Hi Matt,
Could you issue MR to get changes from knepley/fix-dm-g2n-serial into PETSc master? I’m having some trouble during PETSc installation withexodusii using your branch, but the master seems fine.
-Gautam.
On Jan 18, 2020, at 11:19 AM, 'Bisht, Gautam' via tdycores-dev <tdycores-dev at googlegroups.com<mailto:tdycores-dev at googlegroups.com>> wrote:
Hi Matt,
Thanks for the fixes to the example.
-Gautam
On Jan 15, 2020, at 7:05 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Jan 15, 2020 at 4:08 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Jan 15, 2020 at 3:47 PM 'Bisht, Gautam' via tdycores-dev <tdycores-dev at googlegroups.com<mailto:tdycores-dev at googlegroups.com>> wrote:
Hi Matt,
I’m running into error while using DMPlexNaturalToGlobalBegin/End and am hoping you have some insights in what I’m doing incorrectly. I create a 2x2x2 grid and distribute it across processors (N=1,2). I create a natural and a global vector; and then call DMPlexNaturalToGlobalBegin/End. Here are the two issues:
- When N = 1, PETSc complains about DMSetUseNatural() not being called before DMPlexDistribute(), which is certainly not the case.
- For N=1 and 2, global vector doesn’t have valid entries.
I’m not sure how to create the natural vector and have used DMCreateGlobalVector() to create the natural vector, which could be the issue.
Attached is the sample code to reproduce the error and below is the screen output.
Cool. I will run it and figure out the problem.
1) There was bad error reporting there. I am putting the fix in a new branch. It did not check for being on one process. If you run with
It will work correctly in serial.
2) The G2N needs a serial data layout to work, so you have to make a Section _before_ distributing. I need to put that in the docs. I have
fixed your example to do this and attached it. I run it with
master *:~/Downloads/tmp/Gautam$ /PETSc3/petsc/bin/mpiexec -n 1 ./ex_test -dm_plex_box_faces 2,2,2 -dm_view
DM Object: 1 MPI processes
type: plex
DM_0x84000000_0 in 3 dimensions:
0-cells: 27
1-cells: 54
2-cells: 36
3-cells: 8
Labels:
marker: 1 strata with value/size (1 (72))
Face Sets: 6 strata with value/size (6 (4), 5 (4), 3 (4), 4 (4), 1 (4), 2 (4))
depth: 4 strata with value/size (0 (27), 1 (54), 2 (36), 3 (8))
Field p:
adjacency FVM++
Natural vector:
Vec Object: 1 MPI processes
type: seq
0.
1.
2.
3.
4.
5.
6.
7.
Global vector:
type: seq
0.
1.
2.
3.
4.
5.
6.
7.
Information about the mesh:
[0] cell = 00; (0.250000, 0.250000, 0.250000); is_local = 1
[0] cell = 01; (0.750000, 0.250000, 0.250000); is_local = 1
[0] cell = 02; (0.250000, 0.750000, 0.250000); is_local = 1
[0] cell = 03; (0.750000, 0.750000, 0.250000); is_local = 1
[0] cell = 04; (0.250000, 0.250000, 0.750000); is_local = 1
[0] cell = 05; (0.750000, 0.250000, 0.750000); is_local = 1
[0] cell = 06; (0.250000, 0.750000, 0.750000); is_local = 1
[0] cell = 07; (0.750000, 0.750000, 0.750000); is_local = 1
master *:~/Downloads/tmp/Gautam$ /PETSc3/petsc/bin/mpiexec -n 2 ./ex_test -dm_plex_box_faces 2,2,2 -dm_view
DM Object: Parallel Mesh 2 MPI processes
type: plex
Parallel Mesh in 3 dimensions:
0-cells: 27 27
1-cells: 54 54
2-cells: 36 36
3-cells: 8 8
Labels:
Face Sets: 6 strata with value/size (1 (4), 2 (4), 3 (4), 4 (4), 5 (4), 6 (4))
Field p:
adjacency FVM++
Natural vector:
Vec Object: 2 MPI processes
type: mpi
Process [0]
0.
1.
2.
3.
Process [1]
4.
5.
6.
7.
Global vector:
type: mpi
Process [0]
2.
3.
6.
7.
Process [1]
0.
1.
4.
5.
[0] cell = 00; (0.250000, 0.750000, 0.250000); is_local = 1
[0] cell = 01; (0.750000, 0.750000, 0.250000); is_local = 1
[0] cell = 02; (0.250000, 0.750000, 0.750000); is_local = 1
[0] cell = 03; (0.750000, 0.750000, 0.750000); is_local = 1
[0] cell = 04; (0.250000, 0.250000, 0.250000); is_local = 0
[0] cell = 05; (0.750000, 0.250000, 0.250000); is_local = 0
[0] cell = 06; (0.250000, 0.250000, 0.750000); is_local = 0
[0] cell = 07; (0.750000, 0.250000, 0.750000); is_local = 0
[1] cell = 00; (0.250000, 0.250000, 0.250000); is_local = 1
[1] cell = 01; (0.750000, 0.250000, 0.250000); is_local = 1
[1] cell = 02; (0.250000, 0.250000, 0.750000); is_local = 1
[1] cell = 03; (0.750000, 0.250000, 0.750000); is_local = 1
[1] cell = 04; (0.250000, 0.750000, 0.250000); is_local = 0
[1] cell = 05; (0.750000, 0.750000, 0.250000); is_local = 0
[1] cell = 06; (0.250000, 0.750000, 0.750000); is_local = 0
[1] cell = 07; (0.750000, 0.750000, 0.750000); is_local = 0
Matt
Matt
>make ex_test
>$PETSC_DIR/$PETSC_ARCH/bin/mpiexec -np 1 ./ex_test
Natural vector:
type: seq
0.
1.
2.
3.
4.
5.
6.
7.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: DM global to natural SF was not created.
You must call DMSetUseNatural() before DMPlexDistribute().
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html<https://protect2.fireeye.com/v1/url?k=49ab253e-151e1a87-49ab0f2b-0cc47adc5fce-24c0c8c46a909b39&q=1&e=e8c1de75-1fa2-4cdd-a1a0-86a8a8811e0a&u=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fdocumentation%2Ffaq.html> for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.12.2-537-g5f77d1e0e5 GIT Date: 2019-12-21 14:33:27 -0600
[0]PETSC ERROR: ./ex_test on a darwin-gcc8 named WE37411 by bish218 Wed Jan 15 12:34:03 2020
[0]PETSC ERROR: Configure options --with-blaslapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate --download-parmetis=yes --download-metis=yes --with-hdf5-dir=/opt/local --download-zlib --download-exodusii=yes --download-hdf5=yes --download-netcdf=yes --download-pnetcdf=yes --download-hypre=yes --download-mpich=yes --download-mumps=yes --download-scalapack=yes --with-cc=/opt/local/bin/gcc-mp-8 --with-cxx=/opt/local/bin/g++-mp-8 --with-fc=/opt/local/bin/gfortran-mp-8 --download-sowing=1 PETSC_ARCH=darwin-gcc8
[0]PETSC ERROR: #1 DMPlexNaturalToGlobalBegin() line 289 in /Users/bish218/projects/petsc/petsc_v3.12.2/src/dm/impls/plex/plexnatural.c
Global vector:
type: seq
0.
0.
0.
0.
0.
0.
0.
0.
Rank = 0
local_id = 00; (0.250000, 0.250000, 0.250000); is_local = 1
local_id = 01; (0.750000, 0.250000, 0.250000); is_local = 1
local_id = 02; (0.250000, 0.750000, 0.250000); is_local = 1
local_id = 03; (0.750000, 0.750000, 0.250000); is_local = 1
local_id = 04; (0.250000, 0.250000, 0.750000); is_local = 1
local_id = 05; (0.750000, 0.250000, 0.750000); is_local = 1
local_id = 06; (0.250000, 0.750000, 0.750000); is_local = 1
local_id = 07; (0.750000, 0.750000, 0.750000); is_local = 1
>$PETSC_DIR/$PETSC_ARCH/bin/mpiexec -np 2 ./ex_test
Natural vector:
type: mpi
Process [0]
0.
1.
2.
3.
Process [1]
4.
5.
6.
7.
Global vector:
type: mpi
Process [0]
0.
0.
0.
0.
Process [1]
0.
0.
0.
0.
Rank = 0
local_id = 00; (0.250000, 0.750000, 0.250000); is_local = 1
local_id = 01; (0.750000, 0.750000, 0.250000); is_local = 1
local_id = 02; (0.250000, 0.750000, 0.750000); is_local = 1
local_id = 03; (0.750000, 0.750000, 0.750000); is_local = 1
local_id = 04; (0.250000, 0.250000, 0.250000); is_local = 0
local_id = 05; (0.750000, 0.250000, 0.250000); is_local = 0
local_id = 06; (0.250000, 0.250000, 0.750000); is_local = 0
local_id = 07; (0.750000, 0.250000, 0.750000); is_local = 0
Rank = 1
local_id = 02; (0.250000, 0.250000, 0.750000); is_local = 1
local_id = 03; (0.750000, 0.250000, 0.750000); is_local = 1
local_id = 04; (0.250000, 0.750000, 0.250000); is_local = 0
local_id = 05; (0.750000, 0.750000, 0.250000); is_local = 0
local_id = 06; (0.250000, 0.750000, 0.750000); is_local = 0
local_id = 07; (0.750000, 0.750000, 0.750000); is_local = 0
-Gautam
On Jan 9, 2020, at 4:57 PM, 'Bisht, Gautam' via tdycores-dev <tdycores-dev at googlegroups.com<mailto:tdycores-dev at googlegroups.com>> wrote:
On Jan 9, 2020, at 4:25 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Thu, Jan 9, 2020 at 1:35 PM 'Bisht, Gautam' via tdycores-dev <tdycores-dev at googlegroups.com<mailto:tdycores-dev at googlegroups.com>> wrote:
> On Jan 9, 2020, at 2:58 PM, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
> "'Bisht, Gautam' via tdycores-dev" <tdycores-dev at googlegroups.com<mailto:tdycores-dev at googlegroups.com>> writes:
>>> Do you need to rely on the element number, or would coordinates (of a
>>> centroid?) be sufficient for your purposes?
>> I do need to rely on the element number. In my case, I have a mapping file that remaps data from one grid onto another grid. Though I’m currently creating a hexahedron mesh, in the future I would be reading in an unstructured grid from a file for which I cannot rely on coordinates.
> How does the mapping file work and how is it generated?
In CESM/E3SM, the mapping file is used to map fluxes or states between grids of two components (e.g. land & atmosphere). The mapping method can be conservative, nearest neighbor, bilinear, etc. While CESM/E3SM uses ESMF_RegridWeightGen to generate the mapping file, I’m using by own MATLAB script to create the mapping file.
I’m surprised that this is not an issue for other codes that are using DMPlex. E.g In PFLOTRAN, when a user creates a custom unstructured grid, they can specify material property for each grid cell. So, there should be a way to create a vectorscatter that will scatter material property read in the “application”-order (i.e. order before calling DMPlexDistribute() ) to ghosted-order (i.e. order after calling DMPlexDistribute()).
We did build something specific for this because some people wanted it. I wish I could purge this from all simulations. Its
definitely destructive, but this is the way the world currently is.
You want this:
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexNaturalToGlobalBegin.html<https://protect2.fireeye.com/v1/url?k=5fd6bd0b-036383c4-5fd6971e-0cc47adc5e60-2156f2075f6da02c&q=1&e=986b333d-b320-4f42-9c3c-fd4c4b3e0e40&u=https%3A%2F%2Fwww.mcs.anl.gov%2Fpetsc%2Fpetsc-current%2Fdocs%2Fmanualpages%2FDMPLEX%2FDMPlexNaturalToGlobalBegin.html>
Perfect.
Thanks.
-Gautam
Matt
> We can locate points and create interpolation with unstructured grids.
> You received this message because you are subscribed to the Google Groups "tdycores-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to tdycores-dev+unsubscribe at googlegroups.com<mailto:tdycores-dev%2Bunsubscribe at googlegroups.com>.
> To view this discussion on the web visit https://protect2.fireeye.com/v1/url?k=b265c01b-eed0fed4-b265ea0e-0cc47adc5e60-1707adbf1790c7e4&q=1&e=0962f8e1-9155-4d9c-abdf-2b6481141cd0&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2F8736come4e.fsf%2540jedbrown.org.
To view this discussion on the web visit https://groups.google.com/d/msgid/tdycores-dev/9AB001AF-8857-446A-AE69-E8D6A25CB8FA%40pnnl.gov<https://protect2.fireeye.com/v1/url?k=711264f2-2da75a3d-71124ee7-0cc47adc5e60-a1731ca51d9b5203&q=1&e=4ec2bd09-0f1d-461c-bde7-4a0d8446ce3d&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2F9AB001AF-8857-446A-AE69-E8D6A25CB8FA%2540pnnl.gov>.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
To unsubscribe from this group and stop receiving emails from it, send an email to tdycores-dev+unsubscribe at googlegroups.com<mailto:tdycores-dev+unsubscribe at googlegroups.com>.
To view this discussion on the web visit https://groups.google.com/d/msgid/tdycores-dev/CAMYG4Gm%3DSY%3DyDiYOdBm1j_KZO5NYhu80ZhbFTV23O%2Bv-zVvFnA%40mail.gmail.com<https://protect2.fireeye.com/v1/url?k=ce43b754-92f6899b-ce439d41-0cc47adc5e60-0a864c0f80b4c75d&q=1&e=4ec2bd09-0f1d-461c-bde7-4a0d8446ce3d&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2FCAMYG4Gm%253DSY%253DyDiYOdBm1j_KZO5NYhu80ZhbFTV23O%252Bv-zVvFnA%2540mail.gmail.com%3Futm_medium%3Demail%26utm_source%3Dfooter>.
To view this discussion on the web visit https://groups.google.com/d/msgid/tdycores-dev/7C23ABBA-2F76-4EAB-9834-9391AD77E18B%40pnnl.gov<https://protect2.fireeye.com/v1/url?k=365c6512-6ae95bdd-365c4f07-0cc47adc5e60-f9b3b6f5e8918ac5&q=1&e=986b333d-b320-4f42-9c3c-fd4c4b3e0e40&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2F7C23ABBA-2F76-4EAB-9834-9391AD77E18B%2540pnnl.gov%3Futm_medium%3Demail%26utm_source%3Dfooter>.
To view this discussion on the web visit https://groups.google.com/d/msgid/tdycores-dev/8A7925AE-08F5-4F81-AAA5-B2FDC3D833B0%40pnnl.gov<https://protect2.fireeye.com/v1/url?k=d941301d-85f40fa4-d9411a08-0cc47adc5fce-ae3accbb18dd8e05&q=1&e=e8c1de75-1fa2-4cdd-a1a0-86a8a8811e0a&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2F8A7925AE-08F5-4F81-AAA5-B2FDC3D833B0%2540pnnl.gov%3Futm_medium%3Demail%26utm_source%3Dfooter>.
-- Norbert Wiener
-- Norbert Wiener
To view this discussion on the web visit https://groups.google.com/d/msgid/tdycores-dev/CAMYG4Gn%3DxsVjjN8sX6km8ub%3Djkk8vxiU2DZVEi-4Kpbi_rM-0w%40mail.gmail.com<https://protect2.fireeye.com/v1/url?k=bae87786-e65d483f-bae85d93-0cc47adc5fce-c50576531e121267&q=1&e=e8c1de75-1fa2-4cdd-a1a0-86a8a8811e0a&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2FCAMYG4Gn%253DxsVjjN8sX6km8ub%253Djkk8vxiU2DZVEi-4Kpbi_rM-0w%2540mail.gmail.com%3Futm_medium%3Demail%26utm_source%3Dfooter>.
<ex_test.c>
To view this discussion on the web visit https://groups.google.com/d/msgid/tdycores-dev/3F79926B-D567-4592-8E4E-46D21628D2DF%40pnnl.gov<https://protect2.fireeye.com/v1/url?k=24802983-7835163a-24800396-0cc47adc5fce-dc4bfcfa4b93062d&q=1&e=d8ec9e84-40ee-4fcf-8e21-5e91bd34392f&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2F3F79926B-D567-4592-8E4E-46D21628D2DF%2540pnnl.gov%3Futm_medium%3Demail%26utm_source%3Dfooter>.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200128/80e46482/attachment-0001.html>
