[petsc-users] SNESSetOptionsPrefix usage
Timothée Nicolas timothee.nicolas at gmail.com
Tue Jan 21 04:13:03 CST 2020
I am taking a slightly different path in the development, so I'll answer
later when I come back to that point.
Thanks for your help so far
Cheers
Timothée
Le jeu. 16 janv. 2020 à 15:38, Smith, Barry F. <bsmith at mcs.anl.gov> a
écrit :
> > On Jan 16, 2020, at 3:18 AM, Timothée Nicolas <
> timothee.nicolas at gmail.com> wrote:
> > Actually, for the main solver it works. I'm thinking, could it be due to
> the fact that the second SNES instance is defined in a routine that is
> called somewhere inside the FormFunction of the main SNES? We are improving
> our boundary condition, which becomes quite complex, and we have a small
> problem to solve, so I'm trying to handle it with a SNES. So the two SNES
> are nested, in a sense.
>     This should be fine. We do this.
>      Are you sure the inner SNES is actually being called?
>      Run with -help | grep green does it print a help message for your
> green options?
>      Barry
> > Timothée
> > Le mer. 15 janv. 2020 à 23:24, Timothée Nicolas <
> timothee.nicolas at gmail.com> a écrit :
> > I can actually use some command line arguments. My line arguments
> actually read
> > -snes_mf -green_snes_monitor
> > and the first -snes_mf argument (for the main solver snes) is correctly
> taken into account.
> > I will try what Barry suggested, I'll tell you if I find the reason.
> > Best regards, thanks for your comments
> > Timothée
> > Le mer. 15 janv. 2020 à 18:56, Matthew Knepley <knepley at gmail.com> a
> écrit :
> > I think that Mark is suggesting that no command line arguments are
> getting in.
> > Timothee,
> > Can you use any command line arguments?
> >   Thanks,
> >      Matt
> > On Wed, Jan 15, 2020 at 12:04 PM Smith, Barry F. via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> >   Should still work. Run in the debugger and put a break point in
> snessetoptionsprefix_ and see what it is trying to do
> >   Barry
> > > On Jan 15, 2020, at 8:58 AM, Timothée Nicolas <
> > > Hi, thanks for your answer,
> > > I'm using Petsc version 3.10.4
> > > Timothée
> > > Le mer. 15 janv. 2020 à 14:59, Mark Adams <mfadams at lbl.gov> a écrit :
> > > I'm guessing a Fortran issue. What version of PETSc are you using?
> > > On Wed, Jan 15, 2020 at 8:36 AM Timothée Nicolas <
> > > Dear PETSc users,
> > > I am confused by the usage of SNESSetOptionsPrefix. I understand this
> is required if you have for example different SNES in your program and want
> to set different options for them.
> > > So for my second snes I wrote
> > > call SNESCreate(MPI_COMM_SELF,snes,ierr)
> > > call SNESSetOptionsPrefix(snes,'green_',ierr)
> > > call SNESSetFromOptions(snes,ierr)
> > > etc.
> > > Then when launching the program I wanted to monitor that snes so I
> launched it with the option -green_snes_monitor instead of -snes_monitor.
> But I keep getting the message
> > > WARNING! There are options you set that were not used!
> > > WARNING! could be spelling mistake, etc!
> > > Option left: name:-green_snes_monitor (no value)
> > > What do I miss here?
> > > Best regards
> > > Timothée NICOLAS
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200121/ff058a8a/attachment.html>
