[petsc-users] Crash caused by strange error in KSPSetUp
Richard Beare
richard.beare at monash.edu
Fri Feb 14 20:32:57 CST 2020
It doesn't compile out of the box with master.
singularity def file attached.
On Sat, 15 Feb 2020 at 08:03, Richard Beare <richard.beare at monash.edu>
wrote:
> I will see if I can build with master. The docs for simulatrophy say
> 3.6.3.1.
> On Sat, 15 Feb 2020 at 02:47, Junchao Zhang <jczhang at mcs.anl.gov> wrote:
>> Which petsc version do you use? In aij.c of the master branch, I saw
>> Barry recently added a useful check to catch number of nonzero overflow,
>> ierr = PetscIntCast(nz64,&nz);CHKERRQ(ierr); But you mentioned using
>> 64-bit indices did not solve the problem, it might not be the reason. You
>> should try the master branch if feasible. Also, vary number of MPI ranks to
>> see if error stack changes.
>> --Junchao Zhang
>> On Fri, Feb 14, 2020 at 5:12 AM Richard Beare via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> No luck - exactly the same error after including the
>>> --with-64-bit-indicies=yes --download-mpich=yes options
>>> ==8674== Argument 'size' of function memalign has a fishy (possibly
>>> negative) value: -17152036540
>>> ==8674== at 0x4C320A6: memalign (in
>>> /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
>>> ==8674== by 0x4F0CFF2: PetscMallocAlign(unsigned long, int, char
>>> const*, char const*, void**) (mal.c:28)
>>> ==8674== by 0x4F0F716: PetscTrMallocDefault(unsigned long, int, char
>>> const*, char const*, void**) (mtr.c:188)
>>> ==8674== by 0x569AF3E: MatSeqAIJSetPreallocation_SeqAIJ (aij.c:3595)
>>> ==8674== by 0x569A531: MatSeqAIJSetPreallocation (aij.c:3539)
>>> ==8674== by 0x599080A: DMCreateMatrix_DA_3d_MPIAIJ(_p_DM*, _p_Mat*)
>>> (fdda.c:1085)
>>> ==8674== by 0x598B937: DMCreateMatrix_DA(_p_DM*, _p_Mat**)
>>> (fdda.c:759)
>>> ==8674== by 0x58A2BF2: DMCreateMatrix (dm.c:956)
>>> ==8674== by 0x5E377B3: KSPSetUp (itfunc.c:262)
>>> ==8674== by 0x409FFC: PetscAdLemTaras3D::solveModel(bool)
>>> (PetscAdLemTaras3D.hxx:255)
>>> ==8674== by 0x4239FB: AdLem3D<3u>::solveModel(bool, bool, bool)
>>> (AdLem3D.hxx:551)
>>> ==8674== by 0x41BD17: main (PetscAdLemMain.cxx:344)
>>> ==8674==
>>> On Fri, 14 Feb 2020 at 17:07, Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>>> Richard,
>>>> It is likely that for these problems some of the integers become
>>>> too large for the int variable to hold them, thus they overflow and become
>>>> negative.
>>>> You should make a new PETSC_ARCH configuration of PETSc that uses
>>>> the configure option --with-64-bit-indices, this will change PETSc to use
>>>> 64 bit integers which will not overflow.
>>>> Good luck and let us know how it works out
>>>> Barry
>>>> Probably the code is built with an older version of PETSc; the
>>>> later versions should produce a more useful error message.
>>>> > On Feb 13, 2020, at 11:43 PM, Richard Beare via petsc-users <
>>>> > Hi Everyone,
>>>> > I am experimenting with the Simlul at trophy tool (
>>>> https://github.com/Inria-Asclepios/simul-atrophy) that uses petsc to
>>>> simulate brain atrophy based on segmented MRI data. I am not the author. I
>>>> have this running on most of a dataset of about 50 scans, but experience
>>>> crashes with several that I am trying to track down. However I am out of
>>>> ideas. The problem images are slightly bigger than some of the successful
>>>> ones, but not substantially so, and I have experimented on machines with
>>>> sufficient RAM. The error happens very quickly, as part of setup - see the
>>>> valgrind report below. I haven't managed to get the sgcheck tool to work
>>>> yet. I can only guess that the ksp object is somehow becoming corrupted
>>>> during the setup process, but the array sizes that I can track (which
>>>> derive from image sizes), appear correct at every point I can check. Any
>>>> suggestions as to how I can check what might go wrong in the setup of the
>>>> ksp object?
>>>> > Thankyou.
>>>> > valgrind tells me:
>>>> > ==18175== Argument 'size' of function memalign has a fishy (possibly
>>>> negative) value: -17152038144
>>>> > ==18175== at 0x4C320A6: memalign (in
>>>> > ==18175== by 0x4F0F1F2: PetscMallocAlign(unsigned long, int, char
>>>> > ==18175== by 0x56B43CA: MatSeqAIJSetPreallocation_SeqAIJ
>>>> (aij.c:3595)
>>>> > ==18175== by 0x56B39BD: MatSeqAIJSetPreallocation (aij.c:3539)
>>>> > ==18175== by 0x59A9B44: DMCreateMatrix_DA_3d_MPIAIJ(_p_DM*,
>>>> _p_Mat*) (fdda.c:1085)
>>>> > ==18175== by 0x59A4C71: DMCreateMatrix_DA(_p_DM*, _p_Mat**)
>>>> (fdda.c:759)
>>>> > ==18175== by 0x58BBD29: DMCreateMatrix (dm.c:956)
>>>> > ==18175== by 0x5E509D5: KSPSetUp (itfunc.c:262)
>>>> > ==18175== by 0x40A3DE: PetscAdLemTaras3D::solveModel(bool)
>>>> (PetscAdLemTaras3D.hxx:269)
>>>> > ==18175== by 0x42413F: AdLem3D<3u>::solveModel(bool, bool, bool)
>>>> (AdLem3D.hxx:552)
>>>> > ==18175== by 0x41C25C: main (PetscAdLemMain.cxx:349)
>>>> > ==18175==
>>>> > A/Prof Richard Beare
>>>> > Imaging and Bioinformatics, Peninsula Clinical School
>>>> > orcid.org/0000-0002-7530-5664
>>>> > Richard.Beare at monash.edu
>>>> > +61 3 9788 1724
>>>> > Geospatial Research:
>>>> https://www.monash.edu/medicine/scs/medicine/research/geospatial-analysis
>>> +61 3 9788 1724
> +61 3 9788 1724
+61 3 9788 1724
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200215/6c7fb399/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200215/6c7fb399/attachment-0001.obj>
