[petsc-users] static libs
Junchao Zhang
jczhang at mcs.anl.gov
Thu Feb 20 15:26:28 CST 2020
Copy & paste from a Cray paper:
"The main disadvantage of dynamic shared libraries is the runtime
performance costs of dynamic linking. Every time the program is executed it
has to perform a large part of its linking process. The lookup of symbols
in a dynamic shared library is much less efficient than in static
libraries. The loading of a dynamic shared library during an application‟s
execution may result in a “jitter” effect where a single process holds up
the forward progress of other processes of the application while it is
loading a library. "
BTW, Cori's default is changed from static to dynamic. I heard Frontier
will also use dynamic.
--Junchao Zhang
On Thu, Feb 20, 2020 at 2:03 PM Amil Sharma via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Just wondering if static linking is better for performance?
> On Thu, Feb 20, 2020 at 2:58 PM Albert Mollen <amollen at pppl.gov> wrote:
>> Hi Mark,
>> I'm trying to rebuild Adios2 with dynamic linking on cori. Hopefully we
>> can move over to that.
>> Best regards
>> Albert Mollén
>> Associate Research Physicist
>> Theory Department
>> Princeton Plasma Physics Laboratory
>> P.O. Box 451
>> Princeton, NJ 08543-0451
>> USA
>> Tel. +1 609-243-3909
>> E-mail: amollen at pppl.gov
>> On Thu, Feb 20, 2020 at 2:52 PM Amil Sharma <asharma at pppl.gov> wrote:
>>> We need static linking in order to link an existing static IO library,
>>> but we did not know the PETSc static build configure option.
>>> On Thu, Feb 20, 2020 at 2:30 PM Satish Balay <balay at mcs.anl.gov> wrote:
>>>> BTW: What do you mean by 'Cray static library environment variable'? Is
>>>> it CRAYPE_LINK_TYPE? What is set to? What problems are you having?
>>>> One can get shared library build of PETSc working with:
>>>> export CRAYPE_LINK_TYPE=dynamic
>>>> Satish
>>>> On Thu, 20 Feb 2020, Satish Balay via petsc-users wrote:
>>>> > You can build PETSc statically with configure option:
>>>> > --with-shared-libraries=0
>>>> > Satish
>>>> > On Thu, 20 Feb 2020, Mark Adams wrote:
>>>> > > We are having problems linking with at Cray static library
>>>> environment
>>>> > > variable, that is required to link Adios, and IO package. How does
>>>> one
>>>> > > build with static PETSc libs?
>>>> > > Thanks,
>>>> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200220/5c1dd80a/attachment.html>
