[petsc-users] Forming a matrix from vectors
Matthew Knepley
knepley at gmail.com
Mon Feb 17 06:01:42 CST 2020
On Mon, Feb 17, 2020 at 4:24 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> I would use MatDenseGetColumn() and VecGetArrayRead() to get the two
> pointers and then copy the values with a loop.
I would do as Jose says to get it working. After you verify it, we could
show you how to avoid a copy.
Matt
> Jose
> > El 17 feb 2020, a las 9:35, Eda Oktay <eda.oktay at metu.edu.tr> escribió:
> > Hello all,
> > I am trying to form a matrix whose columns are eigenvectors I have
> calculated before U = [v1,v2,v3]. Is there any easy way of forming this
> matrix? My matrix should be parallel and I have created vectors as below,
> where nev i s the number of requested eigenvalues. So each V[i] represents
> an eigenvector and I should form a matrix by using V.
> > Vec *V;
> > VecDuplicateVecs(vr,nev,&V);
> > for (i=0; i<nev;i++){
> > ierr = EPSGetEigenpair(eps,i,&kr,NULL,V[i],NULL);
> > Thanks!
> > Eda
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200217/964ae0bd/attachment-0001.html>
