[petsc-users] static libs
Albert Mollen amollen at pppl.gov
Thu Feb 20 13:57:48 CST 2020
Hi Mark,
I'm trying to rebuild Adios2 with dynamic linking on cori. Hopefully we can
move over to that.
Best regards
Albert Mollén
Associate Research Physicist
Theory Department
Princeton Plasma Physics Laboratory
P.O. Box 451
Princeton, NJ 08543-0451
USA
Tel. +1 609-243-3909
E-mail: amollen at pppl.gov
On Thu, Feb 20, 2020 at 2:52 PM Amil Sharma <asharma at pppl.gov> wrote:
> We need static linking in order to link an existing static IO library, but
> we did not know the PETSc static build configure option.
> On Thu, Feb 20, 2020 at 2:30 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> BTW: What do you mean by 'Cray static library environment variable'? Is
>> it CRAYPE_LINK_TYPE? What is set to? What problems are you having?
>> One can get shared library build of PETSc working with:
>> export CRAYPE_LINK_TYPE=dynamic
>> Satish
>> On Thu, 20 Feb 2020, Satish Balay via petsc-users wrote:
>> > You can build PETSc statically with configure option:
>> > --with-shared-libraries=0
>> > Satish
>> > On Thu, 20 Feb 2020, Mark Adams wrote:
>> > > We are having problems linking with at Cray static library environment
>> > > variable, that is required to link Adios, and IO package. How does one
>> > > build with static PETSc libs?
>> > > Thanks,
>> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200220/e39e72b6/attachment-0002.html>
