[petsc-users] Implementing the Sherman Morisson formula (low rank update) in petsc4py and FEniCS?
Wed Feb 5 07:35:27 CST 2020
Perhaps Barry is right that you want Picard, but suppose you really want
Newton.
"This problem can be solved efficiently using the Sherman-Morrison formula"
Well, maybe. The main assumption here is that inverting K is cheap. I see
two things you can do in a straightforward way:
  1) Use MatCreateLRC()
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateLRC.html
to create the Jacobian
       and solve using an iterative method. If you pass just K was the
preconditioning matrix, you can use common PCs.
  2) We only implemented MatMult() for LRC, but you could stick your SMW
code in for MatSolve_LRC if you really want to factor K. We would
       of course help you do this.
     Matt
On Wed, Feb 5, 2020 at 1:36 AM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>    I am not sure of everything in your email but it sounds like you want
> to use a "Picard" iteration to solve [K(u)−kaaT]Δu=−F(u). That is solve
>   A(u^{n}) (u^{n+1} - u^{n}) = F(u^{n}) - A(u^{n})u^{n}  where A(u) = K(u)
> - kaaT
>  PETSc provides code to this with SNESSetPicard() (see the manual pages) I
> don't know if Petsc4py has bindings for this.
>   Adding missing python bindings is not terribly difficult and you may be
> able to do it yourself if this is the approach you want.
>    Barry
> > On Feb 4, 2020, at 5:07 PM, Olek Niewiarowski <aan2 at princeton.edu>
> wrote:
> > Hello,
> > I am a FEniCS user but new to petsc4py. I am trying to modify the KSP
> solver through the SNES object to implement the Sherman-Morrison
> formula(e.g.  http://fourier.eng.hmc.edu/e176/lectures/algebra/node6.html
> ). I am solving a nonlinear system of the form [K(u)−kaaT]Δu=−F(u). Here
> the jacobian matrix K is modified by the term kaaT, where k is a scalar.
> Notably, K is sparse, while the term kaaT results in a full matrix. This
> problem can be solved efficiently using the Sherman-Morrison formula :
> > [K−kaaT]-1 = K-1  - (kK-1 aaTK-1)/(1+kaTK-1a)
> > I have managed to successfully implement this at the linear solve level
> (by modifying the KSP solver) inside a custom Newton solver in python by
> following an incomplete tutorial at
> https://www.firedrakeproject.org/petsc-interface.html#defining-a-preconditioner
> > •             while (norm(delU) > alpha):  # while not converged
> > •                 self.update_F()  # call to method to update r.h.s form
> > •                 self.update_K()  # call to update the jacobian form
> > •                 K = assemble(self.K)  # assemble the jacobian matrix
> > •                 F = assemble(self.F)  # assemble the r.h.s vector
> > •                 a = assemble(self.a_form)  # assemble the a_form (see
> Sherman Morrison formula)
> > •                 for bc in self.mem.bc:  # apply boundary conditions
> > •                     bc.apply(K, F)
> > •                     bc.apply(K, a)
> > •                 B = PETSc.Mat().create()
> > •                 # Assemble the bilinear form that defines A and get
> the concrete
> > •                 # PETSc matrix
> > •                 A = as_backend_type(K).mat()  # get the PETSc objects
> for K and a
> > •                 u = as_backend_type(a).vec()
> > •                 # Build the matrix "context"  # see firedrake docs
> > •                 Bctx = MatrixFreeB(A, u, u, self.k)
> > •                 # Set up B
> > •                 # B is the same size as A
> > •                 B.setSizes(*A.getSizes())
> > •                 B.setType(B.Type.PYTHON)
> > •                 B.setPythonContext(Bctx)
> > •                 B.setUp()
> > •                 ksp = PETSc.KSP().create()   # create the KSP linear
> solver object
> > •                 ksp.setOperators(B)
> > •                 ksp.setUp()
> > •                 pc = ksp.pc
> > •                 pc.setType(pc.Type.PYTHON)
> > •                 pc.setPythonContext(MatrixFreePC())
> > •                 ksp.setFromOptions()
> > •                 solution = delU    # the incremental displacement at
> this iteration
> > •                 b = as_backend_type(-F).vec()
> > •                 delu = solution.vector().vec()
> > •                 ksp.solve(b, delu)
> > •                 self.mem.u.vector().axpy(0.25, self.delU.vector())  #
> poor man's linesearch
> > •                 counter += 1
> > Here is the corresponding petsc4py code adapted from the firedrake docs:
> >       • class MatrixFreePC(object):
> >       •     def setUp(self, pc):
> >       •         B, P = pc.getOperators()
> >       •         # extract the MatrixFreeB object from B
> >       •         ctx = B.getPythonContext()
> >       •         self.A = ctx.A
> >       •         self.u = ctx.u
> >       •         self.v = ctx.v
> >       •         self.k = ctx.k
> >       •         # Here we build the PC object that uses the concrete,
> >       •         # assembled matrix A.  We will use this to apply the
> action
> >       •         # of A^{-1}
> >       •         self.pc = PETSc.PC().create()
> >       •         self.pc.setOptionsPrefix("mf_")
> >       •         self.pc.setOperators(self.A)
> >       •         self.pc.setFromOptions()
> >       •         # Since u and v do not change, we can build the
> denominator
> >       •         # and the action of A^{-1} on u only once, in the setup
> >       •         # phase.
> >       •         tmp = self.A.createVecLeft()
> >       •         self.pc.apply(self.u, tmp)
> >       •         self._Ainvu = tmp
> >       •         self._denom = 1 + self.k*self.v.dot(self._Ainvu)
> >       •     def apply(self, pc, x, y):
> >       •         # y <- A^{-1}x
> >       •         self.pc.apply(x, y)
> >       •         # alpha <- (v^T A^{-1} x) / (1 + v^T A^{-1} u)
> >       •         alpha = (self.k*self.v.dot(y)) / self._denom
> >       •         # y <- y - alpha * A^{-1}u
> >       •         y.axpy(-alpha, self._Ainvu)
> >       • class MatrixFreeB(object):
> >       •     def __init__(self, A, u, v, k):
> >       •         self.A = A
> >       •         self.u = u
> >       •         self.v = v
> >       •         self.k = k
> >       •     def mult(self, mat, x, y):
> >       •         # y <- A x
> >       •         self.A.mult(x, y)
> >       •         # alpha <- v^T x
> >       •         alpha = self.v.dot(x)
> >       •         # y <- y + alpha*u
> >       •         y.axpy(alpha, self.u)
> > However, this approach is not efficient as it requires many iterations
> due to the Newton step being fixed, so I would like to implement it using
> SNES and use line search. Unfortunately, I have not been able to find any
> documentation/tutorial on how to do so. Provided I have the FEniCS forms
> for F, K, and a, I'd like to do something along the lines of:
> > solver  = PETScSNESSolver() # the FEniCS SNES wrapper
> > snes = solver.snes()  # the petsc4py SNES object
> > ksp = snes.getKSP()
> >  # set ksp option similar to above
> > solver.solve()
> > I would be very grateful if anyone could could help or point me to a
> reference or demo that does something similar (or maybe a completely
> different way of solving the problem!).
> > Many thanks in advance!
> > Alex
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200205/ae49894c/attachment.html>
