[petsc-users] error related to nested vector
    Matthew Knepley
    knepley at gmail.com
    Tue Jan 14 05:53:38 CST 2020
It says that memory is being overwritten somewhere. You can track this down
using valgrind,
as it suggests in the error message.
     Matt
On Tue, Jan 14, 2020 at 5:44 AM Y. Shidi <ys453 at cam.ac.uk> wrote:
> Dear developers,
> I have a 2x2 nested matrix and the corresponding nested vector.
> When I running the code with field splitting, it gets the following
> errors:
> [0]PETSC ERROR: PetscTrFreeDefault() called from VecRestoreArray_Nest()
> line 678 in /home/ys453/Sources/petsc/src/vec/vec/impls/nest/vecnest.c
> [0]PETSC ERROR: Block at address 0x3f95f60 is corrupted; cannot free;
> may be block not allocated with PetscMalloc()
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Memory corruption:
> http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
> [0]PETSC ERROR: Bad location or corrupted memory
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.3, unknown
> [0]PETSC ERROR: 2DPetscSpuriousTest on a arch-linux2-c-debug named
> merlin by ys453 Tue Jan 14 10:36:53 2020
> [0]PETSC ERROR: Configure options --download-scalapack --download-mumps
> --download-parmetis --download-metis --download-ptscotch
> --download-superlu_dist --download-hypre
> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 269 in
> /home/ys453/Sources/petsc/src/sys/memory/mtr.c
> [0]PETSC ERROR: #2 VecRestoreArray_Nest() line 678 in
> [0]PETSC ERROR: #3 VecRestoreArrayRead() line 1835 in
> /home/ys453/Sources/petsc/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: #4 VecRestoreArrayPair() line 511 in
> /home/ys453/Sources/petsc/include/petscvec.h
> [0]PETSC ERROR: #5 VecScatterBegin_SSToSS() line 671 in
> /home/ys453/Sources/petsc/src/vec/vscat/impls/vscat.c
> [0]PETSC ERROR: #6 VecScatterBegin() line 1779 in
> [0]PETSC ERROR: #7 PCApply_FieldSplit() line 1010 in
> /home/ys453/Sources/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #8 PCApply() line 457 in
> /home/ys453/Sources/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #9 KSP_PCApply() line 276 in
> /home/ys453/Sources/petsc/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #10 KSPFGMRESCycle() line 166 in
> /home/ys453/Sources/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
> [0]PETSC ERROR: #11 KSPSolve_FGMRES() line 291 in
> [0]PETSC ERROR: #12 KSPSolve() line 669 in
> /home/ys453/Sources/petsc/src/ksp/ksp/interface/itfunc.c
> I am not sure why it happens.
> Thank you for your time.
> Kind Regards,
> Shidi
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200114/6a266a2e/attachment.html>
