[petsc-users] The question of the output from ksp/ex2.c
Stefano Zampini
stefano.zampini at gmail.com
Wed Feb 26 02:25:58 CST 2020
This is what I get
[szampini at localhost tutorials]$ mpiexec -n 2 ./ex2 -ksp_monitor_short -m 5
-n 5 -ksp_gmres_cgs_refinement_type refine_always
0 KSP Residual norm 2.73499
1 KSP Residual norm 0.795482
2 KSP Residual norm 0.261984
3 KSP Residual norm 0.0752998
4 KSP Residual norm 0.0230031
5 KSP Residual norm 0.00521255
6 KSP Residual norm 0.00145783
7 KSP Residual norm 0.000277319
Norm of error 0.000292349 iterations 7
When I sequentially, I get (same output as yours)
[szampini at localhost tutorials]$ mpiexec -n 1 ./ex2 -ksp_monitor_short -m 5
0 KSP Residual norm 3.21109
1 KSP Residual norm 0.93268
2 KSP Residual norm 0.103515
3 KSP Residual norm 0.00787798
4 KSP Residual norm 0.000387275
Norm of error 0.000392701 iterations 4
This means you are using the wrong mpiexec
Il giorno mer 26 feb 2020 alle ore 11:17 Tsung-Hsing Chen <
barrydog505 at gmail.com> ha scritto:
> Hi,
> I tried to run the example in ksp/examples/tutorials/ex2.
> I run the code with : mpiexec -n 2 ./ex2 -ksp_monitor_short -m 5 -n 5
> the output is :
> My output(above) is twice as the ksp/examples/tutorials/output/ex2_4.out.
> Is this the right answer that should come out?
> Thanks in advance,
> Tsung-Hsing Chen
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200226/0d62799c/attachment.html>
