[petsc-users] DMDA Error
Dave May dave.mayhem23 at gmail.com
Tue Jan 21 03:02:16 CST 2020
Hi Anthony,
On Tue, 21 Jan 2020 at 08:25, Anthony Jourdon <jourdon_anthony at hotmail.fr>
wrote:
> Hello,
> I made a test to try to reproduce the error.
> To do so I modified the file $PETSC_DIR/src/dm/examples/tests/ex35.c
> I attach the file in case of need.
> The same error is reproduced for 1024 mpi ranks. I tested two problem
> sizes (2*512+1x2*64+1x2*256+1 and 2*1024+1x2*128+1x2*512+1) and the error
> occured for both cases, the first case is also the one I used to run before
> the OS and mpi updates.
> I also run the code with -malloc_debug and nothing more appeared.
> I attached the configure command I used to build a debug version of petsc.
The error indicates the problem occurs on the bold line below (e.g. within
MPI_Isend())
  /* Post the Isends with the message length-info */
  for (i=0,j=0; i<size; ++i) {
    if (ilengths[i]) {
*      ierr =
MPI_Isend((void*)(ilengths+i),1,MPI_INT,i,tag,comm,s_waits+j);CHKERRQ(ierr);*
      j++;
The type of ilengths[i] is PetscMPIInt, which is always typedef'd to int
inside PETSc.
I don't see how any integer mis-match (int vs long int) can be occurring so
I'm puzzled what the problem is.
Weird...
Thanks
Dave
> Thank you for your time,
> Sincerly.
> Anthony Jourdon
> *De :* Zhang, Junchao <jczhang at mcs.anl.gov>
> *Envoyé :* jeudi 16 janvier 2020 16:49
> *À :* Anthony Jourdon <jourdon_anthony at hotmail.fr>
> *Cc :* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Objet :* Re: [petsc-users] DMDA Error
> It seems the problem is triggered by DMSetUp. You can write a small test
> creating the DMDA with the same size as your code, to see if you can
> reproduce the problem. If yes, it would be much easier for us to debug it.
> --Junchao Zhang
> On Thu, Jan 16, 2020 at 7:38 AM Anthony Jourdon <
> jourdon_anthony at hotmail.fr> wrote:
> Dear Petsc developer,
> I need assistance with an error.
> I run a code that uses the DMDA related functions. I'm using petsc-3.8.4.
> This code used to run very well on a super computer with the OS SLES11.
> Petsc was built using an intel mpi 5.1.3.223 module and intel mkl version
> 2016.0.2.181
> The code was running with no problem on 1024 and more mpi ranks.
> Recently, the OS of the computer has been updated to RHEL7
> I rebuilt Petsc using new available versions of intel mpi (2019U5) and mkl
> (2019.0.5.281) which are the same versions for compilers and mkl.
> Since then I tested to run the exact same code on 8, 16, 24, 48, 512 and
> 1024 mpi ranks.
> Until 1024 mpi ranks no problem, but for 1024 an error related to DMDA
> appeared. I snip the first lines of the error stack here and the full error
> stack is attached.
> [534]PETSC ERROR: #1 PetscGatherMessageLengths() line 120 in
> /scratch2/dlp/appli_local/SCR/OROGEN/petsc3.8.4_MPI/petsc-3.8.4/src/sys/utils/mpimesg.c
> [534]PETSC ERROR: #2 VecScatterCreate_PtoS() line 2288 in
> /scratch2/dlp/appli_local/SCR/OROGEN/petsc3.8.4_MPI/petsc-3.8.4/src/vec/vec/utils/vpscat.c
> [534]PETSC ERROR: #3 VecScatterCreate() line 1462 in
> /scratch2/dlp/appli_local/SCR/OROGEN/petsc3.8.4_MPI/petsc-3.8.4/src/vec/vec/utils/vscat.c
> [534]PETSC ERROR: #4 DMSetUp_DA_3D() line 1042 in
> /scratch2/dlp/appli_local/SCR/OROGEN/petsc3.8.4_MPI/petsc-3.8.4/src/dm/impls/da/da3.c
> [534]PETSC ERROR: #5 DMSetUp_DA() line 25 in
> /scratch2/dlp/appli_local/SCR/OROGEN/petsc3.8.4_MPI/petsc-3.8.4/src/dm/impls/da/dareg.c
> [534]PETSC ERROR: #6 DMSetUp() line 720 in
> /scratch2/dlp/appli_local/SCR/OROGEN/petsc3.8.4_MPI/petsc-3.8.4/src/dm/interface/dm.c
> Sincerly,
> Anthony Jourdon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200121/e66b02a2/attachment.html>
