[petsc-users] Fwd: Moose install troubleshooting help
Matthew Knepley
knepley at gmail.com
Thu Jan 2 20:04:29 CST 2020
On Thu, Jan 2, 2020 at 6:31 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Satish,
> Do you have any suggestions for this?
> Chris,
> It may be helpful if you could share the petsc configuration log file with
> us?
> Fande,
> ---------- Forwarded message ---------
> From: Chris Thompson <thompsoc91 at gmail.com>
> Date: Tue, Dec 31, 2019 at 9:53 AM
> Subject: Moose install troubleshooting help
> To: moose-users <moose-users at googlegroups.com>
> Dear All,
> I could use some help or a pointer in the right direction.
> I have been following the directions at
> https://mooseframework.inl.gov/getting_started/installation/hpc_install_moose.html
> All was going well until "make PETSC_DIR=$STACK_SRC/petsc-3.11.4
> PETSC_ARCH=linux-opt install". I tried running "make --debug=v
> PETSC_DIR=$STACK_SRC/petsc-3.11.4 PETSC_ARCH=linux-opt install", but that
> didn't produce any more helpful information.
> This on a CentOS system running 7.6
> Here is the error / output I am getting.
> rogue /usr/local/neapps/moose/stack_temp/petsc-3.11.4 926$ make --debug=v
> PETSC_DIR=/usr/local/neapps/moose/stack_temp/petsc-3.11.4
> GNU Make 3.82
> Built for x86_64-redhat-linux-gnu
> Copyright (C) 2010 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.
> Reading makefiles...
> Reading makefile `makefile'...
> Reading makefile `linux-opt/lib/petsc/conf/petscvariables' (search path)
> (no ~ expansion)...
> Reading makefile
> `/usr/local/neapps/moose/stack_temp/petsc-3.11.4/lib/petsc/conf/variables'
> (search path) (no ~ expansion)...
> Reading makefile
> `/usr/local/neapps/moose/stack_temp/petsc-3.11.4/linux-opt/lib/petsc/conf/petscvariables'
> Reading makefile
> `/usr/local/neapps/moose/stack_temp/petsc-3.11.4/lib/petsc/conf/rules'
> Reading makefile
> `/usr/local/neapps/moose/stack_temp/petsc-3.11.4/linux-opt/lib/petsc/conf/petscrules'
> Reading makefile
> `/usr/local/neapps/moose/stack_temp/petsc-3.11.4/lib/petsc/conf/test.common'
> Updating goal targets....
> Considering target file `install'.
> File `install' does not exist.
> Finished prerequisites of target file `install'.
> Must remake target `install'.
> Invoking recipe from makefile:250 to update target `install'.
> *** Using PETSC_DIR=/usr/local/neapps/moose/stack_temp/petsc-3.11.4
> PETSC_ARCH=linux-opt ***
> *** Installing PETSc at prefix location:
> /usr/local/neapps/moose/petsc-3.11.4 ***
> Traceback (most recent call last):
> File "./config/install.py", line 434, in <module>
> Installer(sys.argv[1:]).run()
> File "./config/install.py", line 428, in run
> self.runcopy()
> File "./config/install.py", line 407, in runcopy
> self.installIncludes()
> File "./config/install.py", line 305, in installIncludes
> self.copies.extend(self.copytree(self.rootIncludeDir,
> self.destIncludeDir,exclude = exclude))
> File "./config/install.py", line 246, in copytree
> raise shutil.Error(errors)
> shutil.Error:
> ['/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc',
> '/usr/local/neapps/moose/petsc-3.11.4/include/petsc',
> '[\'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc/private\',
> \'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/private\',
> \'[\\\'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc/private/kernels\\\',
> \\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/private/kernels\\\',
> \\\'[\\\\\\\'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc/private/kernels\\\\\\\',
> \\\\\\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/private/kernels\\\\\\\',
> "[Errno 1] Operation not permitted:
> \\\\\\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/private/kernels\\\\\\\'"]\\\',
> \\\'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc/private\\\',
> \\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/private\\\',
> \\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/private\\\'"]\',
> \'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc/finclude\',
> \'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/finclude\',
> \'[\\\'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc/finclude\\\',
> \\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/finclude\\\',
> \\\'/usr/local/neapps/moose/petsc-3.11.4/include/petsc/finclude\\\'"]\',
> \'/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include/petsc\',
> \'/usr/local/neapps/moose/petsc-3.11.4/include/petsc\', "[Errno 1]
> \'/usr/local/neapps/moose/petsc-3.11.4/include/petsc\'"]',
> '/usr/local/neapps/moose/stack_temp/petsc-3.11.4/include',
> '/usr/local/neapps/moose/petsc-3.11.4/include', "[Errno 1] Operation not
> permitted: '/usr/local/neapps/moose/petsc-3.11.4/include'"]
> make: *** [install] Error 1
> I'm not sure how to proceed with this error.
It looks like you do not have permissions in the install directory. You may
want to run the install command using 'sudo'.
Matt
> Thank you,
> Chris
> You received this message because you are subscribed to the Google Groups
> "moose-users" group.
> To unsubscribe from this group and stop receiving emails from it, send an
> email to moose-users+unsubscribe at googlegroups.com.
> To view this discussion on the web visit
> https://groups.google.com/d/msgid/moose-users/d7c11fe1-f6aa-4b5f-8746-9ea7bc93de87%40googlegroups.com
> <https://groups.google.com/d/msgid/moose-users/d7c11fe1-f6aa-4b5f-8746-9ea7bc93de87%40googlegroups.com?utm_medium=email&utm_source=footer>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200102/ce714b3f/attachment.html>
