[petsc-users] Crash caused by strange error in KSPSetUp
Smith, Barry F. bsmith at mcs.anl.gov
Fri Feb 14 00:07:24 CST 2020
   Richard,
     It is likely that for these problems some of the integers become too large for the int variable to hold them, thus they overflow and become negative.
     You should make a new PETSC_ARCH configuration of PETSc that uses the configure option --with-64-bit-indices, this will change PETSc to use 64 bit integers which will not overflow.
     Good luck and let us know how it works out
    Barry
     Probably the code is built with an older version of PETSc; the later versions should produce a more useful error message.
> On Feb 13, 2020, at 11:43 PM, Richard Beare via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi Everyone,
> I am experimenting with the Simlul at trophy tool (https://github.com/Inria-Asclepios/simul-atrophy) that uses petsc to simulate brain atrophy based on segmented MRI data. I am not the author. I have this running on most of a dataset of about 50 scans, but experience crashes with several that I am trying to track down. However I am out of ideas. The problem images are slightly bigger than some of the successful ones, but not substantially so, and I have experimented on machines with sufficient RAM. The error happens very quickly, as part of setup - see the valgrind report below. I haven't managed to get the sgcheck tool to work yet. I can only guess that the ksp object is somehow becoming corrupted during the setup process, but the array sizes that I can track (which derive from image sizes), appear correct at every point I can check. Any suggestions as to how I can check what might go wrong in the setup of the ksp object?
> Thankyou.
> valgrind tells me:
> ==18175== Argument 'size' of function memalign has a fishy (possibly negative) value: -17152038144
> ==18175==    at 0x4C320A6: memalign (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> ==18175==    by 0x4F0F1F2: PetscMallocAlign(unsigned long, int, char const*, char const*, void**) (mal.c:28)
> ==18175==    by 0x56B43CA: MatSeqAIJSetPreallocation_SeqAIJ (aij.c:3595)
> ==18175==    by 0x56B39BD: MatSeqAIJSetPreallocation (aij.c:3539)
> ==18175==    by 0x59A9B44: DMCreateMatrix_DA_3d_MPIAIJ(_p_DM*, _p_Mat*) (fdda.c:1085)
> ==18175==    by 0x59A4C71: DMCreateMatrix_DA(_p_DM*, _p_Mat**) (fdda.c:759)
> ==18175==    by 0x58BBD29: DMCreateMatrix (dm.c:956)
> ==18175==    by 0x5E509D5: KSPSetUp (itfunc.c:262)
> ==18175==    by 0x40A3DE: PetscAdLemTaras3D::solveModel(bool) (PetscAdLemTaras3D.hxx:269)
> ==18175==    by 0x42413F: AdLem3D<3u>::solveModel(bool, bool, bool) (AdLem3D.hxx:552)
> ==18175==    by 0x41C25C: main (PetscAdLemMain.cxx:349)
> ==18175==
> A/Prof Richard Beare
> Imaging and Bioinformatics, Peninsula Clinical School
> orcid.org/0000-0002-7530-5664
> Richard.Beare at monash.edu
> +61 3 9788 1724
> Geospatial Research: https://www.monash.edu/medicine/scs/medicine/research/geospatial-analysis
