[petsc-users] Question regarding the EPSSetDimensions routine
baikadi pranay pranayreddy865 at gmail.com
Thu Feb 13 15:03:37 CST 2020
Thank you Jose for the reply.
If I set PETSC_DEFAULT_INTEGER for ncv as suggested in the EPSSetDimensions
documentation, I am still running into the same problem. Also, could you
elaborate on what you mean by checking convergence with a monitor. Do you
mean comparing the eigenvalues for ith and (i+1)th iterations and plotting
the difference to see convergence?
Sincerely,
Pranay.
ᐧ
On Thu, Feb 13, 2020 at 1:54 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> For nev=10 you are using a subspace of size 20. This may be too small.
> Check convergence with a monitor and increase ncv if necessary.
> Jose
> El 13 feb 2020, a las 21:25, baikadi pranay <pranayreddy865 at gmail.com>
> escribió:
> Hello PETSc Users,
> I am trying to find the lowest 'n' eigenvalues of a hermitian eigenvalue
> problem. The size of the operator matrix (hamiltonian in my case) is
> dependent on the mesh spacing provided by the user (which is expected).
> However I have the following issue:
> The number of eigenvalues given by the solver is not consistent with what
> is given as input in the EPSSetDimensions routine. For example, for a
> 12000x12000 matrix, the solver gives 20 correct eigenvalues if nev=20, but
> fails to give any eigenvalue if nev=10.
> I am using the following lines of code to solve the problem:
> *call EPSCreate(PETSC_COMM_WORLD,eps,ierr)*
> *call EPSSetOperators(eps,ham,PETSC_NULL_MAT,ierr)call
> EPSSetProblemType(eps,EPS_HEP,ierr)call
> EPSSetWhichEigenpairs(eps,EPS_SMALLEST_MAGNITUDE,ierr)call
> EPSSetDimensions(eps,n_sub,n_sub*2,PETSC_DEFAULT_INTEGER,ierr)*
> *call EPSSetTolerances(eps,1D-10,5000,ierr)call EPSSolve(eps,ierr)*
> After the EPSSolve, I am calling EPSGetEigenPair and other relevant
> routines to get the eigenvector and eigenvalues.
> Any lead as to how to solve this problem would be greatly helpful to us.
> Please let me know if I need to provide any further information.
> Thank you for your time.
> Sincerely,
> Pranay.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200213/8bd12d38/attachment.html>
