[petsc-users] Choosing VecScatter Method in Matrix-Vector Product
Felix Huber
st107539 at stud.uni-stuttgart.de
Wed Jan 22 09:11:54 CST 2020
Hello,
I currently investigate why our code does not show the expected weak
scaling behaviour in a CG solver. Therefore I wanted to try out
different communication methods for the VecScatter in the matrix-vector
product. However, it seems like PETSc (version 3.7.6) always chooses
either MPI_Alltoallv or MPI_Alltoallw when I pass different options via
the PETSC_OPTIONS environment variable. Does anybody know, why this
doesn't work as I expected?
The matrix is a MPIAIJ matrix and created by a finite element
discretization of a 3D Laplacian. Therefore it only communicates with
'neighboring' MPI ranks. Not sure if it helps, but the code is run on a
Cray XC40.
I tried the `ssend`, `rsend`, `sendfirst`, `reproduce` and no options
from
https://www.mcs.anl.gov/petsc/petsc-3.7/docs/manualpages/Vec/VecScatterCreate.html
which all result in a MPI_Alltoallv. When combined with `nopack` the
communication uses MPI_Alltoallw.
Best regards,
Felix
