[petsc-users] Condition Number and GMRES iteration
Fande Kong
fdkong.jd at gmail.com
Fri Feb 7 13:14:08 CST 2020
Thanks, Matt,
It is a great paper. According to the paper, here is my understanding: for
normal matrices, the eigenvalues of the matrix together with the
initial residual completely determine the GMRES convergence rate. For
non-normal matrices, eigenvalues are NOT the relevant quantities in
determining the behavior of GMRES.
What quantities we should look at for non-normal matrices? In other words,
how do we know one matrix is easier than others to solve? Possibly they
are still open problems?!
Fande,
On Fri, Feb 7, 2020 at 6:51 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 6, 2020 at 7:37 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Hi All,
>> MOOSE team, Alex and I are working on some variable scaling techniques to
>> improve the condition number of the matrix of linear systems. The goal of
>> variable scaling is to make the diagonal of matrix as close to unity as
>> possible. After scaling (for certain example), the condition number of the
>> linear system is actually reduced, but the GMRES iteration does not
>> decrease at all.
>> From my understanding, the condition number is the worst estimation for
>> GMRES convergence. That is, the GMRES iteration should not increases when
>> the condition number decreases. This actually could example what we saw:
>> the improved condition number does not necessary lead to a decrease in
>> GMRES iteration. We try to understand this a bit more, and we guess that
>> the number of eigenvalue clusters of the matrix of the linear system
>> may/might be related to the convergence rate of GMRES. We plot eigenvalues
>> of scaled system and unscaled system, and the clusters look different from
>> each other, but the GMRRES iterations are the same.
>> Anyone know what is the right relationship between the condition number
>> and GMRES iteration? How does the number of eigenvalue clusters affect
>> GMRES iteration? How to count eigenvalue clusters? For example, how many
>> eigenvalue clusters we have in the attach image respectively?
>> If you need more details, please let us know. Alex and I are happy to
>> provide any details you are interested in.
> Hi Fande,
> This is one of my favorite papers of all time:
> https://epubs.siam.org/doi/abs/10.1137/S0895479894275030
> It shows that the spectrum alone tells you nothing at all about GMRES
> convergence. You need other things, like symmetry (almost
> everything is known) or normality (a little bit is known).
> Thanks,
> Matt
>> Thanks,
>> Fande Kong,
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200207/4ff6c85c/attachment-0001.html>
