[petsc-users] SLEPc: The inner product is not well defined
Jose E. Roman jroman at dsic.upv.es
Tue Feb 18 03:17:46 CST 2020
> El 17 feb 2020, a las 19:19, Emmanuel Ayala <juaneah at gmail.com> escribió:
> Thank you very much for the answer.
> This error appears when computing the B-norm of a vector x, as sqrt(x'*B*x). Probably your B matrix is semi-definite, and due to floating-point error the value x'*B*x becomes negative for a certain vector x. The code uses a tolerance of 10*PETSC_MACHINE_EPSILON, but it seems the rounding errors are larger in your case. Or maybe your B-matrix is indefinite, in which case you should solve the problem as non-symmetric (or as symmetric-indefinite GHIEP).
> Do you get the same problem with the Krylov-Schur solver?
> After check the input matrices, the problem was solved using GHIEP.
> A workaround is to edit the source code and remove the check or increase the tolerance, but this may be catastrophic if your B is indefinite. A better solution is to reformulate the problem, solving the matrix pair (A,C) where C=alpha*A+beta*B is positive definite (note that then the eigenvalues become lambda/(beta+alpha*lambda)).
> Ok, there is a rule to choose the values for alpha and beta?
For instance take alpha=1 and beta=-sigma, where sigma is a lower bound of the leftmost eigenvalue of B (the most negative one). This assumes that A is positive definite.
Jose
> Kind regards.
> Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200218/6577db32/attachment-0001.html>
