[petsc-users] Solver compilation with 64-bit version of PETSc under Windows 10 using Cygwin
Smith, Barry F.
bsmith at mcs.anl.gov
Sat Jan 18 22:47:15 CST 2020
Dmitry,
I have completed and tested the branch barry/2020-01-15/support-default-integer-8 it is undergoing testing now https://gitlab.com/petsc/petsc/merge_requests/2456
Please give it a try. Note that MPI has no support for integer promotion so YOU must insure that any MPI calls from Fortran pass 4 byte integers not promoted 8 byte integers.
I have tested it with recent versions of MPICH and OpenMPI, it is fragile at compile time and may fail to compile with different versions of MPI.
Good luck,
Barry
I do not recommend this approach for integer promotion in Fortran. Just blindly promoting all integers can often lead to problems. I recommend using the kind mechanism of
Fortran to insure that each variable is the type you want, you can recompile with different options to promote the kind declared variables you wish. Of course this is more intrusive and requires changes to the Fortran code.
> On Jan 15, 2020, at 7:00 AM, Дмитрий Мельничук <dmitry.melnichuk at geosteertech.com> wrote:
> Hello all!
> At present time I need to compile solver called Defmod (https://bitbucket.org/stali/defmod/wiki/Home), which is written in Fortran 95.
> Defmod uses PETSc for solving linear algebra system.
> Solver compilation with 32-bit version of PETSc does not cause any problem.
> But solver compilation with 64-bit version of PETSc produces an error with size of ierr PETSc variable.
> 1. For example, consider the following statements written in Fortran:
> PetscErrorCode :: ierr_m
> PetscInt :: ierr
> call VecDuplicate(Vec_U,Vec_Um,ierr)
> call VecCopy(Vec_U,Vec_Um,ierr)
> call VecGetLocalSize(Vec_U,j,ierr)
> call VecGetOwnershipRange(Vec_U,j1,j2,ierr_m)
> As can be seen first three subroutunes require ierr to be size of INTEGER(8), while the last subroutine (VecGetOwnershipRange) requires ierr to be size of INTEGER(4).
> Using the same integer format gives an error:
> There is no specific subroutine for the generic ‘vecgetownershiprange’ at (1)
> 2. Another example is:
> call MatAssemblyBegin(Mat_K,Mat_Final_Assembly,ierr)
> CHKERRA(ierr)
> call MatAssemblyEnd(Mat_K,Mat_Final_Assembly,ierr)
> I am not able to define an appropriate size if ierr in CHKERRA(ierr). If I choose INTEGER(8), the error "Type mismatch in argument ‘ierr’ at (1); passed INTEGER(8) to INTEGER(4)" occurs.
> If I define ierr as INTEGER(4), the error "Type mismatch in argument ‘ierr’ at (1); passed INTEGER(4) to INTEGER(8)" appears.
> 3. If I change the sizes of ierr vaiables as error messages require, the compilation completed successfully, but an error occurs when calculating the RHS vector with following message:
> [0]PETSC ERROR: Out of range index value -4 cannot be negative
> Command to configure 32-bit version of PETSc under Windows 10 using Cygwin:
> ./configure --with-cc=x86_64-w64-mingw32-gcc --with-cxx=x86_64-w64-mingw32-g++ --with-fc=x86_64-w64-mingw32-gfortran --download-fblaslapack --with-mpi-include=/cygdrive/c/MPISDK/Include --with-mpi-lib=/cygdrive/c/MPISDK/Lib/libmsmpi.a --with-mpi-mpiexec=/cygdrive/c/MPI/Bin/mpiexec.exe --with-debugging=yes -CFLAGS='-O2' -CXXFLAGS='-O2' -FFLAGS='-O2 -static-libgfortran -static -lpthread -fno-range-check' --with-shared-libraries=no
> Command to configure 64-bit version of PETSc under Windows 10 using Cygwin:
> ./configure --with-cc=x86_64-w64-mingw32-gcc --with-cxx=x86_64-w64-mingw32-g++ --with-fc=x86_64-w64-mingw32-gfortran --download-fblaslapack --with-mpi-include=/cygdrive/c/MPISDK/Include --with-mpi-lib=/cygdrive/c/MPISDK/Lib/libmsmpi.a --with-mpi-mpiexec=/cygdrive/c/MPI/Bin/mpiexec.exe --with-debugging=yes -CFLAGS='-O2' -CXXFLAGS='-O2' -FFLAGS='-O2 -static-libgfortran -static -lpthread -fno-range-check -fdefault-integer-8' --with-shared-libraries=no --with-64-bit-indices --known-64-bit-blas-indices
> Kind regards,
> Dmitry Melnichuk
