[petsc-users] static libs
Mark Adams
mfadams at lbl.gov
Thu Feb 20 16:51:26 CST 2020
On Thu, Feb 20, 2020 at 2:30 PM Satish Balay <balay at mcs.anl.gov> wrote:
> BTW: What do you mean by 'Cray static library environment variable'? Is it
> CRAYPE_LINK_TYPE?
Yes, that was it.
> What is set to? What problems are you having?
I think they were using 'static' for Adios but are going to try to make it
work with dynamic. Otherwise I can configure with static libs.
> One can get shared library build of PETSc working with:
> export CRAYPE_LINK_TYPE=dynamic
> Satish
> On Thu, 20 Feb 2020, Satish Balay via petsc-users wrote:
> > You can build PETSc statically with configure option:
> > --with-shared-libraries=0
> > Satish
> > On Thu, 20 Feb 2020, Mark Adams wrote:
> > > We are having problems linking with at Cray static library environment
> > > variable, that is required to link Adios, and IO package. How does one
> > > build with static PETSc libs?
> > > Thanks,
> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200220/ab37d1ba/attachment-0001.html>
