[petsc-users] Condition Number and GMRES iteration
Fande Kong
fdkong.jd at gmail.com
Fri Feb 7 13:15:14 CST 2020
On Fri, Feb 7, 2020 at 11:43 AM Victor Eijkhout <eijkhout at tacc.utexas.edu>
wrote:
> On , 2020Feb7, at 12:31, Mark Adams <mfadams at lbl.gov> wrote:
> BTW, one of my earliest talks, in grad school before I had any real
> results, was called "condition number does not matter”
> After you learn that the condition number gives an _upper_bound_ on the
> number of iterations, you learn that if a few eigenvalues are separated
> from a cluster of other eigenvalues, your number of iterations is 1 for
> each separated one, and then a bound based on the remaining cluster.
> (Condition number predicts a number of iterations based on Chebychev
> polynomials. Since the CG polynomials are optimal, they are at least as
> good as Chebychev. Hence the number of iterations is at most what you got
> from Chebychev, which is the condition number bound.)
I like this explanation for normal matrices. Thanks so much, Victor,
Fande,
> Victor.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200207/954a042a/attachment.html>
