[petsc-users] Implementing the Sherman Morisson formula (low rank update) in petsc4py and FEniCS?
Matthew Knepley
knepley at gmail.com
Mon Feb 10 11:13:05 CST 2020
On Mon, Feb 10, 2020 at 9:09 AM Olek Niewiarowski <aan2 at princeton.edu>
wrote:
> Barry,
> Thank you for your help and detailed suggestions. I will try to implement
> what you proposed and will follow-up with any questions. In the meantime, I
> just want to make sure I understand the use of SNESSetPicard:
> *r* - vector to store function value
> *b* - function evaluation routine - *my F(u) function *
> *Amat* - matrix with which A(x) x - b(x) is to be computed -* a
> MatCreateLRC() -- what's the best way of passing in scalar k?*
> *Pmat* - matrix from which preconditioner is computed (usually the same
> as Amat) - * a regular Mat()*
> *J* - function to compute matrix value, see SNESJacobianFunction
> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESJacobianFunction.html#SNESJacobianFunction>
> for details on its calling sequence -- * computes K + kaa' *
> By the way, the manual page states "we do not recommend using this
> routine. It is far better to provide the nonlinear function F() and some
> approximation to the Jacobian and use an approximate Newton solver :-)"
This is still correct. Barry is suggesting Picard since the implementation
for you is a little bit simpler. However, the Picard solver
is missing the K' piece of the Jacobian, so it will only ever convergence
linearly, as opposed to quadratically for Newton in the convergence
basin. However, once you have Picard going, it will be simple to switch to
Newton by just providing that extra piece.
Matt
> Thanks again!
> *Alexander (Olek) Niewiarowski*
> PhD Candidate, Civil & Environmental Engineering
> Princeton University, 2020
> Cell: +1 (610) 393-2978
> *From:* Smith, Barry F. <bsmith at mcs.anl.gov>
> *Sent:* Thursday, February 6, 2020 13:25
> *To:* Olek Niewiarowski <aan2 at princeton.edu>
> *Cc:* Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Implementing the Sherman Morisson formula
> If I remember your problem is K(u) + kaa' = F(u)
> You should start by creating a SNES and calling SNESSetPicard. Read its
> manual page. Your matrix should be a MatCreateLRC() for the Mat argument
> to SNESSetPicard and the Peat should be just your K matrix.
> If you run with -ksp_fd_operator -pc_type lu will be using K to
> precondition K + kaa' + d F(U)/dU . Newton's method should converge at
> quadratic order. You can use -ksp_fd_operator -pc_type anything else to use
> an iterative linear solver as the preconditioner of K.
> If you really want to use Sherman Morisson formula then you would
> create a PC shell and do
> typedef struct{
> KSP innerksp;
> Vec u_1,u_2;
> } YourStruct;
> SNESGetKSP(&ksp);
> KSPGetPC(&pc);
> PCSetType(pc,PCSHELL);
> PCShellSetApply(pc,YourPCApply)
> PetscMemclear(yourstruct,si
> PCShellSetContext(pc,&yourstruct);
> Then
> YourPCApply(PC pc,Vec in, Vec out)
> YourStruct *yourstruct;
> PCShellGetContext(pc,(void**)&yourstruct)
> if (!yourstruct->ksp) {
> PCCreate(comm,&yourstruct->ksp);
> KSPSetPrefix(yourstruct->ksp,"yourpc_");
> Mat A,B;
> KSPGetOperators(ksp,&A,&B);
> KSPSetOperators(yourstruct->ksp,A,B);
> create work vectors
> Apply the solve as you do for the linear case with Sherman Morisson
> formula
> This you can run with for example -yourpc_pc_type cholesky
> Barry
> Looks complicated, conceptually simple.
> > 2) Call KSPSetOperators(ksp, K, K,)
> > 3) Solve the first system KSPSolve(ksp, -F, u_1)
> > 4) Solve the second system KSPSolve(ksp, a, u_2)
> > 5) Calculate beta VecDot(a, u_2, &gamma); beta = 1./(1. + k*gamma);
> > 6) Update the guess VecDot(u_2, F, &delta); VecAXPBYPCZ(u, 1.0,
> beta*delta, 1.0, u_1, u_2)
> No
> > On Feb 6, 2020, at 9:02 AM, Olek Niewiarowski <aan2 at princeton.edu>
> wrote:
> > Hi Matt,
> > What you suggested in your last email was exactly what I did on my very
> first attempt at the problem, and while it "worked," convergence was not
> satisfactory due to the Newton step being fixed in step 6. This is the
> reason I would like to use the linesearch in SNES instead. Indeed in your
> manual you "recommend most PETSc users work directly with SNES, rather than
> using PETSc for the linear problem within a nonlinear solver." Ideally I'd
> like to create a SNES solver, pass in the functions to evaluate K, F, a,
> and k, and set up the underlying KSP object as in my first message. Is this
> possible?
> > Thanks,
> > From: Matthew Knepley <knepley at gmail.com>
> > Sent: Thursday, February 6, 2020 5:33
> > To: Olek Niewiarowski <aan2 at princeton.edu>
> > Cc: Smith, Barry F. <bsmith at mcs.anl.gov>; petsc-users at mcs.anl.gov <
> > Subject: Re: [petsc-users] Implementing the Sherman Morisson formula
> > On Wed, Feb 5, 2020 at 8:53 PM Olek Niewiarowski <aan2 at princeton.edu>
> wrote:
> > Hi Barry and Matt,
> > Thank you for your input and for creating a new issue in the repo.
> > My initial question was more basic (how to configure the SNES's KSP
> solver as in my first message with a and k), but now I see there's more to
> the implementation. To reiterate, for my problem's structure, a good
> solution algorithm (on the algebraic level) is the following "double
> back-substitution":
> > For each nonlinear iteration:
> > • define intermediate vectors u_1 and u_2
> > • solve Ku_1 = -F --> u_1 = -K^{-1}F (this solve is cheap, don't
> actually need K^-1)
> > • solve Ku_2 = -a --> u_2 = -K^{-1}a (ditto)
> > • define \beta = 1/(1 + k a^Tu_2)
> > • \Delta u = u_1 + \beta k u_2^T F u_2
> > • u = u + \Delta u
> > This is very easy to setup:
> > 1) Create a KSP object KSPCreate(comm, &ksp)
> > Thanks,
> > Matt
> > I don't need the Jacobian inverse, [K−kaaT]-1 = K-1 - (kK-1
> aaTK-1)/(1+kaTK-1a) just the solution Δu = [K−kaaT]-1F = K-1F - (kK-1
> aFK-1a)/(1 + kaTK-1a)
> > = u_1 + beta k u_2^T F u_2 (so I never need to invert K either). (To
> Matt's point on gitlab, K is a symmetric sparse matrix arising from a
> bilinear form. ) Also, eventually, I want to have more than one low-rank
> updates to K, but again, Sherman Morrisson Woodbury should still work.
> > Being new to PETSc, I don't know if this algorithm directly translates
> into an efficient numerical solver. (I'm also not sure if Picard iteration
> would be useful here.) What would it take to set up the KSP solver in SNES
> like I did below? Is it possible "out of the box"? I looked at
> MatCreateLRC() - what would I pass this to? (A pointer to demo/tutorial
> would be very appreciated.) If there's a better way to go about all of
> this, I'm open to any and all ideas. My only limitation is that I use
> petsc4py exclusively since I/future users of my code will not be
> comfortable with C.
> > Thanks again for your help!
> > From: Smith, Barry F. <bsmith at mcs.anl.gov>
> > Sent: Wednesday, February 5, 2020 15:46
> > To: Matthew Knepley <knepley at gmail.com>
> > Cc: Olek Niewiarowski <aan2 at princeton.edu>; petsc-users at mcs.anl.gov <
> > https://gitlab.com/petsc/petsc/issues/557
> > > On Feb 5, 2020, at 7:35 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > > Perhaps Barry is right that you want Picard, but suppose you really
> want Newton.
> > > "This problem can be solved efficiently using the Sherman-Morrison
> formula" Well, maybe. The main assumption here is that inverting K is
> cheap. I see two things you can do in a straightforward way:
> > > 1) Use MatCreateLRC()
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateLRC.html
> to create the Jacobian
> > > and solve using an iterative method. If you pass just K was the
> preconditioning matrix, you can use common PCs.
> > > 2) We only implemented MatMult() for LRC, but you could stick your
> SMW code in for MatSolve_LRC if you really want to factor K. We would
> > > of course help you do this.
> > > Thanks,
> > > Matt
> > > On Wed, Feb 5, 2020 at 1:36 AM Smith, Barry F. via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > > I am not sure of everything in your email but it sounds like you
> want to use a "Picard" iteration to solve [K(u)−kaaT]Δu=−F(u). That is solve
> > > A(u^{n}) (u^{n+1} - u^{n}) = F(u^{n}) - A(u^{n})u^{n} where A(u) =
> K(u) - kaaT
> > > PETSc provides code to this with SNESSetPicard() (see the manual
> pages) I don't know if Petsc4py has bindings for this.
> > > Adding missing python bindings is not terribly difficult and you may
> be able to do it yourself if this is the approach you want.
> > > Barry
> > > > On Feb 4, 2020, at 5:07 PM, Olek Niewiarowski <aan2 at princeton.edu>
> wrote:
> > > > Hello,
> > > > I am a FEniCS user but new to petsc4py. I am trying to modify the
> KSP solver through the SNES object to implement the Sherman-Morrison
> formula(e.g. http://fourier.eng.hmc.edu/e176/lectures/algebra/node6.html
> ). I am solving a nonlinear system of the form [K(u)−kaaT]Δu=−F(u). Here
> the jacobian matrix K is modified by the term kaaT, where k is a scalar.
> Notably, K is sparse, while the term kaaT results in a full matrix. This
> problem can be solved efficiently using the Sherman-Morrison formula :
> > > > [K−kaaT]-1 = K-1 - (kK-1 aaTK-1)/(1+kaTK-1a)
> > > > I have managed to successfully implement this at the linear solve
> level (by modifying the KSP solver) inside a custom Newton solver in python
> by following an incomplete tutorial at
> https://www.firedrakeproject.org/petsc-interface.html#defining-a-preconditioner
> > > > • while (norm(delU) > alpha): # while not converged
> > > > • self.update_F() # call to method to update r.h.s
> form
> > > > • self.update_K() # call to update the jacobian form
> > > > • K = assemble(self.K) # assemble the jacobian
> matrix
> > > > • F = assemble(self.F) # assemble the r.h.s vector
> > > > • a = assemble(self.a_form) # assemble the a_form
> (see Sherman Morrison formula)
> > > > • for bc in self.mem.bc: # apply boundary conditions
> > > > • bc.apply(K, F)
> > > > • bc.apply(K, a)
> > > > • B = PETSc.Mat().create()
> > > > • # Assemble the bilinear form that defines A and
> get the concrete
> > > > • # PETSc matrix
> > > > • A = as_backend_type(K).mat() # get the PETSc
> objects for K and a
> > > > • u = as_backend_type(a).vec()
> > > > • # Build the matrix "context" # see firedrake docs
> > > > • Bctx = MatrixFreeB(A, u, u, self.k)
> > > > • # Set up B
> > > > • # B is the same size as A
> > > > • B.setSizes(*A.getSizes())
> > > > • B.setType(B.Type.PYTHON)
> > > > • B.setPythonContext(Bctx)
> > > > • B.setUp()
> > > > • ksp = PETSc.KSP().create() # create the KSP
> linear solver object
> > > > • ksp.setOperators(B)
> > > > • ksp.setUp()
> > > > • pc = ksp.pc
> > > > • pc.setType(pc.Type.PYTHON)
> > > > • pc.setPythonContext(MatrixFreePC())
> > > > • ksp.setFromOptions()
> > > > • solution = delU # the incremental displacement
> at this iteration
> > > > • b = as_backend_type(-F).vec()
> > > > • delu = solution.vector().vec()
> > > > • ksp.solve(b, delu)
> > > > • self.mem.u.vector().axpy(0.25,
> self.delU.vector()) # poor man's linesearch
> > > > • counter += 1
> > > > Here is the corresponding petsc4py code adapted from the firedrake
> docs:
> > > > • class MatrixFreePC(object):
> > > > • def setUp(self, pc):
> > > > • B, P = pc.getOperators()
> > > > • # extract the MatrixFreeB object from B
> > > > • ctx = B.getPythonContext()
> > > > • self.A = ctx.A
> > > > • self.u = ctx.u
> > > > • self.v = ctx.v
> > > > • self.k = ctx.k
> > > > • # Here we build the PC object that uses the
> concrete,
> > > > • # assembled matrix A. We will use this to apply the
> action
> > > > • # of A^{-1}
> > > > • self.pc = PETSc.PC().create()
> > > > • self.pc.setOptionsPrefix("mf_")
> > > > • self.pc.setOperators(self.A)
> > > > • self.pc.setFromOptions()
> > > > • # Since u and v do not change, we can build the
> denominator
> > > > • # and the action of A^{-1} on u only once, in the
> setup
> > > > • # phase.
> > > > • tmp = self.A.createVecLeft()
> > > > • self.pc.apply(self.u, tmp)
> > > > • self._Ainvu = tmp
> > > > • self._denom = 1 + self.k*self.v.dot(self._Ainvu)
> > > > • def apply(self, pc, x, y):
> > > > • # y <- A^{-1}x
> > > > • self.pc.apply(x, y)
> > > > • # alpha <- (v^T A^{-1} x) / (1 + v^T A^{-1} u)
> > > > • alpha = (self.k*self.v.dot(y)) / self._denom
> > > > • # y <- y - alpha * A^{-1}u
> > > > • y.axpy(-alpha, self._Ainvu)
> > > > • class MatrixFreeB(object):
> > > > • def __init__(self, A, u, v, k):
> > > > • self.A = A
> > > > • self.u = u
> > > > • self.v = v
> > > > • self.k = k
> > > > • def mult(self, mat, x, y):
> > > > • # y <- A x
> > > > • self.A.mult(x, y)
> > > > • # alpha <- v^T x
> > > > • alpha = self.v.dot(x)
> > > > • # y <- y + alpha*u
> > > > • y.axpy(alpha, self.u)
> > > > However, this approach is not efficient as it requires many
> iterations due to the Newton step being fixed, so I would like to implement
> it using SNES and use line search. Unfortunately, I have not been able to
> find any documentation/tutorial on how to do so. Provided I have the FEniCS
> forms for F, K, and a, I'd like to do something along the lines of:
> > > > solver = PETScSNESSolver() # the FEniCS SNES wrapper
> > > > snes = solver.snes() # the petsc4py SNES object
> > > > ksp = snes.getKSP()
> > > > # set ksp option similar to above
> > > > solver.solve()
> > > > I would be very grateful if anyone could could help or point me to a
> reference or demo that does something similar (or maybe a completely
> different way of solving the problem!).
> > > > Many thanks in advance!
> > > > Alex
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200210/4063f336/attachment-0001.html>
