[petsc-users] Correct approach for updating deprecated code
Matthew Knepley
knepley at gmail.com
Mon Feb 24 10:04:52 CST 2020
On Sun, Feb 23, 2020 at 6:45 PM Richard Beare <richard.beare at monash.edu>
wrote:
> That's what I did (see below), but I got ordering errors (unfortunately
> deleted those logs too soon). I'll rerun if no one recognises what I've
> done wrong.
> PetscViewer viewer1;
> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,fileName.c_str
> (),FILE_MODE_WRITE,&viewer1);CHKERRQ(ierr);
> //ierr =
> PetscViewerSetFormat(viewer1,PETSC_VIEWER_BINARY_MATLAB);CHKERRQ(ierr);
> ierr = PetscViewerPushFormat(viewer1,PETSC_VIEWER_BINARY_MATLAB);CHKERRQ
> (ierr);
This should not cause problems. However, is it possible that somewhere you
are pushing a format
again and again without popping? This could exceed the stack size.
Matt
> ierr = PetscObjectSetName((PetscObject)mX,"x");CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject)mB,"b");CHKERRQ(ierr);
> On Mon, 24 Feb 2020 at 10:43, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Feb 23, 2020 at 6:25 PM Richard Beare via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi,
>>> The following code gives a deprecation warning. What is the correct way
>>> of updating the use of ViewerSetFormat to ViewerPushFormat (which I presume
>>> is the preferred replacement). My first attempt gave errors concerning
>>> ordering.
>> You can't just change SetFormat to PushFormat here?
>> Matt
>>> Thanks
>>> ierr = PetscViewerSetFormat(viewer1,PETSC_VIEWER_BINARY_MATLAB);CHKERRQ
>>> (ierr);
>>> ierr = VecView(mX,viewer1);CHKERRQ(ierr);
>>> ierr = VecView(mB,viewer1);CHKERRQ(ierr);
>>> A/Prof Richard Beare
>>> Imaging and Bioinformatics, Peninsula Clinical School
>>> orcid.org/0000-0002-7530-5664
>>> Richard.Beare at monash.edu
>>> +61 3 9788 1724
>>> Geospatial Research:
>>> https://www.monash.edu/medicine/scs/medicine/research/geospatial-analysis
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> +61 3 9788 1724
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200224/b22e0243/attachment-0001.html>
