized]
 static void _check_logq() { __float128 f; logq(f);; }
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5:40: note: ���f��� was declared here
Source:
#include <quadmath.h>
int main() {
_check_logq();;
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -lquadmath -lstdc++ -ldl
              Defined "HAVE_LIBQUADMATH" to "1"
C compiler with quadmath library
Checking Fortran works with quadmath library
            Checking for functions [     ] in library ['quadmath'] []
Successful compile:
Source:
      program main
      real*16 s,w; w = 2.0 ;s = cos(w)
      end
Executing: mpif90  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O  /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o  -lquadmath -lstdc++ -ldl
stderr:
Source:
int main() {
_check_logq();;
  return 0;
            Adding ['quadmath'] to LIBS
            Defined "HAVE_REAL___FLOAT128" to "1"
            Defined "USE_REAL_DOUBLE" to "1"
            Defined make macro "PETSC_SCALAR_SIZE" to "64"
          Precision is double
    child PETSc.options.scalarTypes 1.060660
TEST configureMkdir from config.programs(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/programs.py:22)
TESTING: configureMkdir from config.programs(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/programs.py:22)
  Make sure we can have mkdir automatically make intermediate directories
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/mkdir...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/mkdir...not found
Checking for program /usr/local/krb5/bin/mkdir...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/mkdir...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/mkdir...not found
Checking for program /opt/clmgr/sbin/mkdir...not found
Checking for program /opt/clmgr/bin/mkdir...not found
Checking for program /opt/sgi/sbin/mkdir...not found
Checking for program /opt/sgi/bin/mkdir...not found
Checking for program /usr/local/bin/mkdir...not found
Checking for program /usr/bin/mkdir...found
Executing: /usr/bin/mkdir -p .conftest/tmp
          Adding -p flag to /usr/bin/mkdir -p to automatically create directories
            Defined make macro "MKDIR" to "/usr/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/programs.py:44)
TESTING: configureAutoreconf from config.programs(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/programs.py:44)
  Check for autoreconf
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/autoreconf...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/autoreconf...not found
Checking for program /usr/local/krb5/bin/autoreconf...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/autoreconf...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/autoreconf...not found
Checking for program /opt/clmgr/sbin/autoreconf...not found
Checking for program /opt/clmgr/bin/autoreconf...not found
Checking for program /opt/sgi/sbin/autoreconf...not found
Checking for program /opt/sgi/bin/autoreconf...not found
Checking for program /usr/local/bin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
            All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.programs
Executing: ['/usr/bin/autoreconf']
          autoreconf test successful!
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/libtoolize...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/libtoolize...not found
Checking for program /usr/local/krb5/bin/libtoolize...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/libtoolize...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/libtoolize...not found
Checking for program /opt/clmgr/sbin/libtoolize...not found
Checking for program /opt/clmgr/bin/libtoolize...not found
Checking for program /opt/sgi/sbin/libtoolize...not found
Checking for program /opt/sgi/bin/libtoolize...not found
Checking for program /usr/local/bin/libtoolize...not found
Checking for program /usr/bin/libtoolize...found
TEST configurePrograms from config.programs(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/programs.py:71)
TESTING: configurePrograms from config.programs(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/programs.py:71)
  Check for the programs needed to build and run PETSc
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/sh...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/sh...not found
Checking for program /usr/local/krb5/bin/sh...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/sh...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/sh...not found
Checking for program /opt/clmgr/sbin/sh...not found
Checking for program /opt/clmgr/bin/sh...not found
Checking for program /opt/sgi/sbin/sh...not found
Checking for program /opt/sgi/bin/sh...not found
Checking for program /usr/local/bin/sh...not found
Checking for program /usr/bin/sh...found
              Defined make macro "SHELL" to "/usr/bin/sh"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/sed...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/sed...not found
Checking for program /usr/local/krb5/bin/sed...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/sed...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/sed...not found
Checking for program /opt/clmgr/sbin/sed...not found
Checking for program /opt/clmgr/bin/sed...not found
Checking for program /opt/sgi/sbin/sed...not found
Checking for program /opt/sgi/bin/sed...not found
Checking for program /usr/local/bin/sed...not found
Checking for program /usr/bin/sed...found
              Defined make macro "SED" to "/usr/bin/sed"
Executing: /usr/bin/sed -i s/sed/sd/g "/p/work2/tmondrag/petsc-N5i8ny/config.programs/sed1"
          Adding SEDINPLACE cmd: /usr/bin/sed -i
            Defined make macro "SEDINPLACE" to "/usr/bin/sed -i"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/mv...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/mv...not found
Checking for program /usr/local/krb5/bin/mv...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/mv...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/mv...not found
Checking for program /opt/clmgr/sbin/mv...not found
Checking for program /opt/clmgr/bin/mv...not found
Checking for program /opt/sgi/sbin/mv...not found
Checking for program /opt/sgi/bin/mv...not found
Checking for program /usr/local/bin/mv...not found
Checking for program /usr/bin/mv...found
              Defined make macro "MV" to "/usr/bin/mv"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/cp...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/cp...not found
Checking for program /usr/local/krb5/bin/cp...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/cp...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/cp...not found
Checking for program /opt/clmgr/sbin/cp...not found
Checking for program /opt/clmgr/bin/cp...not found
Checking for program /opt/sgi/sbin/cp...not found
Checking for program /opt/sgi/bin/cp...not found
Checking for program /usr/local/bin/cp...not found
Checking for program /usr/bin/cp...found
              Defined make macro "CP" to "/usr/bin/cp"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/grep...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/grep...not found
Checking for program /usr/local/krb5/bin/grep...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/grep...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/grep...not found
Checking for program /opt/clmgr/sbin/grep...not found
Checking for program /opt/clmgr/bin/grep...not found
Checking for program /opt/sgi/sbin/grep...not found
Checking for program /opt/sgi/bin/grep...not found
Checking for program /usr/local/bin/grep...not found
Checking for program /usr/bin/grep...found
              Defined make macro "GREP" to "/usr/bin/grep"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/rm...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/rm...not found
Checking for program /usr/local/krb5/bin/rm...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/rm...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/rm...not found
Checking for program /opt/clmgr/sbin/rm...not found
Checking for program /opt/clmgr/bin/rm...not found
Checking for program /opt/sgi/sbin/rm...not found
Checking for program /opt/sgi/bin/rm...not found
Checking for program /usr/local/bin/rm...not found
Checking for program /usr/bin/rm...found
              Defined make macro "RM" to "/usr/bin/rm -f"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/diff...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/diff...not found
Checking for program /usr/local/krb5/bin/diff...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/diff...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/diff...not found
Checking for program /opt/clmgr/sbin/diff...not found
Checking for program /opt/clmgr/bin/diff...not found
Checking for program /opt/sgi/sbin/diff...not found
Checking for program /opt/sgi/bin/diff...not found
Checking for program /usr/local/bin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/p/work2/tmondrag/petsc-N5i8ny/config.programs/diff1" "/p/work2/tmondrag/petsc-N5i8ny/config.programs/diff2"
            Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /p/home/tmondrag/WORK/moose/scripts/../petsc/lib/petsc/bin/win32fe/ps...not found
  Unable to find programs ['ps'] providing listing of each search directory to help debug
    Path provided in Python program
      Warning /usr/ucb is not a directory
      Warning /usr/usb is not a directory
    Path provided by --with-executables-search-path
      ['win32fe.exe', 'win32feutils.dll']
            Defined make macro "PYTHON" to "/usr/bin/python"
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/m4...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/m4...not found
Checking for program /usr/local/krb5/bin/m4...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/m4...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/m4...not found
Checking for program /opt/clmgr/sbin/m4...not found
Checking for program /opt/clmgr/bin/m4...not found
Checking for program /opt/sgi/sbin/m4...not found
Checking for program /opt/sgi/bin/m4...not found
Checking for program /usr/local/bin/m4...not found
Checking for program /usr/bin/m4...found
              Defined make macro "M4" to "/usr/bin/m4"
    child config.programs 1.683024
TEST configureMake from config.packages.make(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/make.py:87)
TESTING: configureMake from config.packages.make(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/make.py:87)
  Check Guesses for GNU make
Executing: gmake --version
stdout:
GNU Make 4.0
Built for x86_64-unknown-linux-gnu
Copyright (C) 1988-2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/gmake...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/gmake...not found
Checking for program /usr/local/krb5/bin/gmake...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/gmake...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/gmake...not found
Checking for program /opt/clmgr/sbin/gmake...not found
Checking for program /opt/clmgr/bin/gmake...not found
Checking for program /opt/sgi/sbin/gmake...not found
Checking for program /opt/sgi/bin/gmake...not found
Checking for program /usr/local/bin/gmake...not found
Checking for program /usr/bin/gmake...found
              Defined make macro "MAKE" to "/usr/bin/gmake"
TEST setupGNUMake from config.packages.make(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/make.py:121)
TESTING: setupGNUMake from config.packages.make(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/make.py:121)
  Setup other GNU make stuff
Executing: uname -s
stdout: Linux
Executing: uname -s
stdout: Linux
            Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
            Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
            Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
            Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
            Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/gmake  --print-directory"
            Defined make macro "OMAKE" to "/usr/bin/gmake  --no-print-directory"
            Defined make macro "MAKE_PAR_OUT_FLG" to "--output-sync=recurse"
TEST configureMakeNP from config.packages.make(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/make.py:168)
TESTING: configureMakeNP from config.packages.make(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/make.py:168)
  check no of cores on the build machine [perhaps to do make '-j ncores']
          module multiprocessing found 72 cores: using make_np = 42
            Defined make macro "MAKE_NP" to "42"
            Defined make macro "MAKE_TEST_NP" to "30"
            Defined make macro "MAKE_LOAD" to "104.8"
            Defined make macro "NPMAX" to "72"
    child config.packages.make 0.020709
TEST alternateConfigureLibrary from config.packages.OpenMPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
  Called if --with-packagename=0; does nothing by default
    child config.packages.OpenMPI 0.000827
Executing: uname -s
stdout: Linux
TEST alternateConfigureLibrary from config.packages.MPICH(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.MPICH(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.MPICH 0.004006
TEST checkDependencies from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:836)
TESTING: checkDependencies from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:836)
TEST configureLibrary from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:617)
TESTING: configureLibrary from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:617)
            Checking for a functional MPI
            Checking for library in Compiler specific search MPI: []
TEST check from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:157)
TESTING: check from config.libraries(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/libraries.py:157)
  Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
       - libDir may be a list of directories
       - libName may be a list of library names
                Checking for functions [MPI_Init MPI_Comm_create] in library [] []
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
  return 0;
            Checking for optional headers [] in Compiler specific search MPI: ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
TEST checkInclude from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files [] in ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Found header files [] in ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
            Checking for headers ['mpi.h'] in Compiler specific search MPI: ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Checking for header files ['mpi.h'] in ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
                  Checking include with compiler flags var CPPFLAGS ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
#include <mpi.h>
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.headers  -I/p/home/apps/hpe/mpt-2.19/include -I/p/home/apps/gnu_compiler/7.2.0/include /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['mpi.h'] in ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
TEST checkMPIDistro from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:478)
TESTING: checkMPIDistro from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:478)
  Determine if MPICH_NUMVERSION, OMPI_MAJOR_VERSION or MSMPI_VER exist in mpi.h
       Used for consistency checking of MPI installation at compile time
                          All intermediate test results are stored in /p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing -I/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c
Possible ERROR while running compiler: exit code 1
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:4:25: error: ���I_MPI_VERSION��� undeclared here (not in a function); did you mean ���MPI_VERSION���?
 const char *mpich_ver = I_MPI_VERSION;
                         MPI_VERSION
Source:
#include <mpi.h>
int main() {
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:4:17: error: ���I_MPI_NUMVERSION��� undeclared here (not in a function); did you mean ���MPI_SUBVERSION���?
 int mpich_ver = I_MPI_NUMVERSION;
                 MPI_SUBVERSION
Source:
#include <mpi.h>
int main() {
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:4:17: error: ���MVAPICH2_NUMVERSION��� undeclared here (not in a function); did you mean ���MPI_SUBVERSION���?
 int mpich_ver = MVAPICH2_NUMVERSION;
                 MPI_SUBVERSION
Source:
#include <mpi.h>
int main() {
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:4:17: error: ���MPICH_NUMVERSION��� undeclared here (not in a function); did you mean ���MPI_SUBVERSION���?
 int mpich_ver = MPICH_NUMVERSION;
                 MPI_SUBVERSION
Source:
#include <mpi.h>
int main() {
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:4:18: error: ���OMPI_MAJOR_VERSION��� undeclared here (not in a function); did you mean ���MPI_SUBVERSION���?
 int ompi_major = OMPI_MAJOR_VERSION;
                  MPI_SUBVERSION
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:5:18: error: ���OMPI_MINOR_VERSION��� undeclared here (not in a function); did you mean ���OMPI_MAJOR_VERSION���?
 int ompi_minor = OMPI_MINOR_VERSION;
                  OMPI_MAJOR_VERSION
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:6:20: error: ���OMPI_RELEASE_VERSION��� undeclared here (not in a function); did you mean ���OMPI_MINOR_VERSION���?
 int ompi_release = OMPI_RELEASE_VERSION;
                    OMPI_MINOR_VERSION
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
  return 0;
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:9:2: error: #error not MSMPI
 #error not MSMPI
Source:
#include <mpi.h>
#define xstr(s) str(s)
#define str(s) #s
#if defined(MSMPI_VER)
char msmpi_hex[] = xstr(MSMPI_VER);
#else
#error not MSMPI
#endif
int main() {
  return 0;
Executing: uname -s
stdout: Linux
TEST configureMPI2 from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:253)
TESTING: configureMPI2 from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:253)
  Check for functions added to the interface in MPI-2
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
  return 0;
Executing: mpicc  -o /p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest    -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.o  -lquadmath -lstdc++ -ldl
                Defined "HAVE_MPI_FINALIZED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
  return 0;
                Defined "HAVE_MPI_IN_PLACE" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
                                              if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
  return 0;
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
  return 0;
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
  return 0;
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Reduce_local(0, 0, 0, MPI_INT, MPI_SUM));;
  return 0;
                Defined "HAVE_MPI_REDUCE_LOCAL" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
char version[MPI_MAX_LIBRARY_VERSION_STRING];int verlen;if (MPI_Get_library_version(version,&verlen));
  return 0;
                Defined "HAVE_MPI_GET_LIBRARY_VERSION" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
int base[100]; MPI_Win win; if (MPI_Win_create(base,100,4,MPI_INFO_NULL,MPI_COMM_WORLD,&win));
  return 0;
                Defined "HAVE_MPI_WIN_CREATE" to "1"
                Defined "HAVE_MPI_ONE_SIDED" to "1"
TEST configureMPI3 from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:298)
TESTING: configureMPI3 from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:298)
  Check for functions added to the interface in MPI-3
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm scomm; MPI_Aint size=128; int disp_unit=8,*baseptr; MPI_Win win;
                       if (MPI_Comm_split_type(MPI_COMM_WORLD, MPI_COMM_TYPE_SHARED, 0, MPI_INFO_NULL, &scomm));
                       if (MPI_Win_allocate_shared(size,disp_unit,MPI_INFO_NULL,MPI_COMM_WORLD,&baseptr,&win));
                       if (MPI_Win_shared_query(win,0,&size,&disp_unit,&baseptr));
  return 0;
                Defined "HAVE_MPI_PROCESS_SHARED_MEMORY" to "1"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c: In function ���main���:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:7:24: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
                        if (MPI_Iscatter(&send,1,MPI_INT,&recv,1,MPI_INT,0,MPI_COMM_WORLD,&req));
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:8:25: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
                         if (MPI_Iscatterv(&send,counts,displs,MPI_INT,&recv,1,MPI_INT,0,MPI_COMM_WORLD,&req));
Source:
#include <mpi.h>
int main() {
int send=0,recv,counts[2]={1,1},displs[2]={1,2}; MPI_Request req;
                        if (MPI_Igather(&send,1,MPI_INT,&recv,1,MPI_INT,0,MPI_COMM_WORLD,&req));
                        if (MPI_Igatherv(&send,1,MPI_INT,&recv,counts,displs,MPI_INT,0,MPI_COMM_WORLD,&req));
                        if (MPI_Iallgather(&send,1,MPI_INT,&recv,1,MPI_INT,MPI_COMM_WORLD,&req));
                        if (MPI_Iallgatherv(&send,1,MPI_INT,&recv,counts,displs,MPI_INT,MPI_COMM_WORLD,&req));
                        if (MPI_Ialltoall(&send,1,MPI_INT,&recv,1,MPI_INT,MPI_COMM_WORLD,&req));
  return 0;
                Defined "HAVE_MPI_NONBLOCKING_COLLECTIVES" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm distcomm;
                       MPI_Request req;
                       if (MPI_Dist_graph_create_adjacent(MPI_COMM_WORLD,0,0,MPI_WEIGHTS_EMPTY,0,0,MPI_WEIGHTS_EMPTY,MPI_INFO_NULL,0,&distcomm));
                       if (MPI_Neighbor_alltoallv(0,0,0,MPI_INT,0,0,0,MPI_INT,distcomm));
                       if (MPI_Ineighbor_alltoallv(0,0,0,MPI_INT,0,0,0,MPI_INT,distcomm,&req));
  return 0;
                Defined "HAVE_MPI_NEIGHBORHOOD_COLLECTIVES" to "1"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:6:30: warning: ���win��� is used uninitialized in this function [-Wuninitialized]
 int ptr[1]; MPI_Win win; if (MPI_Get_accumulate(ptr,1,MPI_INT,ptr,1,MPI_INT,0,0,1,MPI_INT,MPI_SUM,win));
Source:
#include <mpi.h>
int main() {
  return 0;
                Defined "HAVE_MPI_GET_ACCUMULATE" to "1"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:6:47: warning: ���win��� is used uninitialized in this function [-Wuninitialized]
 int ptr[1]; MPI_Win win; MPI_Request req; if (MPI_Rget(ptr,1,MPI_INT,0,1,1,MPI_INT,win,&req));
Source:
#include <mpi.h>
int main() {
  return 0;
                Defined "HAVE_MPI_RGET" to "1"
TEST configureMPIEXEC from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:175)
TESTING: configureMPIEXEC from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:175)
  Checking for location of mpiexec
                Defined make macro "MPIEXEC" to "Not_appropriate_for_batch_systems_You_must_use_your_batch_system_to_submit_MPI_jobs_speak_with_your_local_sys_admin"
TEST configureMPITypes from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:345)
TESTING: configureMPITypes from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:345)
  Checking for MPI Datatype handles
Successful compile:
Source:
#include <stdlib.h>
#include <mpi.h>
int main() {
int size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_size(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
  return 0;
                      ***** WARNING: Cannot determine if MPI_LONG_DOUBLE works on your system
                      in batch-mode! Assuming it does work. Run with --known-mpi-long-double=0
                      if you know it does not work (very unlikely). Run with --known-mpi-long-double=1
                      to remove this warning message *****
                Defined "HAVE_MPI_LONG_DOUBLE" to "1"
Successful compile:
Source:
#include <stdlib.h>
#include <mpi.h>
int main() {
int size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_size(MPI_INT64_T, &size);
MPI_Finalize();
  return 0;
                      ***** WARNING: Cannot determine if MPI_INT64_T works on your system
                      in batch-mode! Assuming it does work. Run with --known-mpi-int64_t=0
                      if you know it does not work (very unlikely). Run with --known-mpi-int64_t=1
                Defined "HAVE_MPI_INT64_T" to "1"
Successful compile:
Source:
#include <stdlib.h>
#include <mpi.h>
int main() {
int size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_size(MPI_C_DOUBLE_COMPLEX, &size);
MPI_Finalize();
  return 0;
                      ***** WARNING: Cannot determine if MPI_C_DOUBLE_COMPLEX works on your system
                      in batch-mode! Assuming it does work. Run with --known-mpi-c-double-complex=0
                      if you know it does not work (very unlikely). Run with --known-mpi-c-double-complex=1
                Defined "HAVE_MPI_C_DOUBLE_COMPLEX" to "1"
TEST SGIMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:406)
TESTING: SGIMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:406)
  Returns true if SGI MPI is used
                Checking for functions [MPI_SGI_barrier] in library [] []
Executing: mpicc -c -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.closure -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.cacheDetails -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.featureTestMacros -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing -I/p/work2/tmondrag/petsc-N5i8ny/PETSc.options.scalarTypes -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O   /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c
Successful compile:
Source:
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
int main() {
_check_MPI_SGI_barrier();;
  return 0;
              SGI MPI detected - defining MISSING_SIGTERM
                Defined "MISSING_SIGTERM" to "1"
TEST CxxMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:416)
TESTING: CxxMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:416)
  Make sure C++ can compile and link
Checking for header mpi.h
Checking for C++ MPI_Finalize()
                Checking for functions [MPI_Finalize] in library [] []
Executing: mpicxx -c -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.compilers -I/p/work2/tmondrag/petsc-N5i8ny/config.functions -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.libraries -I/p/work2/tmondrag/petsc-N5i8ny/config.utilities.missing  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O  -fPIC    /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.cc
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.cc: In function ���void _check_MPI_Finalize()���:
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.cc:5:41: warning: variable ���ierr��� set but not used [-Wunused-but-set-variable]
 static void _check_MPI_Finalize() { int ierr;
Source:
#include <mpi.h>
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
  return 0;
Executing: mpicxx  -o /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest    -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o -lquadmath -lstdc++ -ldl
TEST FortranMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:432)
TESTING: FortranMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:432)
  Make sure fortran include [mpif.h] and library symbols are found
Checking for fortran mpi_init()
                Checking for functions [] in library [] []
stderr:
/p/home/apps/hpe/mpt-2.19/include/mpif.h:561:54:
         integer MPI_STATUSES_IGNORE(MPI_STATUS_SIZE,1)
                                                      1
Warning: Unused variable ���mpi_statuses_ignore��� declared at (1) [-Wunused-variable]
Source:
      program main
#include "mpif.h"
       integer ierr
       call mpi_init(ierr)
      end
Checking for mpi.mod
stderr:
f951: Fatal Error: Reading module ���mpi��� at line 1 column 2: Unexpected EOF
Source:
      program main
       use mpi
       integer ierr,rank
       call mpi_init(ierr)
       call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
      end
                    Compile failed inside link
TEST configureIO from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:454)
TESTING: configureIO from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:454)
  Check for the functions in MPI/IO
       - Define HAVE_MPIIO if they are present
       - Some older MPI 1 implementations are missing these
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:7:1: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
 if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:9:50: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
                                                  MPI_File fh;
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:12:1: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
 if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:14:50: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
                                                  if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:18:1: warning: this ���if��� clause does not guard... [-Wmisleading-indentation]
 if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:20:50: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ���if���
                                                  if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:12:5: warning: ���buf��� is used uninitialized in this function [-Wuninitialized]
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:18:5: warning: ���disp��� is used uninitialized in this function [-Wuninitialized]
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:18:5: warning: ���info��� is used uninitialized in this function [-Wuninitialized]
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
                                                 MPI_File fh;
void *buf;
MPI_Status status;
                                                 MPI_Offset disp;
MPI_Info info;
                                                 if (MPI_File_close(&fh));
  return 0;
                Defined "HAVE_MPIIO" to "1"
TEST findMPIInc from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:558)
TESTING: findMPIInc from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:558)
  Find MPI include paths from "mpicc -show" and use with CUDAC_FLAGS
TEST PetscArchMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:592)
TESTING: PetscArchMPICheck from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/MPI.py:592)
                  Checking for functions [MPI_Type_get_envelope MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan MPI_Reduce_scatter MPI_Reduce_scatter_block] in library [] []
Successful compile:
Source:
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
char MPI_Reduce_scatter();
static void _check_MPI_Reduce_scatter() { MPI_Reduce_scatter(); }
char MPI_Reduce_scatter_block();
static void _check_MPI_Reduce_scatter_block() { MPI_Reduce_scatter_block(); }
int main() {
_check_MPI_Type_get_envelope();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();
_check_MPI_Reduce_scatter();
_check_MPI_Reduce_scatter_block();;
  return 0;
            Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
            Defined "HAVE_MPI_TYPE_DUP" to "1"
            Defined "HAVE_MPI_INIT_THREAD" to "1"
            Defined "HAVE_MPI_IALLREDUCE" to "1"
            Defined "HAVE_MPI_IBARRIER" to "1"
            Defined "HAVE_MPI_EXSCAN" to "1"
            Defined "HAVE_MPI_REDUCE_SCATTER" to "1"
            Defined "HAVE_MPI_REDUCE_SCATTER_BLOCK" to "1"
            Checking for functions [MPIX_Iallreduce] in library [] []
Successful compile:
Source:
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
int main() {
_check_MPIX_Iallreduce();;
  return 0;
Possible ERROR while running linker: exit code 1
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o: in function `_check_MPIX_Iallreduce':
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5: undefined reference to `MPIX_Iallreduce'
collect2: error: ld returned 1 exit status
            Checking for functions [MPIX_Ibarrier] in library [] []
Successful compile:
Source:
char MPIX_Ibarrier();
static void _check_MPIX_Ibarrier() { MPIX_Ibarrier(); }
int main() {
_check_MPIX_Ibarrier();;
  return 0;
stderr:
/usr/bin/ld: /p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.o: in function `_check_MPIX_Ibarrier':
/p/work2/tmondrag/petsc-N5i8ny/config.libraries/conftest.c:5: undefined reference to `MPIX_Ibarrier'
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c:6:5: warning: unused variable ���combiner��� [-Wunused-variable]
 int combiner = MPI_COMBINER_DUP;;
Source:
#include <mpi.h>
int main() {
  return 0;
            Defined "HAVE_MPI_COMBINER_DUP" to "1"
stderr:
 int combiner = MPI_COMBINER_CONTIGUOUS;;
Source:
#include <mpi.h>
int main() {
  return 0;
            Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
stderr:
 int combiner = MPI_COMBINER_NAMED;;
Source:
#include <mpi.h>
int main() {
  return 0;
            Defined "HAVE_MPI_COMBINER_NAMED" to "1"
TEST checkVersion from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:986)
TESTING: checkVersion from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:986)
  Uses self.version, self.minversion, self.maxversion, self.versionname, and self.versioninclude to determine if package has required version
#include "mpi.h"
;petscpkgver(MPI_VERSION);
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.headers -I/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI    /p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI/conftest.c
For mpi need 2 <= 3 <=
TEST checkSharedLibrary from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:920)
TESTING: checkSharedLibrary from config.packages.MPI(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:920)
  By default we don't care about checking if the library is shared
    child config.packages.MPI 4.614358
TEST alternateConfigureLibrary from config.packages.zstd(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.zstd(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.zstd 0.001155
TEST alternateConfigureLibrary from config.packages.yaml(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.yaml(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.yaml 0.000965
TEST configureLibrary from config.packages.valgrind(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:861)
TESTING: configureLibrary from config.packages.valgrind(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:861)
  Find an installation and check if it can work with PETSc
          Checking for a functional valgrind
          Not checking for library in Compiler specific search VALGRIND: [] because no functions given to check for
              No functions to check for in library [] []
          Checking for optional headers [] in Compiler specific search VALGRIND: ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
          Checking for headers ['valgrind/valgrind.h'] in Compiler specific search VALGRIND: ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Checking for header files ['valgrind/valgrind.h'] in ['/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
#include <valgrind/valgrind.h>
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI -I/p/work2/tmondrag/petsc-N5i8ny/config.headers   -I/p/home/apps/hpe/mpt-2.19/include -I/p/home/apps/gnu_compiler/7.2.0/include /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
stdout:
# 1 "<built-in>"
stderr:
/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: valgrind/valgrind.h: No such file or directory
Source:
Preprocess stderr before filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: valgrind/valgrind.h: No such file or directory
Preprocess stderr after filtering:/p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c:3:10: fatal error: valgrind/valgrind.h: No such file or directory #include <valgrind/valgrind.h>          ^~~~~~~~~~~~~~~~~~~~~compilation terminated.:
          Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
          Checking for optional headers [] in Package specific search directory VALGRIND: ['/usr/local/include', '/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Checking for header files [] in ['/usr/local/include', '/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Found header files [] in ['/usr/local/include', '/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
          Checking for headers ['valgrind/valgrind.h'] in Package specific search directory VALGRIND: ['/usr/local/include', '/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include', '/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
                Checking include with compiler flags var CPPFLAGS ['/usr/local/include', '/p/home/apps/hpe/mpt-2.19/include', '/p/home/apps/gnu_compiler/7.2.0/include']
Executing: mpicc -E  -I/p/work2/tmondrag/petsc-N5i8ny/config.setCompilers -I/p/work2/tmondrag/petsc-N5i8ny/config.types -I/p/work2/tmondrag/petsc-N5i8ny/config.packages.MPI -I/p/work2/tmondrag/petsc-N5i8ny/config.headers   -I/usr/local/include -I/p/home/apps/hpe/mpt-2.19/include -I/p/home/apps/gnu_compiler/7.2.0/include /p/work2/tmondrag/petsc-N5i8ny/config.headers/conftest.c
stdout:
# 1 "<built-in>"
stderr:
Source:
stdout:
# 1 "<built-in>"
stderr:
Source:
            VALGRIND: SearchDir DirPath not found.. skipping: /opt/local
Executing: uname -s
stdout: Linux
              It appears you do not have valgrind installed on your system.
              We HIGHLY recommend you install it from www.valgrind.org
              Or install valgrind-devel or equivalent using your package manager.
              Then rerun ./configure
    child config.packages.valgrind 0.069498
TEST alternateConfigureLibrary from config.packages.ssl(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.ssl(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.ssl 0.001138
TEST alternateConfigureLibrary from config.packages.sprng(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.sprng(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.sprng 0.000956
      Not checking sowing on user request of --with-sowing=0
    child config.packages.sowing 0.000852
TEST alternateConfigureLibrary from config.packages.revolve(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.revolve(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.revolve 0.000961
TEST alternateConfigureLibrary from config.packages.radau5(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.radau5(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.radau5 0.000963
TEST alternateConfigureLibrary from config.packages.pami(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.pami(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.pami 0.000771
TEST alternateConfigureLibrary from config.packages.opengles(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.opengles(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.opengles 0.000786
TEST alternateConfigureLibrary from config.packages.opencl(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.opencl(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.opencl 0.000786
TEST alternateConfigureLibrary from config.packages.muparser(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.muparser(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.muparser 0.000952
        Defined "PYTHON_EXE" to ""/usr/bin/python""
Executing: /usr/bin/python -c "import Cython"
Executing: /usr/bin/python -c "import numpy"
    child config.packages.python 0.090408
TEST alternateConfigureLibrary from config.packages.petsc4py(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/petsc4py.py:97)
TESTING: alternateConfigureLibrary from config.packages.petsc4py(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/petsc4py.py:97)
            Defined make rule "petsc4py-build" with dependencies "" and code []
            Defined make rule "petsc4py-install" with dependencies "" and code []
    child config.packages.petsc4py 0.002105
TEST alternateConfigureLibrary from config.packages.mpi4py(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/mpi4py.py:74)
TESTING: alternateConfigureLibrary from config.packages.mpi4py(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/mpi4py.py:74)
            Defined make rule "mpi4py-build" with dependencies "" and code []
            Defined make rule "mpi4py-install" with dependencies "" and code []
    child config.packages.mpi4py 0.001805
TEST alternateConfigureLibrary from config.packages.mpe(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.mpe(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.mpe 0.001006
TEST alternateConfigureLibrary from config.packages.memkind(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.memkind(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.memkind 0.000817
TEST alternateConfigureLibrary from config.packages.libmesh(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/libmesh.py:76)
TESTING: alternateConfigureLibrary from config.packages.libmesh(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/libmesh.py:76)
            Defined make rule "libmesh-build" with dependencies "" and code []
            Defined make rule "libmesh-install" with dependencies "" and code []
    child config.packages.libmesh 0.001655
TEST alternateConfigureLibrary from config.packages.moose(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.moose(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.moose 0.000814
TEST alternateConfigureLibrary from config.packages.libjpeg(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.libjpeg(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.libjpeg 0.000966
TEST alternateConfigureLibrary from config.packages.libceed(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
TESTING: alternateConfigureLibrary from config.packages.libceed(/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/package.py:924)
    child config.packages.libceed 0.000926
Checking for program /app/unsupported/COST/git/2.4.4/gnu//bin/lgrind...not found
Checking for program /app/unsupported/COST/tcltk/8.6.4/gnu//bin/lgrind...not found
Checking for program /usr/local/krb5/bin/lgrind...not found
Checking for program /p/home/apps/hpe/mpt-2.19/bin/lgrind...not found
Checking for program /p/home/apps/gnu_compiler/7.2.0/bin/lgrind...not found
Checking for program /opt/clmgr/sbin/lgrind...not found
Checking for program /opt/clmgr/bin/lgrind...not found
Checking for program /opt/sgi/sbin/lgrind...not found
Checking for program /opt/sgi/bin/lgrind...not found
Checking for program /usr/local/bin/lgrind...not found
Checking for program /usr/bin/lgrind...not found
Checking for program /bin/lgrind...not found
Checking for program /usr/games/lgrind...not found
Checking for program /opt/c3/bin/lgrind...not found
Checking for program /opt/pbs/default/bin/lgrind...not found
Checking for program /sbin/lgrind...not found
Checking for program /pbs/SLB/lgrind...not found
Checking for program /app/unsupported/local/bin/lgrind...not found
Checking for program /app/mpiutil/lgrind...not found
Checking for program /p/home/tmondrag/WORK/moose/scripts/../petsc/lib/petsc/bin/win32fe/lgrind...not found
  Unable to find programs ['lgrind'] providing listing of each search directory to help debug
    Path provided by default path
      ['gitk', 'git-receive-pack', 'git-shell', 'git-cvsserver', 'git-upload-pack', 'git-upload-archive', 'git']
      ['wish', 'wish8.6', 'tclsh8.6', 'tclsh']
      Warning /usr/local/krb5/bin is not a directory
      ['mpiexec', 'mpt_query', 'mpirun', 'mpt_checkpoint', 'mpt_shepherd', 'mpicc', 'mpicxx', 'mpif77', 'mpif90', 'mpt_forward', 'mpt_bt', 'mpif08', 'oshrun', 'mpiexec_mpt', 'oshfort', 'oshcc', 'util', 'mpt_restart', 'rail-config', 'mpt_hugepage_config', 'omplace', 'oshCC']
      ['c++', 'gccgo', 'go', 'x86_64-pc-linux-gnu-gcc-nm', 'x86_64-pc-linux-gnu-gfortran', 'x86_64-pc-linux-gnu-gccgo', 'x86_64-pc-linux-gnu-gcc', 'x86_64-pc-linux-gnu-gcc-ranlib', 'g++', 'gfortran', 'cpp', 'gcc', 'gcc-ar', 'x86_64-pc-linux-gnu-gcc-7.2.0', 'x86_64-pc-linux-gnu-gcc-ar', 'x86_64-pc-linux-gnu-c++', 'gcc-nm', 'x86_64-pc-linux-gnu-g++', 'gofmt', 'gcov-tool', 'gcc-ranlib', 'gcov', 'gcov-dump']
      Warning /opt/clmgr/sbin is not a directory
      ['rpdcp', 'pdsh', 'pdcp', 'dshbak', 'cmu_stop_monitoring', 'cmu_start_monitoring', 'cmu_restart_monitoring', 'cmu_lock', 'cm', 'SmallMonitoringDaemon', 'SendUdpMessage', 'SecondaryServerMonitoringDaemon']
      ['tempohbc', 'cattr']
      ['cminfo']
      ['python-argcomplete-check-easy-install-script', 'sh', 'luac', 'rdoc.ruby2.1', 'jstatd', 'nstat', 'isoinfo', 'rmic', 'mkroot', 'rmiregistry', 'mailq', 'rpmverify', 'rdoc', 'isodebug', 'getconf', 'serialver', 'devdump', 'sip', 'rake.ruby2.1', 'db_sql', 'wsgen', 'javac', 'rake', 'db_hotbackup', 'isovfy', 'netcat', 'ri', 'native2ascii', 'ri.ruby2.1', 'orbd', 'jps', 'routef', 'ss', 'gem2rpm-0.10.1', 'extcheck', 'jstat', 'wsimport', 'pkill', 'vim', 'db_dump', 'unpack200', 'funzip', 'policytool', 'vi', 'javap', 'db_deadlock', 'ps', 'xjc', 'javadoc', 'tcsh', 'awk', 'newaliases', 'routel', 'lnstat', 'gtk-update-icon-cache', 'ld', 'appletviewer', 'dbus-send', 'java', 'keytool', 'db_archive', 'pgrep', 'ftp', 'lua', 'db_printlog', 'gem2rpm', 'unzipsfx', 'dbus-launch', 'iptables-xml', 'db_load', 'easy_install', 'javah', 'tnameserv', 'jar', 'rpmquery', 'unzip', 'db_checkpoint', 'jmap', 'gem2rpm.ruby2.1', 'db_stat', 'zipgrep', 'jarsigner', 'modulecmd', 'schemagen', 'ctags', 'csh', 'jinfo', 'jconsole', 'db_verify', 'ksh', 'jstack', 'db_upgrade', 'rbash', 'db_recover', 'SUSEConnect', 'jrunscript', 'pack200', 'jsadebugd', 'install-info', 'servertool', 'add.modules', 'jhat', 'rmid', 'isodump', 'jdb', 'envsubst', 'kbdrate', 'smidiff', 'manpath', 'snmpset', 'systemctl', 'xml_spellcheck', 'xargs', 'gouldtoppm', 'spawn_console', 'gccmakedep', 'snmpnetstat', 'cnf', 'id', 'lwp-dump', 'pnmshear', 'Signature_conversion', 'lessecho', 'sg_map', 'apropos', 'pbmto10x', 'pgmmake', 'ib_write_bw', 'openssl', 'gcc-nm-4.8', 'Backarrow2BackSpace', 'openvt', 'roff2html', 'pnmstitch', 'pre-grohtml', 'grub2-syslinux2cfg', 'systemd-run', 'c_rehash', 'aclocal-1.13', 'x86info', 'pcxtoppm', 'scsi_satl', 'fuk', 'geqn', 'mk_changelog', 'pamarith', 'ibv_asyncwatch', 'jpico', 'gdb-add-index', 'pdf2dsc', 'cmake', 'libnetcfg', 'systemd-analyze', 'luit', 'date', 'emacsclient', 'bno_plot.py', 'nl', 'snmptest', 'ibdmsh', 'resizecons', 'llobdstat', 'quota', 'exportCRL.pl', 'zypper', 'gtester', 'mev', 'gmetric', 'lpstat', 'yacc', 'gvfs-set-attribute', 'grub2-kbdcomp', 'setfattr', 'ssh-add', 'mdeltree', 'nc', '411toppm', 'gprof', 'yum-repoquery3', 'rxe_cfg', 'ppmtoneo', 'eject', 'w3m', 'lpr', 'pnmtotiff', 'ppmshift', 'env', 'mkdirhier', 'bzgrep', 'sgm_dd', 'svgtopam', 'who', 'systemd-cat', 'db48_load', 'clean-binary-files', 'ppmquantall', 'ypwhich', 'yzpper', 'lzcmp', 'slptool', 'mkfontdir', 'sun-to-mime', 'gvfs-rename', 'pwd', 'rpmqpack', 'patchwork', 'cpan2dist', 'unshare', 'gtk-launch', 'pax', 'xmbind', 'ftview', 'pbmpscale', 'munge', 'gpart', 'join', 'zegrep', 'pnmhisteq', 'gdcmpgif', 'skill', 'mkhybrid', 'tkcon', 'pcre-config', 'run_perftest_loopback', 'hexdump', 'setcifsacl', 'asn1Coding', 'circo', 'write', 'lua5.2', 'xdg-desktop-icon', 'jpegtopnm', 'rmdir', 'uniq', 'ldapexop', 'opensc-explorer', 'slabtop', 'pamsplit', 'db48_checkpoint', 'zip', 'qttracereplay', 'factor', 'pamaddnoise', 'ptx', 'opiegen', 'grops', 'unix-lpr.sh', 'pnmnoraw', 'perl5.18.2', 'ftdump', 'chmod', 'chkstat', 'roff2text', 'timed-read', 'tee', 'c2ph', 'lsusb', 'col', 'ps2epsi', 'pgmbentley', 'qmlviewer', 'gvgen', 'gstack', 'nroff', 'ppmchange', 'setmetamode', 'pbmtomrf', 'edit', 'pamfixtrunc', 'uil', 'grub2-mkrelpath', 'xpath', 'pdfmom', 'ppmtolj', 'pamscale', 'pnmcat', 'tgz', 'bmptoppm', 'mv', 'spax', 'ncursesw5-config', 'sg_read', 'chgrp', 'qrttoppm', 'autoscan', 'gtk3-icon-browser', 'lsdev', 'mmount', 'webtidy', 'grep', 'pgmtofs', 'fitstopnm', 'oggdec', 'ustar', 'wdctl', 'pamtooctaveimg', 'glib-compile-resources', 'ftp-rfc', 'pfbtops', 'automake-1.13', 'makedumpfile', 'kbd', 'ftvalid', 'rawtoppm', 'findmnt', 'rezip_repo_rsyncable', 'btt', 'grub2-mklayout', 'cdda2wav', 'gconf-merge-tree', 'smidump', 'jstar', 'grolbp', 'ulockmgr_server', 'pygobject-codegen-2.0', 'create-jar-links', 'db48_dump', 'time', 'pdf2ps', 'sg_copy_results', 'convertdb1', 'rescan-scsi-bus.sh', 'grub2-mount', 'perlivp', 'addr2line', 'pnmdepth', 'gpgsm', 'showkey', 'gunzip', 'zcat', 'snmpbulkwalk', 'pamstack', 'isolinux-config', 'stdbuf', 'repo2solv.sh', 'migspeed', 'sg_rdac', 'makeg', 'watchgnupg', 'setterm', 'xmllint', 'gd2copypal', 'regshell', 'lrelease', 'mclasserase', 'procinfo', 'autoconf', 'pdbimgtopam', 'net', 'gpgsm-gencert.sh', 'pbmclean', 'expr', 'snmp-bridge-mib', 'pbmtopi3', 'grotty', 'pbmtobbnbg', 'affixcompress', 'yppasswd', 'gvfs-mount', 'newgidmap', 'gvmap', 'wc', 'whoami', 'ibnlparse', 'appdata2solv', 'ppmwheel', 'tput', 'snmpwalk', 'ftgrid', 'iasecc-tool', 'ppmdmkfont', 'pammixinterlace', 'showaudio', 'ppmtobmp', 'linguist', 'nproc', 'esd', 'psresize', 'mdel', 'generateCRL.pl', 'gslp', 'fold', 'journalctl', 'ppmtoyuvsplit', 'pamtotiff', 'msgfmt', 'sun-message.csh', 'lfs', 'libyui-terminal', 'tail', 'top', 'pamtofits', 'dumpkeys', 'ppmdim', 'profiles', 'pbmtoicon', 'mstvpd', 'namei', 'broadwayd', 'cleanlinks', 'ppmtoilbm', 'ipf-mod.pl', 'lftpget', 'cameratopam', 'pnmmontage', 'sg_sat_set_features', 'gapplication', 'gvcolor', 'ri.ruby.ruby2.1', 'create_package_descr', 'xdg-email', 'sg_emc_trespass', 'regtree', 'pbmtoln03', 'ibv_rc_pingpong', 'lppasswd', 'lftp_wrapper', 'podselect', 'chattr', 'captoinfo', 'unxz', 'getfilename', 'mutt', 'ccomps', 'nodeattr', 'vcut', 'drpmsync', 'pbmtomgr', 'autom4te', 'pbmtox10bm', 'mailstat', 'pbmtoibm23xx', 'mknod', 'lfs_migrate', 'gvfs-open', 'spawn_login', 'mimecheck', 'mountpoint', 'psfxtable', 'gtk-demo', 'ppmrough', 'infokey', 'smbget', 'ppmcolors', 'ifnames', 'pnmtopnm', 'ldapcompare', 'delv', 'pygtk-codegen-2.0', 'perl', 'objcopy', 'fragiso', 'pnmtile', 'pnmtopclxl', 'lzcat', 'unmunch', 'pbmtoatk', 'grub2-script-check', 'moc', 'umount', 'cifsdd', 'testsaslauthd', 'qpaeq', 'moc-qt5', 'roff2ps', 'ex', 'psed', 'pbmtopsg3', 'memhog', 'comm', 'grn', 'smbcacls', 'sg_read_block_limits', 'chvt', 'ftmulti', 'bzcmp', 'eventlogadm', 'setfacl', 'pamtompfont', 'xz', 'lzegrep', 'gemtopbm', 'sg_ident', 'gettext.sh', 'ibv_ud_pingpong', 'config_data', 'rdate', 'scdaemon', 'ipmi_sim', 'gcr-viewer', 'inf2cdtext.pl', 'vimdiff', 'testrb', 'systemd-path', 'pgmslice', 'rpmlocate', 'chroot', 'ps2pdf12', 'sun-message', 'lsblk', 'pgmminkowski', 'openipmish', 'gml2gv', 'ebrowse', 'post-grohtml', 'sg_senddiag', 'amuFormat.sh', 'applydeltaiso', 'gdbus-codegen', 'smbtree', 'jmacs', 'pinky', 'richtext', 'tty', 'fixscribeps', 'pgmhist', 'pgpring', 'pgpewrap', 'pamgradient', 'sccmap', 'installcheck', 'pamtohtmltbl', 'libtool', 'pf2afm', 'gc', 'lsattr', 'ypdomainname', 'colmux', 'mshowfat', 'libpng16-config', 'cal', 'pdfroff', 'lupdate', 'oggenc', 'rasttopnm', 'xdg-settings', 'eu-elfcmp', 'getcifsacl', 'neqn', 'psfgettable', 'pamenlarge', 'keytab-lilo', 'systemd-journalctl', 'sg_prevent', 'curl', 'analyze', 'gtk-update-icon-cache-2.0', 'abs2rel', 'scsi_mandat', 'bzcat', 'freetype-config', 'xorrecord', 'ppmtorgb3', 'pammosaicknit', 'smtpd.py', 'ibdmtr', 'syslinux2ansi', 'unzip-plain', 'pamseq', 'xdg-terminal', 'cryptdir', 'old', 'ranlib', 'sftp', 'smbpasswd', 'bashbug', 'pngtogd', 'samba-regedit', 'nisdomainname', 'mkzftree', 'ib_send_bw', 'gemtopnm', 'attr', 'sg_verify', 'yume', 'smixlate', 'fribidi', 'nfs4_setfacl', 'makealias', 'grub2-mkfont', 'paste', 'cat', 'mandb', 'pamfunc', 'smbspool', 'sg_scan', 'sginfo', 'ncurses6-config', 'sha256sum', 'pamtopam', 'dlook.pl', 'cdinfo', 'rpmgraph', 'eu-findtextrel', 'ppmpat', 'strace-graph', 'getkeycodes', 'smbtar', 'mdatopbm', 'sum', 'setpriv', 'eyuvtoppm', 'grolj4', 'gdbus', 'lzless', 'xsubpp', 'pampaintspill', 'pstops', 'gcc', 'cyrus_sasl_sample_client', 'hipstopgm', 'gvfs-copy', 'gencat', 'jpeg2ktopam', 's2p', 'fmt', 'dc', 'setleds', 'plot-llstat', 'tbl', 'getafm', 'pnmalias', 'basename', 'fc-validate', 'sg_read_attr', 'ppmtouil', 'lwp-download', 'sg_reassign', 'ls', 'ppmtopcx', 'pydoc', 'opensc-tool', 'dbilogstrip', 'gfortran', 'emacs', 'zdiff', 'bzless', 'zipinfo', 'sfdp', 'mime-info-to-mime', 'fiascotopnm', 'winicontopam', 'lispmtopgm', 'lsmem', 'ppmtopuzz', 'dot', 'lsmod', 'aulastlog', 'gropdf', 'nfs4_editfacl', 'grub2-editenv', 'localedef', 'unicode_start', 'xml_merge', 'create_update_source.sh', 'sg_stpg', 'diff3', 'mzip', 'yuvtoppm', 'ofl', 'funzip-plain', 'ogginfo', 'lsusb.py', 'gpg-connect-agent', 'ipg', 'ppmquant', 'cdda2mp3.new', 'python2.7-config', 'wall', 'pamsharpness', 'audiosend', 'smilint', 'ypchfn', 'Backarrow2Delete', 'macptopbm', 'turbostat', 'pamflip', 'sg_ses', 'dig', 'epsffit', 'gettext', 'systemd-inhibit', 'makedumpfile-R.pl', 'libpng12-config', 'comps2solv', 'mkdiskimage', 'pamditherbw', 'gem2rpm.ruby2.1-0.10.1', 'sync', 'eu-ar', 'installation_sources', 'preconv', 'pod2html', 'bunzip2', 'pl2pm', 'setJava', 'unbuffer', 'udevadm', 'sg_vpd', 'uuencode', 'ppmmix', 'gmake', 'find2perl', 'gtbl', 'pyvenv', 'scout', 'sudo', 'ptardiff', 'fusermount', 'ypmatch', 'glib-genmarshal', 'sleep', 'dbiprof', 'dbwrap_tool', 'gconftool-rebuild', 'termidx', 'fstopgm', 'hunspell', 'fixdlsrps', 'sg_read_buffer', 'lsinitrd', 'checkmedia', 'gvfs-tree', 'g++-4.8', 'pnmtoplainpnm', 'neato', 'zipgrep-plain', 'catchsegv', 'unexpand', 'pr', 'gtk-update-icon-cache-3.0', 'unlzma', 'lprsetup.sh', 'pkttyagent', 'readcd', 'eu-ld', 'lastb', 'ppmtoeyuv', 'fillup', 'cluster', 'mcat', 'gsbj', 'python-argcomplete-check-easy-install-script-2.7', 'rpmmd2solv', 'dot2gxl', 'grub2-mknetdir', 'pktopbm', 'pbmtosunicon', 'ldd', 'Mail', 'gvfs-save', 'nmbstatus', 'dot_builtins', 'f2py', 'blkrawverify', 'timedatectl', 'pbmtoxbm', 'egrep', 'ppmdcfont', 'osage', 'pamoil', 'mimegzip', 'systemd-cgls', 'modhash', 'sort', 'ppmtopgm', 'qt3to4', 'truncate', 'xkibitz', 'dirmngr', 'bioradtopgm', 'glib-gettextize', 'make_method', 'setarch', 'annotate', 'quotasync', 'python', 'dracut', 'pbmtopk', 'pstree', 'genDDNSkey', 'pamfile', 'ppmforge', 'gpg-zip', 'fgconsole', 'fipshmac', 'icedax', 'pamtopfm', 'dbiproxy', 'zcmp', 'mmove', 'pylupdate4', 'ybmtopbm', 'xmlpatternsvalidator', 'fixpspps', 'rgb3toppm', 'rngtest', 'wish8.6', 'nsenter', 'cupstestdsc', 'zsoelim', 'ftbench', '.fipscheck.hmac', 'webpng', 'collectl', 'bmptopnm', 'create_sha1sum', 'x86_64-suse-linux-gnu-pkg-config', 'erb', 'grep-changelog', 'ps2pdfwr', 'lprm', 'rpmdb', 'fixwwps', 'gdk-pixbuf-query-loaders-64', 'db48_verify', 'lz', 'lsscsi', 'pdksh', 'btrecord', 'grub2-glue-efi', 'zipdetails', 'smime_keys', 'qvfb', 'mren', 'build-jar-repository', 'pamstretch', 'tfmtodit', 'lwp-request', 'zipsplit', 'infotopam', 'xorriso', 'colrm', 'snmpdelta', 'otp-md4', 'sed', 'sha512sum', 'bzip2recover', 'xhost', 'perf', 'deltainfoxml2solv', 'bzip2', 'dislocate', 'mimencode', 'md5pass', 'gs', 'qtconfig', 'stty', 'ppmtoleaf', 'sg_unmap', 'pgmtolispm', 'gtk-builder-convert', 'gvfs-less', 'gcore', 'ppmflash', 'piconv', 'expand', 'ionice', 'du', 'createpatch', 'ibv_xsrq_pingpong', 'xdg-desktop-menu', 'pmap', 'fixqt4headers.pl', 'pamtoxvmini', 'pamgauss', 'cpack', 'wordforms', 'pnmrotate', 'gcc-4.8', 'ainfo', 'grub2-emu-lite', 'slogin', 'python3.4m', 'ibv_uc_pingpong', 'ptar', 'snice', 'auvirt', 'pbmtocmuwm', 'psselect', 'rake.ruby.ruby2.1', 'xzfgrep', 'gvfs-trash', 'chrp-addnote', 'gsettings-data-convert', 'lzmadec', 'irb.ruby2.1', 'shar', 'brushtopbm', 'nmblookup', 'm4', 'unzipsfx-plain', 'peekfd', 'sg_rtpg', 'pjtoppm', 'mail', 'db48_deadlock', 'applydeltarpm', 'reset', 'uuidgen', 'pgmmedian', 'snmpget', 'gvmap.sh', 'ibdmchk', 'nfs4_getfacl', 'pamexec', 'scsi_readcap', 'pnmindex', 'opieftpd', 'kbdinfo', 'get-versions', 'df', 'grub2-menulst2cfg', 'spctoppm', 'prctl', 'avstopam', 'pamdepth', 'qhelpgenerator', 'lookbib', 'zypp-CheckAccessDeleted', 'lsns', 'cdda2ogg', 'unicode_stop', 'display-buttons', 'xwdtopnm', 'glib-compile-schemas', 'gtk-query-settings', 'lzma', 'unlink', 'mtools', 'snmpusm', 'snmpcheck', 'gdiffmk', 'sg_rmsn', 'pgmkernel', 'a2p', 'at', 'xorrisofs', 'screen', 'luitx', 'ar', 'rsyncstats', 'xmkmf', 'pygtk-demo', 'dlook', 'dirsplit', 'bison', 'eps2eps', 'systemd-firstboot', 'flock', 'create_md5sums', 'gslj', 'lsof', 'od', 'pbmmask', 'psfaddtable', 'bzdiff', 'initviocons', 'pamedge', 'pgmcrater', 'patch-metamail', 'pulseaudio', 'sgitopnm', 'troff', 'lzdiff', 'trace', 'db48_sql', 'smbclient', 'ppmcie', 'gcov', 'xtotroff', 'mbadblocks', 'cpio', 'snmpdf', 'ipcrm', 'scp', 'test_xauth', 'cpumap', 'gvfs-mkdir', 'usbhid-dump', 'pkcs15-crypt', 'ppm3d', 'less', 'netkey-tool', 'rpms2solv', 'testparm', 'vttest', 'vlock', 'ppmddumpfont', 'sg_start', 'pamtouil', 'rcc', 'mdu', 'tagmedia', 'ps2ascii', 'dos2unix', 'pbmtopgm', 'pod2usage', 'groups', 'ib_read_bw', 'fixfmps', 'ngettext', 'pnmtosir', 'pkcs15-init', 'xdg-mime', 'gcc-ar-4.8', 'pamendian', 'xmlwf', 'gawk', 'metamail', 'sg_logs', 'ippfind', 'richtoatk', 'gio-querymodules-64', 'sg_get_config', 'ftgamma', 'pnmsmooth', 'eu-addr2line', 'screendump', 'ipmish', 'pnmpad', 'gd2togif', 'numactl', 'regdiff', 'pamrgbatopng', 'info', 'systemd-stdio-bridge', 'chkconfig', 'extcompose', 'tknewsbiff', 'find-jar', 'readom', 'sg_map26', 'display-coords', 'ldapdelete', 'audiocompose', 'filesize', 'gtk-query-immodules-3.0-64', 'man', 'pamtodjvurle', 'ibdiagui', 'make', 'lzmore', 'uudecode', 'prtstat', 'opiekey', 'scriptreplay', 'grub2-fstest', 'mksh', 'arpaname', 'sip-2.7', 'ppmcolormask', 'last', 'pamrubber', 'pwdx', 'printf', 'pamslice', 'sputoppm', 'base32', 'sg_timestamp', 'gethostip', 'ppmtoacad', 'wbinfo', 'makedeltarpm', 'pbmtoescp2', 'eu-ranlib', 'gtk-builder-tool', 'pbmtodjvurle', 'fastjar', 'isosize', 'os-prober', 'encode_keychange', 'aclocal', 'pbmtog3', 'crontab', 'linux64', 'true', 'tzselect', 'colcrt', 'pbmtocis', 'db48_printlog', 'erb.ruby2.1', 'ppmtogif', 'db48_upgrade', 'grub2-render-label', 'intstats', 'tgatoppm', 'scsi_ready', 'pampick', 'xml_pp', 'rmcp_ping', 'ppmdist', 'qdbuscpp2xml', 'star', 'python3.4', 'packages2eula.pl', 'ul', 'flex', 'cpanp-run-perl', 'roff2x', 'ppmnorm', 'diff', 'pbmlife', 'dvipdf', 'aulast', 'mcomp', 'mkzimage_cmdline', 'munch', 'aa-easyprof', 'sg_raw', 'ps2pdf', 'mtvtoppm', 'mdir', 'systemd-ask-password', 'gpg2', 'python3', 'tailf', 'pkaction', 'fips_standalone_hmac', 'sg_ses_microcode', 'rpcgen', 'pkexec', 'ypchsh', 'neotoppm', 'podchecker', 'fdp', 'mkhtmlindex', 'pi3topbm', 'libtoolize', 'dir', 'ps2pdf13', 'grub2-mkimage', 'socklist', 'mstregdump', 'patch', 'ppmntsc', 'vorbiscomment', 'elfedit', 'pamtoavs', 'c++', 'newuidmap', 'scsi_start', 'h2xs', 'fixtpps', 'mstmread', 'westcos-tool', 'atktopbm', 'snmpbulkget', 'view', 'pammasksharpen', 'minfo', 'sg_turs', 'passwd', 'ppmtoyuv', 'chacl', 'pc1toppm', 'kill', 'ntlm_auth', 'psmerge', 'repomdxml2solv', 'pnmscale', 'ssh-agent', 'ibv_devinfo', 'gxditview', 'unmunge', 'install', 'tabs', 'free', 'whereis', 'pinentry', 'shownonascii', 'isohybrid.pl', 'pbmtozinc', 'etags', 'seq', 'ucs2any', 'ibtopodiff', 'uuenpipe', 'guess_encoding', 'outpsfheader', 'unix2mac', 'column', 'ftstring', 'systool', 'mkisofs', 'x86_64', 'ppmbrighten', 'fixmacps', 'locale', 'opielogin', 'sg_sat_identify', 'shuf', 'pamtojpeg2k', 'rebuild-jar-repository', 'pi1toppm', 'gvfs-mime', 'vitmp', 'readlink', 'gtester-report', 'xmlpatterns', 'gpm-root', 'opiesu', 'pnmtopalm', 'setup-pulseaudio', 'grub2-mkrescue', 'lockfile', 'size', 'cut', 'dbus-launch.x11', 'spottopgm', 'disable-paste', 'mcookie', 'rpcclient', 'cistopbm', 'rletopnm', 'gcc-ar', 'mtoolstest', 'readmult', 'command-not-found', 'opiepasswd', 'pnmquantall', 'grepjar', 'xzdiff', 'rexec', 'json_xs', 'mktemp', 'btrfs-map-logical', 'xdg-open', 'sprof', 'yes', 'mergelib', 'snapper', 'ping6', 'nslookup', 'tic', 'bdftruncate', 'curl-config', 'xzcat', 'ldapsearch', 'ib_atomic_bw', 'tsort', 'infotocap', 'automake', 'setpalette', 'bc', 'dotty', 'trust', 'getunimap', 'xauth', 'mesg', 'zeisstopnm', 'gpgv', 'grap2graph', 'afmtodit', 'bcfree', 'printafm', 'joe', 'bzmore', 'chmorph', 'sg', 'machinectl', 'pbmminkowski', 'pbmtoepsi', 'xzgrep', 'xbmtopbm', 'mmroff', 'addftinfo', 'sg_write_long', 'toe', 'lftp', 'tclsh', 'sc-hsm-tool', 'gconftool-2', 'pamchannel', 'designer', 'gpg-agent', 'ftdiff', 'qmake-qt5', 'sunicontopnm', 'link', 'sg_write_same', 'net-snmp-cert', 'lneato', 'pgmtopgm', 'ssh', 'tred', 'pfmtopam', 'sgi_config_changed', 'touch', 'gpgv2', 'ppmtopi1', 'ssh-keygen', 'pamtosrf', 'smbcontrol', 'scsi_temperature', 'atrm', 'gdk-pixbuf-csource', 'systemd-detect-virt', 'mimezip', 'pod2man', 'safe-rm', 'mt', 'eu-unstrip', 'gsdj500', 'unshar', 'cardos-tool', 'timed-run', 'ppmtosixel', 'scsi_logging_level', 'gpasswd', 'snmptls', 'perldoc', 'cancel', 'xdg-icon-resource', 'sg_sat_read_gplog', 'nop', 'gvpack', 'hltest', 'sg_get_lba_status', 'sirtopnm', 'loginctl', 'pnmtojpeg', 'ppmmake', 'pnmconvol', 'showexternal', 'wish', 'mvxattr', 'pamtopdbimg', 'mkmanifest', 'gd2topng', 'pnminterp', 'icontopbm', 'ruby', 'snmptable', 'sg_reset_wp', 'sg_opcodes', 'rm', 'opieinfo', 'pnmtoxwd', 'pamsistoaglyph', 'vimtutor', 'safe-rmdir', 'readelf', 'eqn2graph', 'bcomps', 'uname26', 'gcov-4.8', 'fipscheck', 'numastat', 'sun-audio-file', 'twopi', 'pnmnlfilt', 'gvfs-move', 'piv-tool', 'loadkeys', 'extlinux', 'dconf', 'ppmfade', 'genisoimage', 'unpigz', 'ipptool', 'strings', 'thinkjettopbm', 'autoreconf', 'pgmtexture', 'array', 'rds-ping', 'sdrcomp', 'merge-pciids', 'hostnamectl', 'gvfs-rm', 'mkinfodir', 'dmesg', 'kbd_mode', 'openct-tool', 'autoupdate', 'giftopnm', 'giftogd2', 'vdir', 'relnotes', 'create_directory.yast', 'ximtoppm', 'gpgparsemail', 'updateinfoxml2solv', 'pnmtoddif', 'ppmtoascii', 'cksum', 'gdk-pixbuf-pixdata', 'ddbugtopbm', 'grodvi', 'jbigtopnm', 'ldappasswd', 'fadot', 'pnmcrop', 'pnmtorle', 'gv2gxl', 'raw_ethernet_bw', 'xpmtoppm', 'cifscreds', 'psbook', 'pnmgamma', 'ppmtoppm', 'eu-objdump', 'openipmicmd', 'batch', 'pamtowinicon', 'i386', 'acyclic', 'pamx', 'xzmore', 'pbmupc', 'fc-scan', 'mpartition', 'rpmspec', 'pngtogd2', 'pamstretch-gen', 'mmencode', 'xzless', 'fixproc', 'pamrecolor', 'cp', 'gzexe', 'dirname', 'ppmtoxpm', 'btreplay', 'loadunimap', 'rpmsign', 'sha224sum', 'sg_luns', 'get_kernel_version', 'lexgrog', 'easy_install-2.7', 'prove', 'lp', 'sudoedit', 'pod2latex', 'zforce', 'grub2-file', 'ib_atomic_lat', 'pnmtojbig', 'expiry', 'fc-cat', 'ppmtv', 'lex', 'wbmptopbm', 'systemd-tmpfiles', 'base64', 'mattrib', 'uudepipe', 'pamfix', 'qmlplugindump', 'pbmtomatrixorbital', 'gpgtar', 'pixeltool', 'mac2unix', 'koi8rxterm', 'xzdec', 'strace', 'ipmilan', 'sbigtopgm', 'openipmi_eventd', 'pgmtopbm', 'mailto-hebrew', 'raw_ethernet_lat', 'testrb.ruby2.1', 'fc-match', 'getent', 'gfortran-4.8', 'pbmtoppa', 'pbmtextps', 'mxtar', 'uncompress', 'passmass', 'pstruct', 'mstmtserver', 'pamtopnm', 'mgrtopbm', 'printenv', 'grub2-emu', 'pbmtonokia', 'qdbusxml2cpp', 'lesskey', 'mailto', 'enc2xs', 'zipnote', 'psidtopgm', 'setfont', 'ib_send_lat', 'systemd-tty-ask-password-agent', 'pgmoil', 'cmuwmtopbm', 'gen-s390-cd-kernel.pl', 'smt', 'lzfgrep', 'getfacl', 'sg_xcopy', 'pnmhistmap', 'build-classpath', 'uname', 'unflatten', 'h2ph', 'znew', 'xml_grep', 'coredumpctl', 'mimeit', 'bzegrep', 'list_audio_tracks', 'pbmtolj', 'splitmail', 'sqlite3', 'mapscrn', 'recode', 'sha384sum', 'lastlog', 'pnmremap', 'ppmtopj', 'systemd-escape', 'prlimit', 'pbmtogo', 'ppmdither', 'ps2ps2', 'newgrp', 'pamdice', 'pnmtops', 'chage', 'pbmtext', 'pnmcolormap', 'regpatch', 'dwp', 'rsh', 'shred', 'agentxtrap', 'zsh', 'remunge', 'eu-strip', 'gdlib-config', 'tr', 'pathchk', 'stat', 'pbmtomda', 'pbmtomacp', 'pnmtotiffcmyk', 'rpmdb2solv', 'build-classpath-directory', 'snmpvacm', 'gxl2gv', 'cups-config', 'sha1sum', 'traptoemail', 'sg_read_long', 'xterm', 'pydoc3.4', 'gstat', 'raw_ethernet_fs_rate', 'pgmdeshadow', 'lzmainfo', 'gpgsplit', 'ibis', 'pamthreshold', 'pbmpage', 'dircolors', 'ppmtoicr', 'roff2pdf', 'uptime', 'makedeltaiso', 'emacs-x11', 'gpgconf', 'arch', 'ping', 'pamdeinterlace', 'augparse', 'c++filt', 'mcd', 'leaftoppm', 'eu-nm', 'mstfwreset', 'verify_blkparse', 'snmpinform', 'resize', 'manweb', 'xzegrep', 'pnmmargin', 'ispellaff2myspell', 'cpuset', 'expect', 'gdtopng', 'mk_listings', 'strip', 'mkfontscale', 'bzfgrep', 'lconvert', 'line', 'smbprngenpdf', 'tkmib', 'imake', 'stty.pl', 'os_release', 'srftopam', 'systemd-nspawn', 'ppmtolss16', 'gvfs-cat', 'sg_requests', 'uic', 'ipmitool', 'groffer', 'smistrip', 'syslinux', 'gvimtutor', 'catman', 'snmptranslate', 'decryptdir', 'bdftogd', 'embedspu', 'git_version.tcl', 'db48_hotbackup', 'pampop9', 'more', 'llstat', 'gst-device-monitor-1.0', 'escp2topbm', 'gcc-ranlib', 'create_sha1sums', 'hpftodit', 'pstree.x11', 'ppmtoarbtxt', 'pphs', 'metasend', 'check-binary-files', 'gnuctags', 'mmd', 'xzcmp', 'mount', 'sldtoppm', 'chcon', 'atq', 'clrunimap', 'pinentry-curses', 'pnmtopng', 'sg_rep_zones', 'mcheck', 'xpstat', 'ipmicmd', 'gxl2dot', 'sg_zone', 'augtool', 'tac', 'vmstat', 'osirrox', 'sg_safte', 'pamperspective', 'tifftopnm', 'lpunlock', 'look', 'python2-config', 'uz', 'otp-md5', 'gendiff', 'python2.7', 'mstmwrite', 'uxterm', 'systemd-sysusers', 'flex++', 'ppmtopict', 'lzgrep', 'scsi_stop', 'ib_write_lat', 'dirmngr-client', 'sg_inq', 'setvtrgb', 'lpoptions', 'fc-pattern', 'palmtopnm', 'xdg-su', 'rvim', 'jvmjar', 'showpicture', 'openpgp-tool', 'gsettings', 'tartest', 'ppmdraw', 'ibdiagnet', 'pgmedge', 'pnmscalefixed', 'red', 'ppmshadow', 'rev', 'pamundice', 'ypcat', 'perlbug', 'ctest', 'zgrep', 'mgrep', 'numfmt', 'perlthanks', 'rjoe', 'blkiomon', 'wodim', 'pnmflip', 'ncurses5-config', 'pkcs15-tool', 'mcopy', 'migratepages', 'setkeycodes', 'rftp', 'script', 'gvfs-ls', 'grub2-mkpasswd-pbkdf2', 'users', 'kernel-install', 'ldapwhoami', 'systemd-hwdb', 'cc', 'ps2pdf14', 'pnmpsnr', 'net-snmp-create-v3-user', 'systemd-machine-id-setup', 'iconv', 'cdrecord', 'pamsharpmap', 'fallocate', 'tset', 'wordlist2hunspell', 'compress_susetags', 'snmpgetnext', 'ruby.ruby2.1', 'gzip', 'dvdrecord', 'pgmramp', 'ycpc', 'find', 'syslinux-mtools', 'gpg', 'pbmtowbmp', 'mlabel', 'pitchplay', 'sg_referrals', 'pbmmake', 'cpupower', 'csplit', 'chem', 'pnmtofiasco', 'yume-opkg', 'hunzip', 'gem.ruby2.1', 'rename', 'lpq', 'qhelpconverter', 'usb-devices', 'fc-cache', 'sg_reset', 'watch', 'pbmtoascii', 'ChangeSymlinks', 'su', 'hdifftopam', 'isohybrid', 'systemd-loginctl', 'kmod', 'python2', 'rcc-qt5', 'rds-stress', 'killall', 'gpgkey2ssh', 'stdlogctl', 'create_repo_for_patch.sh', 'sg_write_verify', 'pnmpaste', 'sdiff', 'pnmtofits', 'db48_recover', 'ilbmtoppm', 'eidenv', 'clear', 'ld.bfd', 'host', 'chrt', 'sharesec', 'diff-jars', 'pnmmercator', 'sg_modes', 'ppmlabel', 'pgmmorphconv', 'echo', 'pbmtoptx', 'lkbib', 'pbmtogem', 'uic-qt5', 'asn1Decoding', 'gem', 'gdb', 'mwm', 'hzip', 'sg_wr_mode', 'sg_sync', 'pgmtoppm', 'pnminvert', 'pamtilt', 'ppmrelief', 'ptty_try', 'nsupdate', 'which', 'ppmtojpeg', 'eu-strings', 'sg_write_buffer', 'rlogin-cwd', 'showconsolefont', 'xml_split', 'false', 'sg_test_rwbuf', 'db48_archive', 'ipcmk', 'pamsumm', 'ppmrainbow', 'winicontoppm', 'logname', 'pyuic4', 'cryptoflex-tool', 'ccmakedep', 'ldapmodrdn', 'ppmtomap', 'dump2slvl.pl', 'fc-list', 'eu-make-debug-archive', 'localectl', 'emacs-gtk', 'pamtotga', 'sgp_dd', 'mstconfig', 'qdoc3', 'kbxutil', 'pgmabel', 'linux32', 'cpanp', 'mouse-test', 'gvfs-monitor-file', 'setlogcons', 'mkdir', 'sg_compare_and_write', 'oldfind', 'eu-elflint', 'pyrcc4', 'pamvalidate', 'crash', 'ppmglobe', 'igawk', 'mergesolv', 'fc-query', 'chfn', 'mshortname', 'shasum', 'net-snmp-config', 'utmpdump', 'pamwipeout', 'w3mman', 'qmake', 'split', 'yuvsplittoppm', 'psfstriptable', 'dumpsolv', 'pic', 'ogg123', 'numademo', 'tclsh8.6', 'fixwfwps', 'pic2graph', 'yum-repoquery', 'corelist', 'showpartial', 'pbmreduce', 'nm', 'chmem', 'snmpstatus', 'pxelinux-options', 'ppmtoterm', 'mtype', 'cmp', 'modsign-verify', 'pamsummcol', 'systemconfigurator', 'xml2-config', 'm17n-db', 'ruby-find-versioned', 'includeres', 'smiquery', 'ptargrep', 'plymouth', 'sg_format', 'gvfs-monitor-dir', 'ed', 'pnmcut', 'timeout', 'lessclose.sh', 'gsnd', 'getdelays', 'rdoc.ruby.ruby2.1', 'ppmtospu', 'memdiskfind', 'pgmnorm', 'pyvenv-3.4', 'pamstereogram', 'idn', 'gst-discoverer-1.0', 'wget', 'ldapmodify', 'findsmb', 'unix2dos', 'realpath', 'taskset', 'tload', 'whatis', 'rview', 'update-mime-database', 'gtk-encode-symbolic-svg', 'pfbtopfa', 'ppmspread', 'setvesablank', 'pamtohdiff', 'sg_decode_sense', 'zypp-NameReqPrv', 'ibv_srq_pingpong', 'ldapurl', 'kibitz', 'ssh-keyscan', 'ssh-copy-id', 'oLschema2ldif', 'as', 'pkg-config', 'splain', 'xmlcatalog', 'scan_scsi.linux', 'autoheader', 'glib-mkenums', 'pbmtoplot', 'doxygen', 'fixpsditps', 'gst-play-1.0', 'getfattr', 'xdg-screensaver', 'indxbib', 'pigz', 'solterm', 'rcvAppleSingle', 'systemd-cgtop', 'mailx', 'multixterm', 'ib_read_lat', 'ipcs', 'ausyscall', 'pod2text', 'imgtoppm', 'ln', 'mstmcra', 'revpath', 'pnmnorm', 'g++', 'pambayer', 'rds-info', 'testsolv', 'runcon', 'fixwpps', 'eqn', 'lndir', 'termprobes', 'eu-stack', 'ppmtowinicon', 'lsipc', 'rcp', 'irb', 'luac5.2', 'lslogins', 'linux-boot-prober', 'ppmtopjxl', 'setsid', 'sha1pass', 'busctl', 'xsltproc', 'systemd-delta', 'pnmtosgi', 'roff2dvi', 'ccmake', 'dijkstra', 'qdbus', 'extractres', 'deallocvt', 'formail', 'hostid', 'cyrus_sasl_sample_server', 'asciitopgm', 'nohup', 'sndAppleSingle', 'bootctl', 'uic3', 'systemd-notify', 'ftlint', 'chsh', 'objdump', 'sg_rbuf', 'eu-size', 'pngtopam', 'grub2-mkstandalone', 'sg_sanitize', 'convmv', 'prune', 'dplace', 'ppmtomitsu', 'mkfifo', 'renice', 'rlogin', 'pnmarith', 'strace-log-merge', 'gsdj', 'pamcomp', 'makedepend', '[', 'lefty', 'rawtopgm', 'md5sum', 'fdupes', 'cpp', 'getopt', 'snmptrap', 'gcc-nm', 'python-config', 'pnmtorast', 'dbus-run-session', 'tack', 'lessopen.sh', 'snmpconf', 'zipcloak', 'anytopnm', 'ipmi_ui', 'mm2gv', 'lslocks', 'raw_ethernet_burst_lat', 'infocmp', 'soelim', 'pbmtolps', 'geteltorito', 'lksh', 'smicache', 'telnet', 'xxd', 'instmodsh', 'mformat', 'pnmcomp', 'eu-readelf', 'ppmtoapplevol', 'ppmhist', 'cdda2mp3', 'p11-kit', 'repo2solv', 'chown', 'kmp-install', 'sg_dd', 'ibdiagpath', 'cpan', 'fgrep', 'run_perftest_multi_devices', 'mstflint', 'gresource', 'sudoreplay', 'pnmenlarge', 'akill', 'nice', 'gobject-query', 'sg_persist', 'pnmsplit', 'smbcquotas', 'rsync', 'udisksctl', 'cdrskin', 'dd', 'sg_readcap', 'ldapadd', 'showchar', 'head', 'zfgrep', 'file', 'pbmto4425', 'asn1Parser', 'sun2mime', 'icu-config', 'rpmkeys', 'sg_sat_phy_event', 'db48_stat', 'rpm2cpio', 'groff', 'susetags2solv', 'pgmnoise', 'pbmtoybm', 'refer', 'pdbedit', 'test', 'syncqt.pl', 'psnup', 'pkcheck', 'qdbusviewer', 'gtk-query-immodules-2.0-64', 'pamtosvg', 'autoexpect', 'finger', 'logger', 'combinedeltarpm', 'lss16toppm', 'xvminitoppm', 'rlatopam', 'smbinfo', 'w', 'pamlookup', 'mdig', 'pbmtoepson', 'gcc-ranlib-4.8', 'pambackground', 'mrftopbm', 'bznew', 'lwp-mirror', 'json_pp', 'lscpu', 'omshell', 'procmail', 'esdcompat', 'ps2ps', 'mimebzip', 'sqlite3_analyzer', 'pkcs11-tool', 'pydoc3', 'cpp-4.8', 'ibv_devices', 'grog', 'pngtopnm', 'libpng-config', 'ncursesw6-config', 'gdparttopng', 'pgmenhance', 'gvpr', 'zless', 'mrd', 'pnmfile', 'gvfs-info', 'pamcut', 'zmore', 'mailserver', 'qlalr', 'pnmquant', 'pamtogif', 'dump2psl.pl']
      ['chown', 'setvesablank', 'mkdir', 'lksh', 'showconsolefont', 'echo', 'setvtrgb', 'setkeycodes', 'mount', 'pidof', 'zsh', 'false', 'loadunimap', 'clrunimap', 'rm', 'setfont', 'setlogcons', 'fgrep', 'kbd_mode', 'gzip', 'dd', 'find', 'logger', 'awk', 'ping6', 'cp', 'stat', 'psfstriptable', 'fgconsole', 'df', 'initviocons', 'systemd-ask-password', 'setpalette', 'uname', 'plymouth', 'unicode_stop', 'gawk', 'kill', 'readlink', 'touch', 'arch', 'ed', 'su', 'ls', 'unicode_start', 'sync', 'fillup', 'sort', 'sed', 'mail', 'psfaddtable', 'screendump', 'mktemp', 'loadkeys', 'ping', 'ln', 'mksh', 'guess_encoding', 'dmesg', 'more', 'deallocvt', 'kbdrate', 'systemctl', 'spawn_console', 'openvt', 'systemd', 'date', 'resizecons', 'pwd', 'rmdir', 'chmod', 'setmetamode', 'mv', 'chgrp', 'grep', 'findmnt', 'showkey', 'gunzip', 'zcat', 'dumpkeys', 'ksh', 'mknod', 'spawn_login', 'psfxtable', 'umount', 'chvt', 'lsblk', 'ypdomainname', 'psfgettable', 'ip', 'nisdomainname', 'cat', 'getkeycodes', 'setleds', 'basename', 'lsmod', 'ipg', 'sleep', 'egrep', 'stty', 'kbdinfo', 'cpio', 'true', 'outpsfheader', 'getunimap', 'mapscrn', 'md5sum', 'blkparse', 'dbus-cleanup-sockets', 'dbus-monitor', 'fsync', 'tar', 'ex', 'fuser', 'csh', 'rpm', 'pdksh', 'login', 'pgrep', 'btrace', 'dbus-send', 'netstat', 'tcsh', 'domainname', 'ps', 'dbus-uuidgen', 'hostname', 'vi', 'vim', 'pkill', 'dnsdomainname', 'bash', 'blktrace', 'usleep', 'dbus-daemon', 'keyctl', 'sh']
      ['cshutdown', 'cpush', 'ckill', 'c3_sock.py', 'clist', 'cexecs', 'cpushimage', 'c3.csh', 'cname', 'cget', 'c3.sh', 'ckillnode', 'c3_except.py', 'crm', 'c3cmd-filter', 'c3_file_obj.py', 'cnum', 'c3_com_obj.py', 'c3_version.py', 'cexec', 'c3_config.py']
      ['pbs_rdel', 'pbs_migrate_users', 'qdisable', 'pbs_python', 'qselect', 'pbsdsh', 'pbs_remsh', 'qenable', 'nqs2pbs', 'pbsrun', 'pbs_mpilam', 'qstat', 'qmgr', 'tracejob', 'qrerun', 'pbs_tmrsh', 'qsig', 'pclm', 'qdel', 'pbs_lamboot', 'pbs_password', 'pbsrun_wrap', 'pbs_mpirun', 'pbs_mpihp', 'qalter', 'qmove', 'pbs_wish', 'pbs_sleep', 'qstop', 'qrun', 'qsub', 'qorder', 'pbs_rstat', 'printjob', 'qhold', 'qrls', 'mpiexec', 'qmsg', 'pbs_attach', 'pbs_release_nodes', 'pbsnodes', 'pbsrun_unwrap', 'printjob.bin', 'pbs_tclsh', 'qterm', 'pbs_rsub', 'qstart', 'pbs_ralter', 'pbs_topologyinfo', 'pbs_hostn']
      ['btrfs-debug-tree', 'mkdosfs', 'audispd', 'ifdown', 'fsck.ext3', 'mkfs.cramfs', 'raw', 'agetty', 'pivot_root', 'ifstatus', 'blkid', 'fsck.minix', 'hwclock', 'OneClickInstallUrlHandler', 'mke2fs', 'modprobe', 'fstrim', 'debugfs', 'hdparm', 'insserv', 'arping', 'reboot', 'crda', 'tracepath', 'btrfs', 'fsck.fat', 'badblocks', 'btrfsck', 'kdump', 'vconfig', 'e2undo', 'mkfs.minix', 'shutdown', 'regdbdump', 'adjtimex', 'auditctl', 'in.rdisc', 'fbtest', 'mkfs.msdos', 'dosfsck', 'swapon', 'telinit', 'mkfs.btrfs', 'mkfs.vfat', 'OneClickInstallUI', 'yast', 'fsck.ext2', 'dumpe2fs', 'smart_agetty', 'aureport', 'swaplabel', 'ctrlaltdel', 'btrfs-convert', 'OneClickInstallCLI', 'mkfs.ext3', 'chkconfig', 'btrfstune', 'rmmod', 'fsck.msdos', 'fdisk', 'SuSEfirewall2', 'logsave', 'mkfs.fat', 'e2image', 'rcipmi', 'mkfs.bfs', 'blockdev', 'switch_root', 'OCICLI', 'fsck', 'mkfs.ext4', 'sfdisk', 'insmod', 'fsck.cramfs', 'tracepath6', 'udevadm', 'lsmod', 'chcpu', 'btrfs-image', 'ip', 'refresh_initrd', 'ifprobe', 'depmod', 'fsck.vfat', 'modinfo', 'resize2fs', 'findfs', 'auditd', 'nologin', 'yast2', 'btrfs-show-super', 'kexec', 'poweroff', 'e2fsck', 'autrace', 'fsfreeze', 'fsck.ext4', 'halt', 'mkfs.ext2', 'rcSuSEfirewall2', 'service', 'wiper.sh', 'wipefs', 'dosfslabel', 'ifenslave', 'udevd', 'cryptsetup', 'fsck.btrfs', 'e2label', 'swapoff', 'augenrules', 'tune2fs', 'mkswap', 'ifup', 'cfdisk', 'runlevel', 'mount.fuse', 'losetup', 'rsyslogd', 'btrfs-zero-log', 'clockdiff', 'ausearch', 'mkfs', 'init', 'slattach', 'chkstat-polkit', 'getappcore', 'mdadm', 'ipmaddr', 'update-bootloader', 'install-info', 'fsck.xfs', 'purge-kernels', 'tunefs.reiserfs', 'vgremove', 'mount.cifs', 'fstab-decode', 'iscsi-iname', 'pmap_set2', 'lvscan', 'vgexport', 'vgreduce', 'rcnetwork', 'mount.crypt_LUKS', 'mkill', 'dmraid', 'iscsiuio', 'SUSEfirewall2', 'bootcpuset', 'vgcreate', 'lvmconf', 'umount.nfs4', 'multipathd', 'rcsubdomain', 'installkernel', 'route', 'dmeventd', 'pvremove', 'pvscan', 'lvmsar', 'unix2_chkpwd', 'multipath', 'vgcfgrestore', 'umount.crypt', 'pvchange', 'start_daemon', 'lvrename', 'mount.crypto_LUKS', 'lvmetad', 'unix_update', 'mount.nfs', 'ldconfig', 'mingetty', 'pbl', 'umount.nfs', 'setconsole', 'blkdeactivate', 'lvs', 'apparmor_parser', 'iscsi_discovery', 'mount.lustre', 'lvmdump', 'cpuset_release_agent', 'killproc', 'isserial', 'umount.crypto_LUKS', 'analyzevmcore', 'mkinitrd_setup', 'showconsole', 'lvmpolld', 'rvmtab', 'request-key', 'pam_tally2', 'plipconfig', 'dhclient-script', 'lvmconfig', 'vgchange', 'resize_reiserfs', 'ifuser', 'unix_chkpwd', 'umount.crypt_LUKS', 'mdmon', 'fsadm', 'rarp', 'lvdisplay', 'rcapparmor', 'ether-wake', 'lvreduce', 'lspci', 'vgimportclone', 'lvm', 'pvcreate', 'blogger', 'key.dns_resolver', 'vgdisplay', 'pvdisplay', 'dmevent_tool', 'pvs', 'nfsdcltrack', 'rpcbind', 'vgscan', 'blogd', 'iptunnel', 'setpci', 'brcm_iscsiuio', 'chkbin', 'supportconfig', 'lvremove', 'ifconfig', 'vgck', 'nameif', 'vgrename', 'mkfs.reiserfs', 'pvmove', 'lvmsadc', 'vgconvert', 'dhclient', 'lvchange', 'mount.crypt', 'lvconvert', 'vgextend', 'pvresize', 'mkinitrd', 'mkfs.xfs', 'pidofproc', 'startproc', 'vgsplit', 'update-pciids', 'iscsi_fw_login', 'dmsetup', 'pidof', 'reiserfsck', 'debugfs.reiserfs', 'vgmknodes', 'lvmdiskscan', 'sysctl', 'startpar', 'lvextend', 'netconfig', 'vgs', 'blogctl', 'debugreiserfs', 'rpcinfo', 'lvresize', 'vgcfgbackup', 'fsck.reiserfs', 'mkhomedir_helper', 'checkproc', 'set_polkit_default_privs', 'rmt', 'dmstats', 'vhangup', 'lvcreate', 'vgmerge', 'mount.nfs4', 'xfs_repair', 'mkreiserfs', 'vgimport', 'pvck', 'reiserfstune', 'pam_timestamp_check', 'osd_login', 'arp', 'killall5', 'rcsyslog', 'iscsid', 'kpartx', 'iscsi_offload', 'iscsistart', 'dhclient6', 'mpathpersist', 'iscsi-gen-initiatorname', 'iscsiadm']
**** Configure header /p/work2/tmondrag/petsc-N5i8ny/confdefs.h ****
#if !defined(INCLUDED_UNKNOWN)
#define INCLUDED_UNKNOWN
#define IS_COLORING_MAX USHRT_MAX
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#define PETSC_CLANGUAGE_C 1
#define PETSC_HAVE_ERF 1
#define PETSC_HAVE_FENV_H 1
#define PETSC_HAVE_LOG2 1
#define PETSC_HAVE_TGAMMA 1
#define PETSC_CXX_INLINE inline
#define PETSC_CXX_RESTRICT __restrict
#define PETSC_C_INLINE inline
#define PETSC_C_RESTRICT __restrict
#define PETSC_FORTRAN_CHARLEN_T int
#define PETSC_HAVE_C99 1
#define PETSC_HAVE_CXX_DIALECT_CXX11 1
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#define PETSC_HAVE_RTLD_GLOBAL 1
#define PETSC_HAVE_RTLD_LAZY 1
#define PETSC_HAVE_RTLD_LOCAL 1
#define PETSC_HAVE_RTLD_NOW 1
#define PETSC_HAVE_DLFCN_H 1
#define PETSC_HAVE_FCNTL_H 1
#define PETSC_HAVE_FLOAT_H 1
#define PETSC_HAVE_IMMINTRIN_H 1
#define PETSC_HAVE_INTTYPES_H 1
#define PETSC_HAVE_MALLOC_H 1
#define PETSC_HAVE_NETDB_H 1
#define PETSC_HAVE_NETINET_IN_H 1
#define PETSC_HAVE_PTHREAD_H 1
#define PETSC_HAVE_PWD_H 1
#define PETSC_HAVE_SETJMP_H 1
#define PETSC_HAVE_STDINT_H 1
#define PETSC_HAVE_STRINGS_H 1
#define PETSC_HAVE_SYS_PARAM_H 1
#define PETSC_HAVE_SYS_PROCFS_H 1
#define PETSC_HAVE_SYS_RESOURCE_H 1
#define PETSC_HAVE_SYS_SOCKET_H 1
#define PETSC_HAVE_SYS_SYSINFO_H 1
#define PETSC_HAVE_SYS_TIMES_H 1
#define PETSC_HAVE_SYS_TIME_H 1
#define PETSC_HAVE_SYS_TYPES_H 1
#define PETSC_HAVE_SYS_UTSNAME_H 1
#define PETSC_HAVE_SYS_WAIT_H 1
#define PETSC_HAVE_TIME_H 1
#define PETSC_HAVE_UNISTD_H 1
#define PETSC_HAVE_ISINF 1
#define PETSC_HAVE_ISNAN 1
#define PETSC_HAVE_ISNORMAL 1
#define PETSC_HAVE_REAL___FLOAT128 1
#define PETSC_USE_REAL_DOUBLE 1
#define PETSC_HAVE_C99_COMPLEX 1
#define PETSC_HAVE_CXX_COMPLEX 1
#define PETSC_HAVE_STRUCT_SIGACTION 1
#define PETSC_SIZEOF_ENUM 4
#define PETSC_SIZEOF_INT 4
#define PETSC_SIZEOF_LONG 8
#define PETSC_SIZEOF_LONG_LONG 8
#define PETSC_SIZEOF_SHORT 2
#define PETSC_SIZEOF_SIZE_T 8
#define PETSC_SIZEOF_VOID_P 8
#define PETSC_USE_FORTRANKIND 1
#define PETSC_USE_VISIBILITY_C 1
#define PETSC_USE_VISIBILITY_CXX 1
#define PETSC_HAVE_ACCESS 1
#define PETSC_HAVE_BZERO 1
#define PETSC_HAVE_CLOCK 1
#define PETSC_HAVE_DLCLOSE 1
#define PETSC_HAVE_DLERROR 1
#define PETSC_HAVE_DLOPEN 1
#define PETSC_HAVE_DLSYM 1
#define PETSC_HAVE_DRAND48 1
#define PETSC_HAVE_FORK 1
#define PETSC_HAVE_GETCWD 1
#define PETSC_HAVE_GETDOMAINNAME 1
#define PETSC_HAVE_GETHOSTBYNAME 1
#define PETSC_HAVE_GETHOSTNAME 1
#define PETSC_HAVE_GETPAGESIZE 1
#define PETSC_HAVE_GETRUSAGE 1
#define PETSC_HAVE_GETWD 1
#define PETSC_HAVE_LSEEK 1
#define PETSC_HAVE_MEMALIGN 1
#define PETSC_HAVE_MEMMOVE 1
#define PETSC_HAVE_MMAP 1
#define PETSC_HAVE_NANOSLEEP 1
#define PETSC_HAVE_POPEN 1
#define PETSC_HAVE_RAND 1
#define PETSC_HAVE_READLINK 1
#define PETSC_HAVE_REALPATH 1
#define PETSC_HAVE_SLEEP 1
#define PETSC_HAVE_SNPRINTF 1
#define PETSC_HAVE_SOCKET 1
#define PETSC_HAVE_STRCASECMP 1
#define PETSC_HAVE_SYSINFO 1
#define PETSC_HAVE_TIME 1
#define PETSC_HAVE_UNAME 1
#define PETSC_HAVE_USLEEP 1
#define PETSC_HAVE_VA_COPY 1
#define PETSC_HAVE_VSNPRINTF 1
#define PETSC_SIGNAL_CAST
#define PETSC_FORTRAN_TYPE_INITIALIZE  = -2
#define PETSC_HAVE_FORTRAN_FLUSH 1
#define PETSC_HAVE_FORTRAN_TYPE_STAR 1
#define PETSC_USING_F2003 1
#define PETSC_USING_F90 1
#define PETSC_USING_F90FREEFORM 1
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#define PETSC_USE_SHARED_LIBRARIES 1
#define PETSC_USE_DEBUGGER "gdb"
#define PETSC_VERSION_BRANCH_GIT "(HEAD detached from 5ea3abf)"
#define PETSC_VERSION_DATE_GIT "2020-01-24 13:29:59 -0600"
#define PETSC_VERSION_GIT "v3.12.3-632-gaf591a4"
#define PETSC_HAVE_MPIIO 1
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#define PETSC_HAVE_MPI_COMBINER_NAMED 1
#define PETSC_HAVE_MPI_C_DOUBLE_COMPLEX 1
#define PETSC_HAVE_MPI_EXSCAN 1
#define PETSC_HAVE_MPI_FINALIZED 1
#define PETSC_HAVE_MPI_GET_ACCUMULATE 1
#define PETSC_HAVE_MPI_GET_LIBRARY_VERSION 1
#define PETSC_HAVE_MPI_IALLREDUCE 1
#define PETSC_HAVE_MPI_IBARRIER 1
#define PETSC_HAVE_MPI_INIT_THREAD 1
#define PETSC_HAVE_MPI_INT64_T 1
#define PETSC_HAVE_MPI_IN_PLACE 1
#define PETSC_HAVE_MPI_LONG_DOUBLE 1
#define PETSC_HAVE_MPI_NEIGHBORHOOD_COLLECTIVES 1
#define PETSC_HAVE_MPI_NONBLOCKING_COLLECTIVES 1
#define PETSC_HAVE_MPI_ONE_SIDED 1
#define PETSC_HAVE_MPI_PROCESS_SHARED_MEMORY 1
#define PETSC_HAVE_MPI_REDUCE_LOCAL 1
#define PETSC_HAVE_MPI_REDUCE_SCATTER 1
#define PETSC_HAVE_MPI_REDUCE_SCATTER_BLOCK 1
#define PETSC_HAVE_MPI_RGET 1
#define PETSC_HAVE_MPI_TYPE_DUP 1
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#define PETSC_HAVE_MPI_WIN_CREATE 1
#define PETSC_MISSING_SIGTERM 1
#define PETSC_Alignx(a,b)
#define PETSC_IS_COLOR_VALUE_TYPE short
#define PETSC_IS_COLOR_VALUE_TYPE_F integer2
#define PETSC_USE_AVX512_KERNELS 1
#define PETSC_USE_BACKWARD_LOOP 1
#define PETSC_USE_CTABLE 1
#define PETSC_USE_INFO 1
#define PETSC_USE_LOG 1
#define PETSC_USE_MALLOC_COALESCED 1
#define PETSC_MEMALIGN 16
#define PETSC_LEVEL1_DCACHE_LINESIZE 32
#define PETSC__BSD_SOURCE 1
#define PETSC__DEFAULT_SOURCE 1
#define PETSC__GNU_SOURCE 1
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#define PETSC_PYTHON_EXE "/usr/bin/python"
#endif
**** C specific Configure header /p/work2/tmondrag/petsc-N5i8ny/conffix.h ****
#if defined(__cplusplus)
extern "C" {
#else
#endif
#endif
                    OSError while running ./configure
[Errno 13] Permission denied: '/pbs/SLB'
  File "/p/work2/tmondrag/moose/petsc/config/configure.py", line 447, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/framework.py", line 1219, in configure
    self.processChildren()
  File "/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/framework.py", line 1208, in processChildren
    self.serialEvaluation(self.childGraph)
  File "/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/framework.py", line 1183, in serialEvaluation
    child.configure()
  File "/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/packages/lgrind.py", line 41, in configure
    self.getExecutable('lgrind', getFullPath = 1)
  File "/p/work2/tmondrag/moose/petsc/config/BuildSystem/config/base.py", line 307, in getExecutable
    self.logWrite('      '+str(os.listdir(d))+'\n')
Finishing configure run at Fri, 24 Jan 2020 17:01:49 -0600
