[petsc-users] [petsc-maint] (no subject)
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Tue Jan  7 09:21:50 CST 2020
> On Jan 7, 2020, at 8:59 AM, Mark Adams <mfadams at lbl.gov> wrote:
>  I’m not sure what the compilers, and C++ are doing here
> On Tue, Jan 7, 2020 at 9:17 AM Кудров Илья <ilyakudrov at yandex.ru> wrote:
> However, after configuring
> cout<<1. + 1.*PETSC_i<<endl;
> outputs (1, 0) instead of (1, 1).
   Where after configure? PETSC_i is not defined until after PetscInitialize() is called. Send full example.
   Here is the code that defines it
     Initialized the global complex variable; this is because with
     shared libraries the constructors for global variables
     are not called; at least on IRIX.
#if defined(PETSC_HAVE_COMPLEX)
#if defined(PETSC_CLANGUAGE_CXX) && !defined(PETSC_USE_REAL___FLOAT128)
    PetscComplex ic(0.0,1.0);
    PETSC_i = ic;
#else
    PETSC_i = _Complex_I;
#endif
Perhaps it is problematic in C++?  With single precision? Try PetscComplex ic(0.0,1.0); and see what ic is
   Barry
> 07.01.2020, 16:01, "Mark Adams" <mfadams at lbl.gov>:
> yes, configure with
> --with-precision=single
> --with-scalar-type=complex
> On Tue, Jan 7, 2020 at 7:49 AM Кудров Илья <ilyakudrov at yandex.ru> wrote:
> Good day! Is it possible to use complex numbers in single precision in linear solvers? I'd like to decrease time and memory needed for calculation.
> Best regards, Ilya Kudrov!
