[petsc-users] The question of the output from ksp/ex2.c
Stefano Zampini
stefano.zampini at gmail.com
Wed Feb 26 02:50:32 CST 2020
First, make sure you compiled with support for MPI by running make check
[szampini at localhost petsc]$ make check
Running test examples to verify correct installation
Using PETSC_DIR=/home/szampini/Devel/jointinversion/pkgs/petsc and
PETSC_ARCH=arch-joint
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI
processes
C/C++ example src/snes/examples/tutorials/ex19 run successfully with hypre
C/C++ example src/snes/examples/tutorials/ex19 run successfully with mumps
Completed test examples
if you have the "2 MPI processes" output, then type
[szampini at localhost petsc]$ make -f gmakefile print VAR=MPIEXEC
mpiexec
For me, mpiexec is system-wide.
Il giorno mer 26 feb 2020 alle ore 11:38 Tsung-Hsing Chen <
barrydog505 at gmail.com> ha scritto:
> So, What should I do to use the correct mpiexec?
> Am I configure petsc with the wrong way or something should be done?
> Stefano Zampini <stefano.zampini at gmail.com> 於 2020年2月26日 週三 下午4:26寫道:
>> This is what I get
>> [szampini at localhost tutorials]$ mpiexec -n 2 ./ex2 -ksp_monitor_short -m
>> 5 -n 5 -ksp_gmres_cgs_refinement_type refine_always
>> 0 KSP Residual norm 2.73499
>> 1 KSP Residual norm 0.795482
>> 2 KSP Residual norm 0.261984
>> 3 KSP Residual norm 0.0752998
>> 4 KSP Residual norm 0.0230031
>> 5 KSP Residual norm 0.00521255
>> 6 KSP Residual norm 0.00145783
>> 7 KSP Residual norm 0.000277319
>> Norm of error 0.000292349 iterations 7
>> When I sequentially, I get (same output as yours)
>> [szampini at localhost tutorials]$ mpiexec -n 1 ./ex2 -ksp_monitor_short -m
>> 0 KSP Residual norm 3.21109
>> 1 KSP Residual norm 0.93268
>> 2 KSP Residual norm 0.103515
>> 3 KSP Residual norm 0.00787798
>> 4 KSP Residual norm 0.000387275
>> Norm of error 0.000392701 iterations 4
>> This means you are using the wrong mpiexec
>> Il giorno mer 26 feb 2020 alle ore 11:17 Tsung-Hsing Chen <
>>> Hi,
>>> I tried to run the example in ksp/examples/tutorials/ex2.
>>> I run the code with : mpiexec -n 2 ./ex2 -ksp_monitor_short -m 5 -n 5
>>> the output is :
>>> My output(above) is twice as the ksp/examples/tutorials/output/ex2_4.out.
>>> Is this the right answer that should come out?
>>> Thanks in advance,
>>> Tsung-Hsing Chen
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200226/22dff238/attachment-0001.html>
