[petsc-users] error handling
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Jan 20 18:06:23 CST 2020
Sam,
I am not sure what your goal is but PETSc error return codes are error return codes not exceptions. They mean that something catastrophic happened and there is no recovery.
Note that PETSc solvers do not return nonzero error codes on failure to converge etc. You call, for example, KPSGetConvergedReason() after a KSP solve to see if it has failed, this is not a catastrophic failure. If a MatCreate() or any other call returns a nonzero ierr the game is up, you cannot continue running PETSc.
Barry
> On Jan 20, 2020, at 5:41 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Not if you initialize the pointers to zero: Mat A = NULL.
> Matt
> On Mon, Jan 20, 2020 at 6:31 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> I mean MatDestroy.
> On Mon, Jan 20, 2020 at 3:28 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Does it hurt to call Destroy function without calling CreateFunction? For example
> Mat A, B;
> PetscErrorCode ierr1, ierr2;
> ierr1 = MatCreate(PETSC_COMM_WORLD,&A);
> if(ierr1 == 0)
> ierr2 = MatCreate(PETSC_COMM_WORLD
> ,&B);
> if(ierr1 !=0 || ierr2 != 0)
> Destroy(&A);
> Destroy(&B); // if ierr1 !=0, MatCreat is not called on B. Does it hurt to call Destroy B here?
> On Mon, Jan 20, 2020 at 11:11 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Mon 20. Jan 2020 at 19:47, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Can I assume if there is MatCreat or VecCreate, I should clean up the memory myself?
> Yes. You will need to call the matching Destroy function.
> On Mon, Jan 20, 2020 at 10:45 AM Sam Guo <sam.guo at cd-adapco.com> wrote:
> I only include the first few lines of SLEPc example. What about following
> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,n,n);CHKERRQ(ierr);
> Is there any memory lost?
> On Mon, Jan 20, 2020 at 10:41 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Mon 20. Jan 2020 at 19:39, Sam Guo <sam.guo at cd-adapco.com> wrote:
> I don't have a specific case yet. Currently every call of PETSc is checked. If ierr is not zero, print the error and return. For example,
> Mat A; /* problem matrix */
> EPS eps; /* eigenproblem solver context */
> EPSType type;
> PetscReal error,tol,re,im;
> PetscScalar kr,ki; Vec xr,xi; 25
> PetscInt n=30,i,Istart,Iend,nev,maxit,its,nconv;
> PetscErrorCode ierr;
> ierr = SlepcInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);
> ierr = PetscOptionsGetInt(NULL,NULL,"-n",&n,NULL);CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_WORLD,"\n1-D Laplacian Eigenproblem, n=%D\n\n",n);CHKERRQ(ierr);
> I am wondering if the memory is lost by calling CHKERRQ.
> No.
> On Mon, Jan 20, 2020 at 10:14 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Mon 20. Jan 2020 at 19:11, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Dear PETSc dev team,
> If PETSc function returns an error, what's the correct way to clean PETSc?
> The answer depends on the error message reported. Send the complete error message and a better answer can be provided.
> Particularly how to clean up the memory?
> Totally depends on the objects which aren’t being freed. You need to provide more information
> Thanks
> Dave
> Thanks,
> Sam
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
