[petsc-users] chowiluviennacl
Mills, Richard Tran
rtmills at anl.gov
Mon Jan 20 16:41:40 CST 2020
Hi Xiangdong,
Maybe I am misunderstanding you, but it sounds like you want an exact direct solution, so I don't understand why you are using an incomplete factorization solver for this. SuperLU_DIST (as Mark has suggested) or MUMPS are two such packages that provide MPI-parallel sparse LU factorization. If you need GPU support, SuperLU_DIST has such support. I don't know the status of our support for using the GPU capabilities of this, though -- I assume another developer can chime in regarding this.
Note that the ILU provided by "chowiluiennacl" employs a very different algorithm than the standard PCILU in PETSc, and you shouldn't expect to get the same incomplete factorization. The algorithm is described in this paper by Chow and Patel:
https://www.cc.gatech.edu/~echow/pubs/parilu-sisc.pdf
Best regards,
Richard
On 1/15/20 11:39 AM, Xiangdong wrote:
I just submitted the issue: https://gitlab.com/petsc/petsc/issues/535
What I really want is an exact Block Tri-diagonal solver on GPU. Since for block tridiagonal system, ILU0 would be the same as ILU. So I tried the chowiluviennacl. but I found that the default parameters does not produce the same ILU0 factorization as the CPU ones (PCILU). My guess is that if I increase the number of sweeps chow_patel_ilu_config.sweeps(3), it may give a better result. So the option Keys would be helpful.
Since Mark mentioned the Superlu's GPU feature, can I use superlu or hypre's GPU functionality through PETSc?
Thank you.
Xiangdong
On Wed, Jan 15, 2020 at 2:22 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Jan 15, 2020 at 1:48 PM Xiangdong <epscodes at gmail.com<mailto:epscodes at gmail.com>> wrote:
In the ViennaCL manual http://viennacl.sourceforge.net/doc/manual-algorithms.html
It did expose two parameters:
// configuration of preconditioner:
viennacl::linalg::chow_patel_tag chow_patel_ilu_config;
chow_patel_ilu_config.sweeps(3); // three nonlinear sweeps
chow_patel_ilu_config.jacobi_iters(2); // two Jacobi iterations per triangular 'solve' Rx=r
and mentioned that:
The number of nonlinear sweeps and Jacobi iterations need to be set problem-specific for best performance.
In the PETSc' implementation:
viennacl::linalg::chow_patel_tag ilu_tag;
ViennaCLAIJMatrix *mat = (ViennaCLAIJMatrix*)gpustruct->mat;
ilu->CHOWILUVIENNACL = new viennacl::linalg::chow_patel_ilu_precond<viennacl::compressed_matrix<PetscScalar> >(*mat, ilu_tag);
The default is used. Is it possible to expose these two parameters so that user can change it through option keys?
Yes. Do you mind making an issue for it? That way we can better keep track.
Matt
Thank you.
Xiangdong
On Wed, Jan 15, 2020 at 12:40 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Jan 15, 2020 at 9:59 AM Xiangdong <epscodes at gmail.com<mailto:epscodes at gmail.com>> wrote:
Maybe I am not clear. I want to solve the block tridiagonal system Tx=b a few times with same T but different b. On CPU, I can have it by applying the ILU0 and reuse the factorization. Since it is block tridiagonal, ILU0 would give same results as LU.
I am trying to do the same thing on GPU with chowiluviennacl, but found default factorization does not produce the exact factorization for tridiagonal system. Can we tight the drop off tolerance so that it can work as LU for tridiagonal system?
There are no options in our implementation. You could look at the ViennaCL manual to see if we missed something.
Matt
Thank you.
Xiangdong
On Wed, Jan 15, 2020 at 9:41 AM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Jan 15, 2020 at 9:36 AM Xiangdong <epscodes at gmail.com<mailto:epscodes at gmail.com>> wrote:
Can chowiluviennacl do ilu0?
I need to solve a tri-diagonal system directly. If I apply the PCILU, I will obtain the exact solution with preonly + pcilu. However, the preonly + chowiluviennacl will not provide the exact solution. Any option keys to set the CHOWILUVIENNACL filling level or dropping off tolerance like the standard ilu?
No. However, such a scheme makes less sense here. This algorithm spawns a individual threads for individual elements. Drop tolerance
is not less work, it is sparser, but that should not matter for a tridiagonal system. Levels also is not applicable since you have only 1 level.
Matt
Thank you.
Best,
Xiangdong
On Tue, Jan 14, 2020 at 10:05 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Tue, Jan 14, 2020 at 9:56 PM Xiangdong <epscodes at gmail.com<mailto:epscodes at gmail.com>> wrote:
Dear Developers,
I have a quick question about the chowiluviennacl. When I tried to use it, I found that it only works for np=1, not np>1. However, in the description of chowiluviennacl.cxx, it says "the ViennaCL Chow-Patel parallel ILU preconditioner".
By parallel, this means shared memory parallelism on the GPU.
I am wondering whether I am using it correctly. Does chowiluviennacl work for np>1?
I do not believe so. I do not see why it could not be extended, but that would mean writing some more code.
Matt
In addition, are there option keys for the chowiluviennacl one can try?
Thank you.
Best,
Xiangdong
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200120/e43e6239/attachment-0001.html>
