[petsc-users] Matrix-free method in PETSc
Mon Feb 17 09:19:21 CST 2020
On Mon, Feb 17, 2020 at 8:56 AM Yuyun Yang <yyang85 at stanford.edu> wrote:
> Hello,
> I actually have a question about the usage of DMDA since I'm quite new to
> this. I wonder if the DMDA suite of functions can be directly called on
> vectors created from VecCreate? Or the vectors have to be formed by
> DMDACreateGlobalVector?
Most things work the same. About the only thing that is different is that
we set a special viewer for vectors from DMDACreateGlobalVector()
which puts it in lexicographic order on output.
> I'm also not sure about what the dof and stencil width arguments do.
'dof' is how many unknowns lie at each vertex. 'sw' is the width of the
ghost region for local vectors.
> I'm still unsure about the usage of MatCreateShell and
> MatShellSetOperation, since it seems that MyMatMult should still have 3
> inputs just like MatMult (the matrix and two vectors).
MatShell is a type where you provide your own function implementations,
rather than using those for a particular storage format, like AIJ.
> Since I'm not forming the matrix, does that mean the matrix input is
> meaningless but still needs to exist for the sake of this format?
It means you calculate the output yourself, using the input.
> After I create such a shell matrix, can I use it like a regular matrix in
> KSP and utilize preconditioners?
Many preconditioners want access to individual elements of the matrix,
which usually will not work with shell matrices, since the
user just wants to provide the multiply routine.
    Matt
> Thanks!
> Yuyun
> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Yuyun
> *Sent:* Sunday, February 16, 2020 3:12 AM
> *To:* Smith, Barry F. <bsmith at mcs.anl.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Matrix-free method in PETSc
> Thank you, that is very helpful information indeed! I will try it and send
> you my code when it works.
> Best regards,
> Yuyun
> *From:* Smith, Barry F. <bsmith at mcs.anl.gov>
> *Sent:* Saturday, February 15, 2020 10:02 PM
> *To:* Yuyun Yang <yyang85 at stanford.edu>
>   Yuyun,
>     If you are speaking about using a finite difference stencil on a
> structured grid where you provide the Jacobian vector products yourself by
> looping over the grid doing the stencil operation we unfortunately do not
> have exactly that kind of example.
>     But it is actually not difficult. I suggest starting with
> src/ts/examples/tests/ex22.c It computes the sparse matrix explicitly with
> FormIJacobian()
>     What you need to do is instead in main() use MatCreateShell() and
> MatShellSetOperation(,MATOP_MULT,(void (*)(void))MyMatMult) then provide
> the routine MyMatMult() to do your stencil based matrix free product; note
> that you can create this new routine by taking the structure of IFunction()
> and reorganizing it to do the Jacobian product instead. You will need to
> get the information about the shell matrix size on each process by calling
> DMDAGetCorners().
>     You will then remove the explicit computation of the Jacobian, and
> also remove the Event stuff since you don't need it.
>      Extending to 2 and 3d is straight forward.
>      Any questions let us know.
>    Barry
>    If you like this would make a great merge request with your code to
> improve our examples.
> > On Feb 15, 2020, at 9:42 PM, Yuyun Yang <yyang85 at stanford.edu> wrote:
> > Hello team,
> > I wanted to apply the Krylov subspace method to a matrix-free
> implementation of a stencil, such that the iterative method acts on the
> operation without ever constructing the matrix explicitly (for example,
> when doing backward Euler).
> > I'm not sure whether there is already an example for that somewhere. If
> so, could you point me to a relevant example?
> > Thank you!
> > Best regards,
> > Yuyun
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200217/1c986654/attachment.html>
