[petsc-users] Problems applying multigrid
Ellen Price ellen.price at cfa.harvard.edu
Wed Jan 8 13:49:34 CST 2020
Hi PETSc users!
I was playing around with getting faster convergence for my code and
decided to give multigrid a try. For some context, I am using the beuler
timestepper, so the SNES/KSP/PC hierarchy is contained within that. The
problem is defined on a regular grid, a DMDA in dimension 2 with 5 dofs. It
has DM_BOUNDARY_GHOSTED boundaries.
The way I understand it, with these options:
-pc_type mg -pc_mg_galerkin both -pc_mg_levels 2
I should be able to at least *try* multigrid on this problem at a basic
level without changing anything else (please correct me if I'm wrong!),
even if I don't immediately get good convergence.
I know multigrid can be finicky (I've seen a lot of mailing list posts
about it), but I've run into an error that might be internal, or at least
not obvious. Here is a sample of the output:
[12]PETSC ERROR: Arguments are incompatible
[12]PETSC ERROR: Processor's coarse DMDA must lie over fine DMDA
    i_c 314 i_f 628 fine ghost range [499,628]
Does anyone know what would cause this? A quick Google search just brought
up the PETSc source code where the error is issued.
Ellen Price
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200108/717b6c5d/attachment.html>
