[petsc-users] static libs
Thu Feb 20 13:29:49 CST 2020
BTW: What do you mean by 'Cray static library environment variable'? Is it CRAYPE_LINK_TYPE? What is set to? What problems are you having?
One can get shared library build of PETSc working with:
export CRAYPE_LINK_TYPE=dynamic
Satish
On Thu, 20 Feb 2020, Satish Balay via petsc-users wrote:
> You can build PETSc statically with configure option:
> --with-shared-libraries=0
> Satish
> On Thu, 20 Feb 2020, Mark Adams wrote:
> > We are having problems linking with at Cray static library environment
> > variable, that is required to link Adios, and IO package. How does one
> > build with static PETSc libs?
> > Thanks,
> > Mark
