[petsc-users] Correct use of VecGetArray with std::vector
Junchao Zhang
jczhang at mcs.anl.gov
Fri Feb 28 14:00:54 CST 2020
You can create the C++ vector vals and resize it to a proper size, get its
data pointer, then pass it to PETSc,
int n;
Vec x;
std::vector<PetscScalar> vals;
vals.resize(n); /* You need to calculate n by other means */
ierr =
VecCreateMPIWithArray(PETSC_COMM_WORLD,bs,n,PETSC_DECIDE,vals.data(),&v);CHKERRQ(ierr);
// Code using v
ierr = VecDestroy(&v);CHKERRQ(ierr);
// Code using vals;
--Junchao Zhang
On Fri, Feb 28, 2020 at 1:12 PM Zane Charles Jakobs <
Zane.Jakobs at colorado.edu> wrote:
> Hi PETSc devs,
> I'm writing some C++ code that calls PETSc, and I'd like to be able to
> place the result of VecGetArray into an std::vector and then later call
> VecRestoreArray on that data, or get the same effects. It seems like the
> correct way to do this would be something like:
> Vec x;
> std::vector<PetscScalar> vals, idx;
> int num_vals, global_offset;
> PetscErrorCode ierr;
> /* do some stuff to x and compute num_vals and global_offset*/
> vals.resize(num_vals);
> idx.resize(num_vals);
> std::iota(idx.begin(), idx.end(), global_offset);
> ierr = VecGetValues(x, num_vals, idx.data(), vals.data());CHKERRQ(ierr);
> /* do stuff to vals */
> ierr = VecSetValues(x, num_vals, idx.data(), vals.data(), [whatever insert
> mode]);CHKERRQ(ierr);
> idx.clear();
> vals.clear();
> Is that correct (in the sense that it does what you'd expect if you
> replaced the vectors with pointers to indices/data and used
> VecGet/RestoreArray() instead of VecGet/SetValues, and it doesn't violate
> any of std::vector's invariants, e.g. by reallocating its memory)? If not,
> is there a "normal" way to do this?
> Thanks!
> -Zane Jakobs
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200228/0c6de7cd/attachment-0001.html>
