[petsc-users] Using PETSc with GPU supported SuperLU_Dist
Satish Balay
balay at mcs.anl.gov
Mon Feb 24 09:18:51 CST 2020
nvidia-smi gives some relevant info. I'm not sure what exactly the cuda-version listed here refers to..
[is it the max version of cuda - this driver is compatible with?]
Satish
[balay at p1 ~]$ nvidia-smi
Mon Feb 24 09:15:26 2020
| NVIDIA-SMI 440.59 Driver Version: 440.59 CUDA Version: 10.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 Quadro T2000 Off | 00000000:01:00.0 Off | N/A |
| N/A 45C P8 4W / N/A | 182MiB / 3911MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1372 G /usr/libexec/Xorg 180MiB |
[balay at p1 ~]$
On Mon, 24 Feb 2020, Junchao Zhang via petsc-users wrote:
> [0]PETSC ERROR: error in cudaSetDevice CUDA driver version is insufficient
> for CUDA runtime version
> That means you need to update your cuda driver for CUDA 10.2. See minimum
> requirement in Table 1 at
> https://docs.nvidia.com/cuda/cuda-toolkit-release-notes/index.html#major-components
> --Junchao Zhang
> On Sun, Feb 23, 2020 at 3:33 PM Abhyankar, Shrirang G <
> shrirang.abhyankar at pnnl.gov> wrote:
> > I was using CUDA v10.2. Switching to 9.2 gives a clean make test.
> > Thanks,
> > Shri
> > *From: *petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
> > "Abhyankar, Shrirang G via petsc-users" <petsc-users at mcs.anl.gov>
> > *Reply-To: *"Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>
> > *Date: *Sunday, February 23, 2020 at 3:10 PM
> > *To: *petsc-users <petsc-users at mcs.anl.gov>, Junchao Zhang <
> > jczhang at mcs.anl.gov>
> > *Subject: *Re: [petsc-users] Using PETSc with GPU supported SuperLU_Dist
> > I am getting an error now for CUDA driver version. Any suggestions?
> > petsc:maint$ make test
> > Running test examples to verify correct installation
> > Using PETSC_DIR=/people/abhy245/software/petsc and
> > PETSC_ARCH=debug-mode-newell
> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
> > process
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Error in system call
> > [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> > for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.12.4, unknown
> > [0]PETSC ERROR: ./ex19 on a debug-mode-newell named newell01.pnl.gov by
> > abhy245 Sun Feb 23 12:49:55 2020
> > [0]PETSC ERROR: Configure options --download-fblaslapack --download-make
> > --download-metis --download-parmetis --download-scalapack
> > --download-suitesparse --download-superlu_dist-gpu=1
> > --download-superlu_dist=1 --with-cc=mpicc --with-clanguage=c++
> > --with-cuda-dir=/share/apps/cuda/10.2 --with-cuda=1
> > --with-cxx-dialect=C++11 --with-cxx=mpicxx --with-fc=mpif77 --with-openmp=1
> > [0]PETSC ERROR: #1 PetscCUDAInitialize() line 261 in
> > /qfs/people/abhy245/software/petsc/src/sys/objects/init.c
> > [0]PETSC ERROR: #2 PetscOptionsCheckInitial_Private() line 652 in
> > [0]PETSC ERROR: #3 PetscInitialize() line 1010 in
> > /qfs/people/abhy245/software/petsc/src/sys/objects/pinit.c
> > Primary job terminated normally, but 1 process returned
> > a non-zero exit code. Per user-direction, the job has been aborted.
> > mpiexec detected that one or more processes exited with non-zero status,
> > thus causing
> > the job to be terminated. The first process to do so was:
> > Process name: [[46518,1],0]
> > Exit code: 88
> > Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
> > processes
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Error in system call
> > [1]PETSC ERROR: [0]PETSC ERROR: Error in system call
> > [0]PETSC ERROR: error in cudaGetDeviceCount CUDA driver version is
> > insufficient for CUDA runtime version
> > error in cudaGetDeviceCount CUDA driver version is insufficient for CUDA
> > runtime version
> > [1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> > [1]PETSC ERROR: [0]PETSC ERROR: Petsc Release Version 3.12.4, unknown
> > abhy245 Sun Feb 23 12:49:57 2020
> > [0]PETSC ERROR: #1 PetscCUDAInitialize() line 254 in
> > [1]PETSC ERROR: ./ex19 on a debug-mode-newell named newell01.pnl.gov by
> > [1]PETSC ERROR: Configure options --download-fblaslapack --download-make
> > [1]PETSC ERROR: #1 PetscCUDAInitialize() line 254 in
> > [1]PETSC ERROR: #2 PetscOptionsCheckInitial_Private() line 652 in
> > [1]PETSC ERROR: #3 PetscInitialize() line 1010 in
> > thus causing
> > Process name: [[46522,1],0]
> > Exit code: 88
> > 1,2c1,21
> > < lid velocity = 0.0025, prandtl # = 1., grashof # = 1.
> > < Number of SNES iterations = 2
> > abhy245 Sun Feb 23 12:50:00 2020
> > thus causing
> > > Process name: [[46545,1],0]
> > > Exit code: 88
> > /people/abhy245/software/petsc/src/snes/examples/tutorials
> > Possible problem with ex19 running with superlu_dist, diffs above
> > Possible error running Fortran example src/snes/examples/tutorials/ex5f
> > with 1 MPI process
> > [0]PETSC ERROR: ./ex5f on a debug-mode-newell named newell01.pnl.gov by
> > abhy245 Sun Feb 23 12:50:04 2020
> > [0]PETSC ERROR: PetscInitialize:Checking initial options
> > Unable to initialize PETSc
> > mpiexec has exited due to process rank 0 with PID 0 on
> > node newell01 exiting improperly. There are three reasons this could occur:
> > 1. this process did not call "init" before exiting, but others in
> > the job did. This can cause a job to hang indefinitely while it waits
> > for all processes to call "init". By rule, if one process calls "init",
> > then ALL processes must call "init" prior to termination.
> > 2. this process called "init", but exited without calling "finalize".
> > By rule, all processes that call "init" MUST call "finalize" prior to
> > exiting or it will be considered an "abnormal termination"
> > 3. this process called "MPI_Abort" or "orte_abort" and the mca parameter
> > orte_create_session_dirs is set to false. In this case, the run-time cannot
> > detect that the abort call was an abnormal termination. Hence, the only
> > error message you will receive is this one.
> > This may have caused other processes in the application to be
> > terminated by signals sent by mpiexec (as reported here).
> > You can avoid this message by specifying -quiet on the mpiexec command
> > line.
> > Completed test examples
> > *From: *Satish Balay <balay at mcs.anl.gov>
> > *Reply-To: *petsc-users <petsc-users at mcs.anl.gov>
> > *Date: *Saturday, February 22, 2020 at 9:00 PM
> > *To: *Junchao Zhang <jczhang at mcs.anl.gov>
> > *Cc: *"Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>, petsc-users <
> > The fix is now in both maint and master
> > https://gitlab.com/petsc/petsc/-/merge_requests/2555
> > Satish
> > On Sat, 22 Feb 2020, Junchao Zhang via petsc-users wrote:
> > We met the error before and knew why. Will fix it soon.
> > --Junchao Zhang
> > On Sat, Feb 22, 2020 at 11:43 AM Abhyankar, Shrirang G via petsc-users <
> > petsc-users at mcs.anl.gov> wrote:
> > > Thanks, Satish. Configure and make go through fine. Getting an undefined
> > > reference error for VecGetArrayWrite_SeqCUDA.
> > > Shri
> > > *Date: *Saturday, February 22, 2020 at 8:25 AM
> > > *To: *"Abhyankar, Shrirang G" <shrirang.abhyankar at pnnl.gov>
> > > *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> > > On Sat, 22 Feb 2020, Abhyankar, Shrirang G via petsc-users wrote:
> > > Hi,
> > > I want to install PETSc with GPU supported SuperLU_Dist. What are the
> > > configure options I should be using?
> > > Shri,
> > > if self.framework.argDB['download-superlu_dist-gpu']:
> > > self.cuda =
> > framework.require('config.packages.cuda',self)
> > > self.openmp =
> > > framework.require('config.packages.openmp',self)
> > > self.deps =
> > > [self.mpi,self.blasLapack,self.cuda,self.openmp]
> > > So try:
> > > --with-cuda=1 --download-superlu_dist=1 --download-superlu_dist-gpu=1
> > > --with-openmp=1 [and usual MPI, blaslapack]
> > > Satish
