[petsc-users] Guidance on using Tao for unconstrained minimization
Ellen Price ellen.price at cfa.harvard.edu
Thu Feb 27 13:47:13 CST 2020
I tried what you suggested and used the bounded CG method. It gets a lot
farther than the unconstrained CG method and finds a lower residual, but it
still experiences a line search failure after a while. Any thoughts? I'm
attaching the log output.
In case it's helpful, I also spent a few more hours working on the code and
now can compute the Hessian times an arbitrary vector (matrix-free using a
MATSHELL); even matrix-free, however, the Hessian is much slower to compute
than the gradient and objective. To answer a previous question, I am as
sure as I can be that the gradient is correct, since I'm using automatic
differentiation and not relying on a hand-coded function.
Thanks for your help,
Ellen
On Thu, Feb 27, 2020 at 11:40 AM Adam Denchfield <adenchfi at hawk.iit.edu>
wrote:
> Hi Ellen,
> It is as Alp said. To emphasize what he said, you don't need to worry
> about using a bounded CG method - the bounded CG methods can be used for
> unconstrained problems, and are much better than the old unconstrained CG
> code.
> On Thu, Feb 27, 2020, 9:55 AM Dener, Alp via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi Ellen,
>> It looks like you’re using the old unconstrained CG code. This will be
>> deprecated in the near future in favor of the newer bound-constrained CG
>> algorithm (TAOBNCG) that can also solve unconstrained problems when the
>> user does not specify any bounds on the problem.
>> The newer TAOBNCG algorithm implements a preconditioner that
>> significantly improves the scaling of the search direction and helps the
>> line search accept the unit step length most of the time. I would recommend
>> making sure that you’re on PETSc version 3.11 or newer, and then switching
>> to this with “-tao_type bncg”. You will not need to change any of your code
>> to do this. If you still fail to converge, please send a new log with the
>> new algorithm and we can evaluate the next steps.
>>>> Alp Dener
>> Postdoctoral Researcher
>> Argonne National Laboratory
>> https://www.anl.gov/profile/alp-dener
>> On February 26, 2020 at 6:01:34 PM, Ellen Price (
>> ellen.price at cfa.harvard.edu) wrote:
>> Hi Jed,
>> Thanks for getting back to me! Here's the output for my CG config. Sorry
>> it's kind of a lot.
>> Ellen
>> On Wed, Feb 26, 2020 at 12:43 PM Jed Brown <jed at jedbrown.org> wrote:
>>> Could you share output for your current configuration with -tao_monitor
>>> -tao_ls_monitor -tao_view?
>>> "Ellen M. Price" <ellen.price at cfa.harvard.edu> writes:
>>> > Hello PETSc users!
>>> > I am using Tao for an unconstrained minimization problem. I have found
>>> > that CG works better than the other types for this application. After
>>> > about 85 iterations, I get an error about line search failure. I'm not
>>> > clear on what this means, or how I could mitigate the problem, and
>>> > neither the manual nor FAQ give any guidance. Can anyone suggest things
>>> > I could try to help the method converge? I have function and gradient
>>> > info, but no Hessian.
>>> > Thanks,
>>> > Ellen Price
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200227/c02a5ba0/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200227/c02a5ba0/attachment-0001.obj>
