[petsc-users] DMPlex: Mapping cells before and after partitioning
Matthew Knepley
knepley at gmail.com
Thu Jan 9 18:25:55 CST 2020
On Thu, Jan 9, 2020 at 1:35 PM 'Bisht, Gautam' via tdycores-dev <
tdycores-dev at googlegroups.com> wrote:
> > On Jan 9, 2020, at 2:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> > "'Bisht, Gautam' via tdycores-dev" <tdycores-dev at googlegroups.com>
> writes:
> >>> Do you need to rely on the element number, or would coordinates (of a
> >>> centroid?) be sufficient for your purposes?
> >> I do need to rely on the element number. In my case, I have a mapping
> file that remaps data from one grid onto another grid. Though I’m currently
> creating a hexahedron mesh, in the future I would be reading in an
> unstructured grid from a file for which I cannot rely on coordinates.
> > How does the mapping file work and how is it generated?
> In CESM/E3SM, the mapping file is used to map fluxes or states between
> grids of two components (e.g. land & atmosphere). The mapping method can be
> conservative, nearest neighbor, bilinear, etc. While CESM/E3SM uses
> ESMF_RegridWeightGen to generate the mapping file, I’m using by own MATLAB
> script to create the mapping file.
> I’m surprised that this is not an issue for other codes that are using
> DMPlex. E.g In PFLOTRAN, when a user creates a custom unstructured grid,
> they can specify material property for each grid cell. So, there should be
> a way to create a vectorscatter that will scatter material property read in
> the “application”-order (i.e. order before calling DMPlexDistribute() ) to
> ghosted-order (i.e. order after calling DMPlexDistribute()).
We did build something specific for this because some people wanted it. I
wish I could purge this from all simulations. Its
definitely destructive, but this is the way the world currently is.
You want this:
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexNaturalToGlobalBegin.html
Matt
> > We can locate points and create interpolation with unstructured grids.
> > You received this message because you are subscribed to the Google
> Groups "tdycores-dev" group.
> > To unsubscribe from this group and stop receiving emails from it, send
> an email to tdycores-dev+unsubscribe at googlegroups.com.
> > To view this discussion on the web visit
> https://protect2.fireeye.com/v1/url?k=b265c01b-eed0fed4-b265ea0e-0cc47adc5e60-1707adbf1790c7e4&q=1&e=0962f8e1-9155-4d9c-abdf-2b6481141cd0&u=https%3A%2F%2Fgroups.google.com%2Fd%2Fmsgid%2Ftdycores-dev%2F8736come4e.fsf%2540jedbrown.org
> You received this message because you are subscribed to the Google Groups
> To unsubscribe from this group and stop receiving emails from it, send an
> https://groups.google.com/d/msgid/tdycores-dev/9AB001AF-8857-446A-AE69-E8D6A25CB8FA%40pnnl.gov
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200109/9445be04/attachment-0001.html>
