[petsc-users] killed 9 signal after upgrade from petsc 3.9.4 to 3.12.2
Santiago Andres Triana
repepo at gmail.com
Fri Jan 10 13:57:31 CST 2020
Dear all,
I ran the program with valgrind --tool=massif, the results are cryptic to
me ... not sure who's the memory hog! the logs are attached.
The command I used is:
mpiexec -n 24 valgrind --tool=massif --num-callers=20
--log-file=valgrind.log.%p ./ex7 -f1 A.petsc -f2 B.petsc -eps_nev 1 $opts
-eps_target -4.008e-3+1.57142i -eps_target_magnitude -eps_tol 1e-14
Is there any possibility to install a version of superlu_dist (or mumps)
different from what the petsc version automatically downloads?
Thanks!
Santiago
On Thu, Jan 9, 2020 at 10:04 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> This kind of issue is difficult to untangle because you have potentially
> three pieces of software which might have changed between v3.9 and v3.12,
> namely
> PETSc, SLEPC and SuperLU_dist.
> You need to isolate which software component is responsible for the 2x
> increase in memory.
> When I look at the memory usage in the log files, things look very very
> similar for the raw PETSc objects.
> [v3.9]
> --- Event Stage 0: Main Stage
> Viewer 4 3 2520 0.
> Matrix 15 15 125236536 0.
> Vector 22 22 19713856 0.
> Index Set 10 10 995280 0.
> Vec Scatter 4 4 4928 0.
> EPS Solver 1 1 2276 0.
> Spectral Transform 1 1 848 0.
> Basis Vectors 1 1 2168 0.
> PetscRandom 1 1 662 0.
> Region 1 1 672 0.
> Direct Solver 1 1 17440 0.
> Krylov Solver 1 1 1176 0.
> Preconditioner 1 1 1000 0.
> versus
> [v3.12]
> Viewer 4 3 2520 0.
> Matrix 15 15 125237144 0.
> Vector 22 22 19714528 0.
> Index Set 10 10 995096 0.
> Vec Scatter 4 4 3168 0.
> Star Forest Graph 4 4 3936 0.
> EPS Solver 1 1 2292 0.
> Basis Vectors 1 1 2184 0.
> Region 1 1 672 0.
> Direct Solver 1 1 17456 0.
> Krylov Solver 1 1 1400 0.
> Certainly there is no apparent factor 2x increase in memory usage in the
> underlying petsc objects themselves.
> Furthermore, the counts of creations of petsc objects in toobig.log and
> justfine.log match, indicating that none of the implementations used in
> either PETSc or SLEPc have fundamentally changed wrt the usage of the
> native petsc objects.
> It is also curious that VecNorm is called 3 times in "justfine.log" and 19
> times in "toobig.log" - although I don't see how that could be related to
> you problem...
> The above at least gives me the impression that issue of memory increase
> is likely not coming from PETSc.
> I just read Barry's useful email which is even more compelling and also
> indicates SLEPc is not the likely culprit either as it uses PetscMalloc()
> internally.
> Some options to identify the problem:
> 1/ Eliminate SLEPc as a possible culprit by not calling EPSSolve() and
> rather just call KSPSolve() with some RHS vector.
> * If you still see a 2x increase, switch the preconditioner to using
> -pc_type bjacobi -ksp_max_it 10 rather than superlu_dist.
> If the memory usage is good, you can be pretty certain the issue arises
> internally to superl_dist.
> 2/ Leave your code as is and perform your profiling using mumps rather
> than superlu_dist.
> This is a less reliable test than 1/ since the mumps implementation used
> with v3.9 and v3.12 may differ...
> Thanks
> Dave
> On Thu, 9 Jan 2020 at 20:17, Santiago Andres Triana <repepo at gmail.com>
> wrote:
>> Dear all,
>> I think parmetis is not involved since I still run out of memory if I use
>> the following options:
>> export opts='-st_type sinvert -st_ksp_type preonly -st_pc_type lu
>> -st_pc_factor_mat_solver_type superlu_dist -eps_true_residual 1'
>> and issuing:
>> mpiexec -n 24 ./ex7 -f1 A.petsc -f2 B.petsc -eps_nev 1 -eps_target
>> -4.008e-3+1.57142i $opts -eps_target_magnitude -eps_tol 1e-14 -memory_view
>> Bottom line is that the memory usage of petsc-3.9.4 / slepc-3.9.2 is much
>> lower than current version. I can only solve relatively small problems
>> using the 3.12 series :(
>> I have an example with smaller matrices that will likely fail in a 32 Gb
>> ram machine with petsc-3.12 but runs just fine with petsc-3.9. The
>> -memory_view output is
>> with petsc-3.9.4: (log 'justfine.log' attached)
>> Summary of Memory Usage in PETSc
>> Maximum (over computational time) process memory: total 1.6665e+10
>> max 7.5674e+08 min 6.4215e+08
>> Current process memory: total 1.5841e+10
>> max 7.2881e+08 min 6.0905e+08
>> Maximum (over computational time) space PetscMalloc()ed: total 3.1290e+09
>> max 1.5868e+08 min 1.0179e+08
>> Current space PetscMalloc()ed: total 1.8808e+06
>> max 7.8368e+04 min 7.8368e+04
>> with petsc-3.12.2: (log 'toobig.log' attached)
>> Maximum (over computational time) process memory: total 3.1564e+10
>> max 1.3662e+09 min 1.2604e+09
>> Current process memory: total 3.0355e+10
>> max 1.3082e+09 min 1.2254e+09
>> Maximum (over computational time) space PetscMalloc()ed: total 2.7618e+09
>> max 1.4339e+08 min 8.6493e+07
>> Current space PetscMalloc()ed: total 3.6127e+06
>> max 1.5053e+05 min 1.5053e+05
>> Strangely, monitoring with 'top' I can see *appreciably higher* peak
>> memory use, usually twice what -memory_view ends up reporting, both for
>> petsc-3.9.4 and current. Program fails usually at this peak if not enough
>> ram available
>> The matrices for the example quoted above can be downloaded here (I use
>> slepc's tutorial ex7.c to solve the problem):
>> https://www.dropbox.com/s/as9bec9iurjra6r/A.petsc?dl=0 (about 600 Mb)
>> https://www.dropbox.com/s/u2bbmng23rp8l91/B.petsc?dl=0 (about 210 Mb)
>> I haven't been able to use a debugger successfully since I am using a
>> compute node without the possibility of an xterm ... note that I have no
>> experience using a debugger so any help on that will also be appreciated!
>> Hope I can switch to the current petsc/slepc version for my production
>> runs soon...
>> Thanks again!
>> Santiago
>> On Thu, Jan 9, 2020 at 4:25 PM Stefano Zampini <stefano.zampini at gmail.com>
>> wrote:
>>> Can you reproduce the issue with smaller matrices? Or with a debug build
>>> (i.e. using —with-debugging=1 and compilation flags -02 -g)?
>>> The only changes in parmetis between the two PETSc releases are these
>>> below, but I don’t see how they could cause issues
>>> kl-18448:pkg-parmetis szampini$ git log -2
>>> commit ab4fedc6db1f2e3b506be136e3710fcf89ce16ea (*HEAD -> **master*, *tag:
>>> v4.0.3-p5*, *origin/master*, *origin/dalcinl/random*, *origin/HEAD*)
>>> Author: Lisandro Dalcin <dalcinl at gmail.com>
>>> Date: Thu May 9 18:44:10 2019 +0300
>>> GKLib: Make FPRFX##randInRange() portable for 32bit/64bit indices
>>> commit 2b4afc79a79ef063f369c43da2617fdb64746dd7
>>> Date: Sat May 4 17:22:19 2019 +0300
>>> GKlib: Use gk_randint32() to define the RandomInRange() macro
>>> On Jan 9, 2020, at 4:31 AM, Smith, Barry F. via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>> This is extremely worrisome:
>>> ==23361== Use of uninitialised value of size 8
>>> ==23361== at 0x847E939: gk_randint64 (random.c:99)
>>> ==23361== by 0x847EF88: gk_randint32 (random.c:128)
>>> ==23361== by 0x81EBF0B: libparmetis__Match_Global (in
>>> /space/hpc-home/trianas/petsc-3.12.3/arch-linux2-c-debug/lib/libparmetis.so)
>>> do you get that with PETSc-3.9.4 or only with 3.12.3?
>>> This may result in Parmetis using non-random numbers and then giving
>>> back an inappropriate ordering that requires more memory for SuperLU_DIST.
>>> Suggest looking at the code, or running in the debugger to see what is
>>> going on there. We use parmetis all the time and don't see this.
>>> Barry
>>> On Jan 8, 2020, at 4:34 PM, Santiago Andres Triana <repepo at gmail.com>
>>> wrote:
>>> Dear Matt, petsc-users:
>>> Finally back after the holidays to try to solve this issue, thanks for
>>> your patience!
>>> I compiled the latest petsc (3.12.3) with debugging enabled, the same
>>> problem appears: relatively large matrices result in out of memory errors.
>>> This is not the case for petsc-3.9.4, all fine there.
>>> This is a non-hermitian, generalized eigenvalue problem, I generate the
>>> A and B matrices myself and then I use example 7 (from the slepc tutorial
>>> at $SLEPC_DIR/src/eps/examples/tutorials/ex7.c ) to solve the problem:
>>> mpiexec -n 24 valgrind --tool=memcheck -q --num-callers=20
>>> --log-file=valgrind.log.%p ./ex7 -malloc off -f1 A.petsc -f2 B.petsc
>>> -eps_nev 1 -eps_target -2.5e-4+1.56524i -eps_target_magnitude -eps_tol
>>> 1e-14 $opts
>>> where the $opts variable is:
>>> -eps_error_relative ::ascii_info_detail -st_pc_factor_mat_solver_type
>>> superlu_dist -mat_superlu_dist_iterrefine 1 -mat_superlu_dist_colperm
>>> PARMETIS -mat_superlu_dist_parsymbfact 1 -eps_converged_reason
>>> -eps_conv_rel -eps_monitor_conv -eps_true_residual 1'
>>> the output from valgrind (sample from one processor) and from the
>>> program are attached.
>>> If it's of any use the matrices are here (might need at least 180 Gb of
>>> ram to solve the problem succesfully under petsc-3.9.4):
>>> WIth petsc-3.9.4 and slepc-3.9.2 I can use matrices up to 10Gb (with 240
>>> Gb ram), but only up to 3Gb with the latest petsc/slepc.
>>> Any suggestions, comments or any other help are very much appreciated!
>>> Cheers,
>>> Santiago
>>> On Mon, Dec 23, 2019 at 11:19 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> On Mon, Dec 23, 2019 at 3:14 PM Santiago Andres Triana <repepo at gmail.com>
>>> wrote:
>>> Dear all,
>>> After upgrading to petsc 3.12.2 my solver program crashes consistently.
>>> Before the upgrade I was using petsc 3.9.4 with no problems.
>>> My application deals with a complex-valued, generalized eigenvalue
>>> problem. The matrices involved are relatively large, typically 2 to 10 Gb
>>> in size, which is no problem for petsc 3.9.4.
>>> Are you sure that your indices do not exceed 4B? If so, you need to
>>> configure using
>>> --with-64-bit-indices
>>> Also, it would be nice if you ran with the debugger so we can get a
>>> stack trace for the SEGV.
>>> Thanks,
>>> Matt
>>> However, after the upgrade I can only obtain solutions when the matrices
>>> are small, the solver crashes when the matrices' size exceed about 1.5 Gb:
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>> batch system) has told this process to end
>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> [0]PETSC ERROR: or see
>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>> OS X to find memory corruption errors
>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>>> and run
>>> [0]PETSC ERROR: to get more information on the crash.
>>> and so on for each cpu.
>>> I tried using valgrind and this is the typical output:
>>> ==2874== Conditional jump or move depends on uninitialised value(s)
>>> ==2874== at 0x4018178: index (in /lib64/ld-2.22.so)
>>> ==2874== by 0x400752D: expand_dynamic_string_token (in /lib64/
>>> ld-2.22.so)
>>> ==2874== by 0x4008009: _dl_map_object (in /lib64/ld-2.22.so)
>>> ==2874== by 0x40013E4: map_doit (in /lib64/ld-2.22.so)
>>> ==2874== by 0x400EA53: _dl_catch_error (in /lib64/ld-2.22.so)
>>> ==2874== by 0x4000ABE: do_preload (in /lib64/ld-2.22.so)
>>> ==2874== by 0x4000EC0: handle_ld_preload (in /lib64/ld-2.22.so)
>>> ==2874== by 0x40034F0: dl_main (in /lib64/ld-2.22.so)
>>> ==2874== by 0x4016274: _dl_sysdep_start (in /lib64/ld-2.22.so)
>>> ==2874== by 0x4004A99: _dl_start (in /lib64/ld-2.22.so)
>>> ==2874== by 0x40011F7: ??? (in /lib64/ld-2.22.so)
>>> ==2874== by 0x12: ???
>>> ==2874==
>>> These are my configuration options. Identical for both petsc 3.9.4 and
>>> 3.12.2:
>>> ./configure --with-scalar-type=complex --download-mumps
>>> --download-parmetis --download-metis --download-scalapack=1
>>> --download-fblaslapack=1 --with-debugging=0 --download-superlu_dist=1
>>> --download-ptscotch=1 CXXOPTFLAGS='-O3 -march=native' FOPTFLAGS='-O3
>>> -march=native' COPTFLAGS='-O3 -march=native'
>>> Thanks in advance for any comments or ideas!
>>> Cheers,
>>> Santiago
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <test1.e6034496><valgrind.log.23361>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200110/45e05076/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200110/45e05076/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200110/45e05076/attachment-0003.obj>
