[petsc-users] SNESSetOptionsPrefix usage
Timothée Nicolas
timothee.nicolas at gmail.com
Wed Jan 15 16:24:31 CST 2020
I can actually use some command line arguments. My line arguments actually
read
-snes_mf -green_snes_monitor
and the first -snes_mf argument (for the main solver snes) is correctly
taken into account.
I will try what Barry suggested, I'll tell you if I find the reason.
Best regards, thanks for your comments
Timothée
Le mer. 15 janv. 2020 à 18:56, Matthew Knepley <knepley at gmail.com> a écrit :
> I think that Mark is suggesting that no command line arguments are getting
> in.
> Timothee,
> Can you use any command line arguments?
> Thanks,
> Matt
> On Wed, Jan 15, 2020 at 12:04 PM Smith, Barry F. via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Should still work. Run in the debugger and put a break point in
>> snessetoptionsprefix_ and see what it is trying to do
>> Barry
>> > On Jan 15, 2020, at 8:58 AM, Timothée Nicolas <
>> timothee.nicolas at gmail.com> wrote:
>> > Hi, thanks for your answer,
>> > I'm using Petsc version 3.10.4
>> > Timothée
>> > Le mer. 15 janv. 2020 à 14:59, Mark Adams <mfadams at lbl.gov> a écrit :
>> > I'm guessing a Fortran issue. What version of PETSc are you using?
>> > On Wed, Jan 15, 2020 at 8:36 AM Timothée Nicolas <
>> > Dear PETSc users,
>> > I am confused by the usage of SNESSetOptionsPrefix. I understand this
>> is required if you have for example different SNES in your program and want
>> to set different options for them.
>> > So for my second snes I wrote
>> > call SNESCreate(MPI_COMM_SELF,snes,ierr)
>> > call SNESSetOptionsPrefix(snes,'green_',ierr)
>> > call SNESSetFromOptions(snes,ierr)
>> > etc.
>> > Then when launching the program I wanted to monitor that snes so I
>> launched it with the option -green_snes_monitor instead of -snes_monitor.
>> But I keep getting the message
>> > WARNING! There are options you set that were not used!
>> > WARNING! could be spelling mistake, etc!
>> > Option left: name:-green_snes_monitor (no value)
>> > What do I miss here?
>> > Best regards
>> > Timothée NICOLAS
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200115/e431c136/attachment.html>
