[petsc-users] Triple increasing of allocated memory during KSPSolve calling(GMRES preconditioned by ASM)
Matthew Knepley
knepley at gmail.com
Mon Feb 3 10:34:47 CST 2020
On Mon, Feb 3, 2020 at 10:38 AM Дмитрий Мельничук <
dmitry.melnichuk at geosteertech.com> wrote:
> Hello all!
> Now I am faced with a problem associated with the memory allocation when
> calling of KSPSolve .
> GMRES preconditioned by ASM for solving linear algebra system (obtained by
> the finite element spatial discretisation of Biot poroelasticity model) was
> chosen.
> According to the output value of PetscMallocGetCurrentUsage subroutine 176
> MB for matrix and RHS vector storage is required (before KSPSolve calling).
> But during solving linear algebra system 543 MB of RAM is required (during
> KSPSolve calling).
> Thus, the amount of allocated memory after preconditioning stage increased
> three times. This kind of behaviour is critically for 3D models with
> several millions of cells.
1) In order to know anything, we have to see the output of -ksp_view,
although I see you used an overlap of 2
2) The overlap increases the size of submatrices beyond that of the
original matrix. Suppose that you used LU for the sub-preconditioner.
You would need at least 2x memory (with ILU(0)) since the matrix
dominates memory usage. Moreover, you have overlap
and you might have fill-in depending on the solver.
3) The massif tool from valgrind is a good fine-grained way to look at
memory allocation
Matt
Is there a way to decrease amout of allocated memory?
> Is that an expected behaviour for GMRES-ASM combination?
> As I remember, using previous version of PETSc didn't demonstrate so
> significante memory increasing.
> Vec :: Vec_F, Vec_U
> Mat :: Mat_K
> call MatAssemblyBegin(Mat_M,Mat_Final_Assembly,ierr)
> call MatAssemblyEnd(Mat_M,Mat_Final_Assembly,ierr)
> call VecAssemblyBegin(Vec_F_mod,ierr)
> call VecAssemblyEnd(Vec_F_mod,ierr)
> call PetscMallocGetCurrentUsage(mem, ierr)
> print *,"Memory used: ",mem
> call KSPSetType(Krylov,KSPGMRES,ierr)
> call KSPGetPC(Krylov,PreCon,ierr)
> call PCSetType(PreCon,PCASM,ierr)
> call KSPSetFromOptions(Krylov,ierr)
> call KSPSolve(Krylov,Vec_F,Vec_U,ierr)
> options = "-pc_asm_overlap 2 -pc_asm_type basic -ksp_monitor
> -ksp_converged_reason"
> Kind regards,
> Dmitry Melnichuk
> Matrix.dat (265288024) <https://yadi.sk/d/YCCJRsUVmFK9XA>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200203/8005798d/attachment.html>
