[petsc-users] chowiluviennacl
Mark Adams mfadams at lbl.gov
Wed Jan 15 13:12:10 CST 2020
It sounds like you just want a (MPI) parallel GPU exact solver. SuperLU
will do that.
On Wed, Jan 15, 2020 at 1:50 PM Xiangdong <epscodes at gmail.com> wrote:
> In the ViennaCL manual
> http://viennacl.sourceforge.net/doc/manual-algorithms.html
> It did expose two parameters:
> // configuration of preconditioner:
> viennacl::linalg::chow_patel_tag chow_patel_ilu_config;
> chow_patel_ilu_config.sweeps(3); // three nonlinear sweeps
> chow_patel_ilu_config.jacobi_iters(2); // two Jacobi iterations per
> triangular 'solve' Rx=r
> and mentioned that:
> The number of nonlinear sweeps and Jacobi iterations need to be set
> problem-specific for best performance.
> In the PETSc' implementation:
> viennacl::linalg::chow_patel_tag ilu_tag;
>     ViennaCLAIJMatrix *mat = (ViennaCLAIJMatrix*)gpustruct->mat;
>     ilu->CHOWILUVIENNACL = new
> viennacl::linalg::chow_patel_ilu_precond<viennacl::compressed_matrix<PetscScalar>
> >(*mat, ilu_tag);
> The default is used. Is it possible to expose these two parameters so that
> user can change it through option keys?
> Thank you.
> Xiangdong
> On Wed, Jan 15, 2020 at 12:40 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jan 15, 2020 at 9:59 AM Xiangdong <epscodes at gmail.com> wrote:
>>> Maybe I am not clear. I want to solve the block tridiagonal system  Tx=b
>>> a few times with same T but different b. On CPU, I can have it by applying
>>> the ILU0 and reuse the factorization. Since it is block tridiagonal, ILU0
>>> would give same results as LU.
>>> I am trying to do the same thing on GPU with chowiluviennacl, but found
>>> default factorization does not produce the exact factorization for
>>> tridiagonal system. Can we tight the drop off tolerance so that it can work
>>> as LU for tridiagonal system?
>> There are no options in our implementation. You could look at the
>> ViennaCL manual to see if we missed something.
>>   Thanks,
>>     Matt
>>> Thank you.
>>> Xiangdong
>>> On Wed, Jan 15, 2020 at 9:41 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Jan 15, 2020 at 9:36 AM Xiangdong <epscodes at gmail.com> wrote:
>>>>> Can chowiluviennacl do ilu0?
>>>>> I need to solve a tri-diagonal system directly. If I apply the PCILU,
>>>>> I will obtain the exact solution with preonly + pcilu. However, the
>>>>> preonly + chowiluviennacl will not provide the exact solution. Any option
>>>>> keys to set the CHOWILUVIENNACL filling level or dropping off tolerance
>>>>> like the standard ilu?
>>>> No. However, such a scheme makes less sense here. This algorithm spawns
>>>> a individual threads for individual elements. Drop tolerance
>>>> is not less work, it is sparser, but that should not matter for a
>>>> tridiagonal system. Levels also is not applicable since you have only 1
>>>> level.
>>>>   Thanks,
>>>>     Matt
>>>>> Thank you.
>>>>> Best,
>>>>> Xiangdong
>>>>> On Tue, Jan 14, 2020 at 10:05 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Tue, Jan 14, 2020 at 9:56 PM Xiangdong <epscodes at gmail.com> wrote:
>>>>>>> Dear Developers,
>>>>>>> I have a quick question about the chowiluviennacl. When I tried to
>>>>>>> use it, I found that it only works for np=1, not np>1. However, in the
>>>>>>> description of chowiluviennacl.cxx, it says "the ViennaCL Chow-Patel
>>>>>>> parallel ILU preconditioner".
>>>>>> By parallel, this means shared memory parallelism on the GPU.
>>>>>>> I am wondering whether I am using it correctly. Does chowiluviennacl
>>>>>>> work for np>1?
>>>>>> I do not believe so. I do not see why it could not be extended, but
>>>>>> that would mean writing some more code.
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> In addition, are there option keys for the chowiluviennacl one can
>>>>>>> try?
>>>>>>> Thank you.
>>>>>>> Best,
>>>>>>> Xiangdong
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200115/89cc9360/attachment.html>
