[petsc-users] Solver compilation with 64-bit version of PETSc under Windows 10 using Cygwin
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Jan 15 13:34:31 CST 2020
Working on it now; may be doable
> On Jan 15, 2020, at 11:55 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 15, 2020 at 10:26 AM Дмитрий Мельничук <dmitry.melnichuk at geosteertech.com> wrote:
> > And I'm not sure why you are having to use PetscInt for ierr. All PETSc routines should be suing 'PetscErrorCode for ierr'
> If I define ierr as PetscErrorCode for all subroutines given below
> call VecDuplicate(Vec_U,Vec_Um,ierr)
> call VecCopy(Vec_U,Vec_Um,ierr)
> call VecGetLocalSize(Vec_U,j,ierr)
> call VecGetOwnershipRange(Vec_U,j1,j2,ierr)
> then errors occur with first three subroutines:
> Error: Type mismatch in argument «z» at (1); passed INTEGER(4) to INTEGER(8).
> Barry,
> It looks like the ftn-auto interfaces are using 'integer' for the error code, whereas the ftn-custom is using PetscErrorCode.
> Could we make the generated ones use integer?
> Thanks,
> Matt
> Therefore I was forced to define ierr as PetscInt for VecDuplicate, VecCopy, VecGetLocalSize subroutines to fix these errors.
> Why some subroutines sue 8-bytes integer type of ierr (PetscInt), while others - 4-bytes integer type of ierr (PetscErrorCode) remains a mystery for me.
> > What version of PETSc are you using?
> version 3.12.2
> > Are you seeing this issue with a PETSc example?
> I will check it tomorrow and let you know.
> Kind regards,
> Dmitry Melnichuk
> 15.01.2020, 17:14, "Balay, Satish" <balay at mcs.anl.gov>:
> -fdefault-integer-8 is likely to break things [esp with MPI - where 'integer' is used everywhere for ex - MPI_Comm etc - so MPI includes become incompatible with the MPI library with -fdefault-integer-8.]
> What version of PETSc are you using? Are you seeing this issue with a PETSc example?
> Satish
> On Wed, 15 Jan 2020, Дмитрий Мельничук wrote:
> Hello all!
> At present time I need to compile solver called Defmod (https://bitbucket.org/stali/defmod/wiki/Home), which is written in Fortran 95.
> Defmod uses PETSc for solving linear algebra system.
> Solver compilation with 32-bit version of PETSc does not cause any problem.
> But solver compilation with 64-bit version of PETSc produces an error with size of ierr PETSc variable.
> 1. For example, consider the following statements written in Fortran:
> PetscErrorCode :: ierr_m
> PetscInt :: ierr
> call VecGetOwnershipRange(Vec_U,j1,j2,ierr_m)
> As can be seen first three subroutunes require ierr to be size of INTEGER(8), while the last subroutine (VecGetOwnershipRange) requires ierr to be size of INTEGER(4).
> Using the same integer format gives an error:
> There is no specific subroutine for the generic ‘vecgetownershiprange’ at (1)
> 2. Another example is:
> call MatAssemblyBegin(Mat_K,Mat_Final_Assembly,ierr)
> CHKERRA(ierr)
> call MatAssemblyEnd(Mat_K,Mat_Final_Assembly,ierr)
> I am not able to define an appropriate size if ierr in CHKERRA(ierr). If I choose INTEGER(8), the error "Type mismatch in argument ‘ierr’ at (1); passed INTEGER(8) to
> INTEGER(4)" occurs.
> If I define ierr as INTEGER(4), the error "Type mismatch in argument ‘ierr’ at (1); passed INTEGER(4) to INTEGER(8)" appears.
> 3. If I change the sizes of ierr vaiables as error messages require, the compilation completed successfully, but an error occurs when calculating the RHS vector with
> following message:
> [0]PETSC ERROR: Out of range index value -4 cannot be negative
> Command to configure 32-bit version of PETSc under Windows 10 using Cygwin:
> ./configure --with-cc=x86_64-w64-mingw32-gcc --with-cxx=x86_64-w64-mingw32-g++ --with-fc=x86_64-w64-mingw32-gfortran --download-fblaslapack
> --with-mpi-include=/cygdrive/c/MPISDK/Include --with-mpi-lib=/cygdrive/c/MPISDK/Lib/libmsmpi.a --with-mpi-mpiexec=/cygdrive/c/MPI/Bin/mpiexec.exe --with-debugging=yes
> -CFLAGS='-O2' -CXXFLAGS='-O2' -FFLAGS='-O2 -static-libgfortran -static -lpthread -fno-range-check' --with-shared-libraries=no
> Command to configure 64-bit version of PETSc under Windows 10 using Cygwin:./configure --with-cc=x86_64-w64-mingw32-gcc --with-cxx=x86_64-w64-mingw32-g++
> --with-fc=x86_64-w64-mingw32-gfortran --download-fblaslapack --with-mpi-include=/cygdrive/c/MPISDK/Include --with-mpi-lib=/cygdrive/c/MPISDK/Lib/libmsmpi.a
> --with-mpi-mpiexec=/cygdrive/c/MPI/Bin/mpiexec.exe --with-debugging=yes -CFLAGS='-O2' -CXXFLAGS='-O2' -FFLAGS='-O2 -static-libgfortran -static -lpthread -fno-range-check
> -fdefault-integer-8' --with-shared-libraries=no --with-64-bit-indices --known-64-bit-blas-indices
> Kind regards,
> Dmitry Melnichuk
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
