[petsc-users] SNESSetOptionsPrefix usage
    Matthew Knepley
    knepley at gmail.com
    Thu Jan 16 07:36:31 CST 2020
On Thu, Jan 16, 2020 at 4:18 AM Timothée Nicolas <timothee.nicolas at gmail.com>
wrote:
> Actually, for the main solver it works. I'm thinking, could it be due to
> the fact that the second SNES instance is defined in a routine that is
> called somewhere inside the FormFunction of the main SNES? We are improving
> our boundary condition, which becomes quite complex, and we have a small
> problem to solve, so I'm trying to handle it with a SNES. So the two SNES
> are nested, in a sense.
As long as SNESSetFromOptions() is being called, it should function
properly. That is why we want to see it in the debugger.
    Matt
> Timothée
> Le mer. 15 janv. 2020 à 23:24, Timothée Nicolas <
> timothee.nicolas at gmail.com> a écrit :
>> I can actually use some command line arguments. My line arguments
>> actually read
>> -snes_mf -green_snes_monitor
>> and the first -snes_mf argument (for the main solver snes) is correctly
>> taken into account.
>> I will try what Barry suggested, I'll tell you if I find the reason.
>> Best regards, thanks for your comments
>> Timothée
>> Le mer. 15 janv. 2020 à 18:56, Matthew Knepley <knepley at gmail.com> a
>> écrit :
>>> I think that Mark is suggesting that no command line arguments are
>>> getting in.
>>> Timothee,
>>> Can you use any command line arguments?
>>>   Thanks,
>>>      Matt
>>> On Wed, Jan 15, 2020 at 12:04 PM Smith, Barry F. via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>>   Should still work. Run in the debugger and put a break point in
>>>> snessetoptionsprefix_ and see what it is trying to do
>>>>   Barry
>>>> > On Jan 15, 2020, at 8:58 AM, Timothée Nicolas <
>>>> timothee.nicolas at gmail.com> wrote:
>>>> > Hi, thanks for your answer,
>>>> > I'm using Petsc version 3.10.4
>>>> > Timothée
>>>> > Le mer. 15 janv. 2020 à 14:59, Mark Adams <mfadams at lbl.gov> a écrit :
>>>> > I'm guessing a Fortran issue. What version of PETSc are you using?
>>>> > On Wed, Jan 15, 2020 at 8:36 AM Timothée Nicolas <
>>>> > Dear PETSc users,
>>>> > I am confused by the usage of SNESSetOptionsPrefix. I understand this
>>>> is required if you have for example different SNES in your program and want
>>>> to set different options for them.
>>>> > So for my second snes I wrote
>>>> > call SNESCreate(MPI_COMM_SELF,snes,ierr)
>>>> > call SNESSetOptionsPrefix(snes,'green_',ierr)
>>>> > call SNESSetFromOptions(snes,ierr)
>>>> > etc.
>>>> > Then when launching the program I wanted to monitor that snes so I
>>>> launched it with the option -green_snes_monitor instead of -snes_monitor.
>>>> But I keep getting the message
>>>> > WARNING! There are options you set that were not used!
>>>> > WARNING! could be spelling mistake, etc!
>>>> > Option left: name:-green_snes_monitor (no value)
>>>> > What do I miss here?
>>>> > Best regards
>>>> > Timothée NICOLAS
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200116/213d2121/attachment.html>
