[petsc-users] TS tutorial ex11 in Fortran
Barry Smith bsmith at petsc.dev
Mon Dec 28 21:39:37 CST 2020
> On Dec 28, 2020, at 11:52 AM, Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> wrote:
> However in Fortran, for the VTK output, it is true I do not view ts->vec_sol directly but rather a Vec called sol that I use in the TSSolve(ts, sol) call ... but I suppose it should be equivalent shouldn’t it ?
  This can be tricky. As the integrator runs it may not always be updating the vector you pass into TSSolve. It is only when TSSolve returns that the values in sol are guaranteed to match the TS solution. It is better if your VTK output code call something to get get the current solution and not use your Fortran sol vector.
  For example if you register a monitor function one of its arguments is always the correct current solution.  I think you can also call TSGetSolution to return a vector that contains the current solution.
  Barry
> Le lun. 28 déc. 2020 à 18:42, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> a écrit :
> I think I'm not following something. The time stepper implementation (TSStep_XYZ) is where ts->vec_sol should be updated. The controller doesn't have anything to do with it. What TS are you using and how do you know your RHS is nonzero?
> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> writes:
> > Hi Jed,
> > Thanks for your message.
> > I implemented everything in C as you suggested and it works fine except for
> > one thing : the ts->vec_sol does not seem to get updated when seen from the
> > C code (it is on the Fortran side though the solution is correct).
> > As a result, the time step (that uses among other things the max velocity
> > in the domain) is always at the value it gets from the initial solution.
> > Any idea why ts->vec_sol does not seem to be updated ? (I checked the
> > stepnum and time is updated though , when accessed with TSGetTime for
> > instance).
> > Cheers,
> > Thibault
> > Le lun. 28 déc. 2020 à 15:30, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> a écrit :
> >> > Good morning everyone,
> >> > Thank you Barry for the answer, it works now !
> >> > I am facing (yet) another situation: the TSAdaptRegister function.
> >> > In the MR on gitlab, Jed mentioned that sometimes, when function pointers
> >> > are not stored in PETSc objects, one can use stack memory to pass that
> >> > pointer from fortran to C.
> >> The issue with stack memory is that when it returns, that memory is
> >> invalid. You can't use it in this instance.
> >> I think you're going to have problems implementing a TSAdaptCreate_XYZ in
> >> Fortran (because the body of that function will need to access private
> >> struct members; see below).
> >> I would implement what you need in C and you can call out to Fortran if
> >> you want from inside TSAdaptChoose_YourMethod().
> >> PETSC_EXTERN PetscErrorCode TSAdaptCreate_DSP(TSAdapt adapt)
> >>   TSAdapt_DSP    *dsp;
> >>   PetscErrorCode ierr;
> >>   PetscFunctionBegin;
> >>   ierr = PetscNewLog(adapt,&dsp);CHKERRQ(ierr);
> >>   adapt->reject_safety = 1.0; /* unused */
> >>   adapt->data                = (void*)dsp;
> >>   adapt->ops->choose         = TSAdaptChoose_DSP;
> >>   adapt->ops->setfromoptions = TSAdaptSetFromOptions_DSP;
> >>   adapt->ops->destroy        = TSAdaptDestroy_DSP;
> >>   adapt->ops->view           = TSAdaptView_DSP;
> >>   ierr =
> >> PetscObjectComposeFunction((PetscObject)adapt,"TSAdaptDSPSetFilter_C",TSAdaptDSPSetFilter_DSP);CHKERRQ(ierr);
> >>   ierr =
> >> PetscObjectComposeFunction((PetscObject)adapt,"TSAdaptDSPSetPID_C",TSAdaptDSPSetPID_DSP);CHKERRQ(ierr);
> >>   ierr = TSAdaptDSPSetFilter_DSP(adapt,"PI42");CHKERRQ(ierr);
> >>   ierr = TSAdaptRestart_DSP(adapt);CHKERRQ(ierr);
> >>   PetscFunctionReturn(0);
> >> > Can anyone develop that idea ? Because for TSAdaptRegister, i guess the
> >> > wrapper would start like :
> >> > PETSC_EXTERN void tsadaptregister_(char *sname,
> >> >                                    void
> >> (*func)(TSAdapt*,PetscErrorCode*),
> >> >                                    PetscErrorCode *ierr,
> >> >                                    PETSC_FORTRAN_CHARLEN_T snamelen)
> >> > but then the C TSAdaptRegister function takes a PetscErrorCode
> >> > (*func)(TSAdapt) function pointer as argument ... I cannot use any
> >> > FORTRAN_CALLBACK here since I do not have any object to hook it to, and I
> >> > could not find a similar situation among the pre-existing wrappers. Does
> >> > anyone have an idea on how to proceed ?
> >> > Thanks !!
> >> > Thibault
> >> > Le mar. 22 déc. 2020 à 21:20, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a écrit :
> >> >> PetscObjectUseFortranCallback((PetscDS)ctx,
> >> >> *ierr = PetscObjectSetFortranCallback((PetscObject)*prob
> >> >>   It looks like the problem is that these user provided functions do not
> >> >> take a PetscDS directly as an argument so the Fortran callback
> >> information
> >> >> cannot be obtained from them.
> >> >> The manual page for PetscDSAddBoundary() says
> >> >>  - ctx         - An optional user context for bcFunc
> >> >> but then when it lists the calling sequence for bcFunc it does not list
> >> >> the ctx as an argument, so either the manual page or code is wrong.
> >> >> It looks  like you make the ctx be the PetscDS prob argument when you
> >> >> call PetscDSAddBoundary
> >> >> In principle this sounds like it might work. I think you need to track
> >> >> through the debugger to see if the ctx passed to ourbocofunc() is
> >> >> actually the PetscDS prob variable and if not why it is not.
> >> >>   Barry
> >> >> On Dec 22, 2020, at 5:49 AM, Thibault Bridel-Bertomeu <
> >> >> thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> wrote:
> >> >> Dear all,
> >> >> I have hit two snags while implementing the missing wrappers necessary
> >> to
> >> >> transcribe ex11 to Fortran.
> >> >> First is about the PetscDSAddBoundary wrapper, that I have done so :
> >> >> static PetscErrorCode ourbocofunc(PetscReal time, const PetscReal *c,
> >> >> const PetscReal *n, const PetscScalar *a_xI, const PetscScalar *a_xG,
> >> void
> >> >> *ctx)
> >> >>     PetscObjectUseFortranCallback((PetscDS)ctx, bocofunc,
> >> >>                                   (PetscReal*,const PetscReal*,const
> >> >> PetscReal*,const PetscScalar*,const PetscScalar*,void*,PetscErrorCode*),
> >> >>                                   (&time,c,n,a_xI,a_xG,ctx,&ierr));
> >> >> static PetscErrorCode ourbocofunc_time(PetscReal time, const PetscReal
> >> *c,
> >> void
> >> >> *ctx)
> >> >>     PetscObjectUseFortranCallback((PetscDS)ctx, bocofunc_time,
> >> >> PETSC_EXTERN void petscdsaddboundary_(PetscDS *prob,
> >> >> DMBoundaryConditionType *type, char *name, char *labelname, PetscInt
> >> >> *field, PetscInt *numcomps, PetscInt *comps,
> >> >>                                       void (*bcFunc)(void),
> >> >>                                       void (*bcFunc_t)(void),
> >> >>                                       PetscInt *numids, const PetscInt
> >> >> *ids, void *ctx, PetscErrorCode *ierr,
> >> >>                                       PETSC_FORTRAN_CHARLEN_T namelen,
> >> >> PETSC_FORTRAN_CHARLEN_T labelnamelen)
> >> >>     char *newname, *newlabelname;
> >> >>     FIXCHAR(name, namelen, newname);
> >> >>     FIXCHAR(labelname, labelnamelen, newlabelname);
> >> >>     *ierr = PetscObjectSetFortranCallback((PetscObject)*prob,
> >> >> PETSC_FORTRAN_CALLBACK_CLASS, &bocofunc,      (PetscVoidFunction)bcFunc,
> >> >> ctx);
> >> >> PETSC_FORTRAN_CALLBACK_CLASS, &bocofunc_time,
> >> (PetscVoidFunction)bcFunc_t,
> >> >> ctx);
> >> >>     *ierr = PetscDSAddBoundary(*prob, *type, newname, newlabelname,
> >> >> *field, *numcomps, comps,
> >> >>                                (void (*)(void))ourbocofunc,
> >> >>                                (void (*)(void))ourbocofunc_time,
> >> >>                                *numids, ids, *prob);
> >> >>     FREECHAR(name, newname);
> >> >>     FREECHAR(labelname, newlabelname);
> >> >> but when I call it in the program, with adequate routines,  I obtain the
> >> >> following error :
> >> >> [0]PETSC ERROR: --------------------- Error Message
> >> --------------------------------------------------------------[0]PETSC
> >> ERROR: Corrupt argument:
> >> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC>
> >> ERROR: Fortran callback not set on this object[0]PETSC ERROR: See
> >> https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> >> shooting.[0]PETSC ERROR: Petsc Development GIT revision:
> >> v3.14.2-297-gf36a7edeb8  GIT Date: 2020-12-18 04:42:53 +0000[0]PETSC ERROR:
> >> ../../../bin/eulerian3D on a  named macbook-pro-de-thibault.home by tbridel
> >> Sun Dec 20 15:05:15 2020[0]PETSC ERROR: Configure options --with-clean=0
> >> --prefix=/Users/tbridel/Documents/1-CODES/04-PETSC/build --with-make-np=2
> >> --with-windows-graphics=0 --with-debugging=0 --download-fblaslapack
> >> --download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
> >> --PETSC_ARCH=macosx
> >> --with-fc=/usr/local/Cellar/open-mpi/4.0.1_2/bin/mpifort
> >> --with-cc=/usr/local/Cellar/open-mpi/4.0.1_2/bin/mpicc
> >> --with-cxx=/usr/local/Cellar/open-mpi/4.0.1_2/bin/mpic++ --with-openmp=0
> >> --download-hypre=yes --download-sowing=yes --download-metis=yes
> >> --download-parmetis=yes --download-triangle=yes --download-tetgen=yes
> >> --download-ctetgen=yes --download-p4est=yes --download-zlib=yes
> >> --download-c2html=yes --download-eigen=yes --download-pragmatic=yes
> >> --with-hdf5-dir=/usr/local/Cellar/hdf5/1.10.5_1
> >> --with-cmake-dir=/usr/local/Cellar/cmake/3.15.3[0]PETSC ERROR: #1
> >> PetscObjectGetFortranCallback() line 258 in
> >> /Users/tbridel/Documents/1-CODES/04-PETSC/src/sys/objects/inherit.c[0]PETSC
> >> ERROR: #2 ourbocofunc() line 141 in
> >> /Users/tbridel/Documents/1-CODES/59-EULERIAN3D/sources/petsc_wrapping/wrapper_petsc.c[0]PETSC
> >> ERROR: #3 DMPlexInsertBoundaryValuesRiemann() line 989 in
> >> /Users/tbridel/Documents/1-CODES/04-PETSC/src/dm/impls/plex/plexfem.c[0]PETSC
> >> ERROR: #4 DMPlexInsertBoundaryValues_Plex() line 1052 in
> >> ERROR: #5 DMPlexInsertBoundaryValues() line 1142 in
> >> ERROR: #6 DMPlexComputeResidual_Internal() line 4524 in
> >> ERROR: #7 DMPlexTSComputeRHSFunctionFVM() line 74 in
> >> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/utils/dmplexts.c[0]PETSC
> >> ERROR: #8 ourdmtsrhsfunc() line 186 in
> >> ERROR: #9 TSComputeRHSFunction_DMLocal() line 105 in
> >> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/utils/dmlocalts.c[0]PETSC
> >> ERROR: #10 TSComputeRHSFunction() line 653 in
> >> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/interface/ts.c[0]PETSC
> >> ERROR: #11 TSSSPStep_RK_3() line 120 in
> >> /Users/tbridel/Documents/1-CODES/04-PETSC/src/ts/impls/explicit/ssp/ssp.c[0]PETSC
> >> ERROR: #12 TSStep_SSP() line 208 in
> >> ERROR: #13 TSStep() line 3757 in
> >> ERROR: #14 TSSolve() line 4154 in
> >> ERROR: #15 User provided function() line 0 in User file
> >> >> Second is about the DMProjectFunction wrapper, that I have done so :
> >> >> static PetscErrorCode ourdmprojfunc(PetscInt dim, PetscReal time,
> >> >> PetscReal x[], PetscInt Nf, PetscScalar u[], void *ctx)
> >> >>     PetscObjectUseFortranCallback((DM)ctx, dmprojfunc,
> >> (PetscInt*,PetscReal*,PetscReal*,PetscInt*,PetscScalar*,void*,PetscErrorCode*),
> >> >>                                   (&dim,&time,x,&Nf,u,_ctx,&ierr))
> >> >> PETSC_EXTERN void dmprojectfunction_(DM *dm, PetscReal *time,
> >> >>                                      void
> >> (*func)(PetscInt*,PetscReal*,PetscReal*,PetscInt*,PetscScalar*,void*,PetscErrorCode*),
> >> >>                                      void *ctx, InsertMode *mode, Vec X,
> >> >> PetscErrorCode *ierr)
> >> >>     PetscErrorCode (*funcarr[1]) (PetscInt dim, PetscReal time,
> >> PetscReal
> >> >> x[], PetscInt Nf, PetscScalar *u, void *ctx);
> >> >>     *ierr = PetscObjectSetFortranCallback((PetscObject)*dm,
> >> >> PETSC_FORTRAN_CALLBACK_CLASS, &dmprojfunc, (PetscVoidFunction)func,
> >> ctx);
> >> >>     funcarr[0] = ourdmprojfunc;
> >> >>     *ierr = DMProjectFunction(*dm, *time, funcarr, &ctx, *mode, X);
> >> >> This time there is no error because I cannot reach this point in the
> >> >> program, but I am not sure anyways how to write this wrapper, especially
> >> >> because of the double pointers that DMProjectFunction takes as
> >> arguments.
> >> >> Does anyone have any idea what could be going wrong with those two
> >> >> wrappers ?
> >> >> Thank you very much in advance !!
> >> >> Thibault
> >> >> Le ven. 18 déc. 2020 à 11:02, Thibault Bridel-Bertomeu <
> >> >> thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>> a écrit :
> >> >>> Aah that is a nice trick, I was getting ready to fork, clone the fork
> >> and
> >> >>> redo the work, but that worked fine ! Thank you Barry !
> >> >>> The MR will appear in a little while !
> >> >>> Thibault
> >> >>> Le ven. 18 déc. 2020 à 10:16, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a écrit :
> >> >>>>   Good question.  There is a trick to limit the amount of work you
> >> need
> >> >>>> to do with a  new fork after you have already made changes with a
> >> PETSc
> >> >>>> clone, but it looks like we do not document this clearly in the
> >> webpages.
> >> >>>> (I couldn't find it).
> >> >>>>   Yes, you do need to make a fork, but after you have made the fork on
> >> >>>> the GitLab website (and have done nothing on your machine) edit the
> >> file
> >> >>>> $PETSC_DIR/.git/config  for your clone on your machine
> >> >>>>   Locate the line that has url = git at gitlab.com:petsc/petsc.git
> >> (this
> >> >>>> may have an https at the beginning of the line)
> >> >>>>   Change this line to point to the fork url instead with git@ not
> >> >>>> https, which will be pretty much the same URL but with your user id
> >> instead
> >> >>>> of petsc in the address.  Then git push and it will push to your fork.
> >> >>>>   Now you changes will be in your fork and you can make the MR from
> >> your
> >> >>>> fork URL on Gitlab. (In other words this editing trick converts your
> >> PETSc
> >> >>>> clone on your machine to a PETSc fork).
> >> >>>>   I hope I have explained this clearly enough it goes smoothly.
> >> >>>>   Barry
> >> >>>> On Dec 18, 2020, at 3:00 AM, Thibault Bridel-Bertomeu <
> >> >>>> Hello Barry,
> >> >>>> I'll start the MR as soon as possible then so that specialists can
> >> >>>> indeed have a look. Do I have to fork PETSc to start a MR or are
> >> PETSc repo
> >> >>>> settings such that can I push a branch from the PETSc clone I got ?
> >> >>>> Thibault
> >> >>>> Le mer. 16 déc. 2020 à 07:47, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a écrit
> >> >>>>>   Thibault,
> >> >>>>>   A subdirectory for the example is fine; we have other examples that
> >> >>>>> use subdirectories and multiple files.
> >> >>>>>   Note: even if you don't have something completely working you can
> >> >>>>> still make MR and list it as DRAFT request for comments, some other
> >> PETSc
> >> >>>>> members who understand the packages you are using and Fortran better
> >> than I
> >> >>>>> may be able to help as you develop the code.
> >> >>>>>   Barry
> >> >>>>> On Dec 16, 2020, at 12:35 AM, Thibault Bridel-Bertomeu <
> >> >>>>> Hello everyone,
> >> >>>>> Thank you Barry for the feedback.
> >> >>>>> OK, yes I'll work up an MR as soon as I have got something working.
> >> By
> >> >>>>> the way, does the fortran-version of the example have to be a single
> >> file ?
> >> >>>>> If my push contains a directory with several files (different
> >> modules and
> >> >>>>> the main), and the Makefile that goes with it, is that ok ?
> >> >>>>> Le mer. 16 déc. 2020 à 04:46, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a
> >> écrit :
> >> >>>>>>   This is great. If you make a branch off of the PETSc  git
> >> repository
> >> >>>>>> with these additions and work on ex11 you can make a merge request
> >> and we
> >> >>>>>> can run the code easily on all our test systems (for security
> >> reasons one
> >> >>>>>> of use needs to launch the tests from your MR).
> >> >>>>>> https://docs.petsc.org/en/latest/developers/integration/ <https://docs.petsc.org/en/latest/developers/integration/>
> >> >>>>>>    Barry
> >> >>>>>> On Dec 15, 2020, at 5:35 AM, Thibault Bridel-Bertomeu <
> >> >>>>>> Hello everyone,
> >> >>>>>> So far, I have the wrappers in the files attached to this e-mail. I
> >> >>>>>> still do not know if they work properly - at least the code
> >> compiles and
> >> >>>>>> the calls to the wrapped-subroutine do not fail - but I wanted to
> >> put this
> >> >>>>>> here in case someone sees something really wrong with it already.
> >> >>>>>> Thank you again for your help, I'll try to post updates of the F90
> >> >>>>>> version of ex11 regularly in this thread.
> >> >>>>>> Stay safe,
> >> >>>>>> Le dim. 13 déc. 2020 à 16:39, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> a écrit
> >> writes:
> >> >>>>>>> > Thank you Mark for your answer.
> >> >>>>>>> > I am not sure what you think could be in the setBC1 routine ? How
> >> >>>>>>> to make
> >> >>>>>>> > the connection with the PetscDS ?
> >> >>>>>>> > On the other hand, I actually found after a while TSMonitorSet
> >> has a
> >> >>>>>>> > fortran wrapper, and it does take as arguments two function
> >> >>>>>>> pointers, so I
> >> >>>>>>> > guess it is possible ? Although I am not sure exactly how to play
> >> >>>>>>> with the
> >> >>>>>>> > PetscObjectSetFortranCallback & PetscObjectUseFortranCallback
> >> >>>>>>> macros -
> >> >>>>>>> > could anybody advise please ?
> >> >>>>>>> tsmonitorset_ is a good example to follow. In your file, create one
> >> >>>>>>> of these static structs with a member for each callback. These are
> >> IDs that
> >> >>>>>>> will be used as keys for Fortran callbacks and their contexts. The
> >> salient
> >> >>>>>>> parts of the file are below.
> >> >>>>>>> static struct {
> >> >>>>>>>   PetscFortranCallbackId prestep;
> >> >>>>>>>   PetscFortranCallbackId poststep;
> >> >>>>>>>   PetscFortranCallbackId rhsfunction;
> >> >>>>>>>   PetscFortranCallbackId rhsjacobian;
> >> >>>>>>>   PetscFortranCallbackId ifunction;
> >> >>>>>>>   PetscFortranCallbackId ijacobian;
> >> >>>>>>>   PetscFortranCallbackId monitor;
> >> >>>>>>>   PetscFortranCallbackId mondestroy;
> >> >>>>>>>   PetscFortranCallbackId transform;
> >> >>>>>>> #if defined(PETSC_HAVE_F90_2PTR_ARG)
> >> >>>>>>>   PetscFortranCallbackId function_pgiptr;
> >> >>>>>>> #endif
> >> >>>>>>> } _cb;
> >> >>>>>>>    Note ctx is the same as ts so we need to get the Fortran context
> >> >>>>>>> out of the TS; this gets put in _ctx using the callback ID
> >> >>>>>>> static PetscErrorCode ourmonitor(TS ts,PetscInt i,PetscReal d,Vec
> >> >>>>>>> v,void *ctx)
> >> PetscObjectUseFortranCallback(ts,_cb.monitor,(TS*,PetscInt*,PetscReal*,Vec
> >> >>>>>>> *,void*,PetscErrorCode*),(&ts,&i,&d,&v,_ctx,&ierr));
> >> >>>>>>> Then follow as in tsmonitorset_, which sets two callbacks.
> >> >>>>>>> PETSC_EXTERN void tsmonitorset_(TS *ts,void
> >> >>>>>>> (*func)(TS*,PetscInt*,PetscReal*,Vec*,void*,PetscErrorCode*),void
> >> >>>>>>> *mctx,void (*d)(void*,PetscErrorCode*),PetscErrorCode *ierr)
> >> >>>>>>>   CHKFORTRANNULLFUNCTION(d);
> >> >>>>>>>   if ((PetscVoidFunction)func == (PetscVoidFunction)
> >> >>>>>>> tsmonitordefault_) {
> >> >>>>>>>     *ierr = TSMonitorSet(*ts,(PetscErrorCode
> >> (*)(TS,PetscInt,PetscReal,Vec,void*))TSMonitorDefault,*(PetscViewerAndFormat**)mctx,(PetscErrorCode
> >> >>>>>>> (*)(void **))PetscViewerAndFormatDestroy);
> >> >>>>>>>   } else {
> >> >>>>>>>     *ierr =
> >> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.monitor,(PetscVoidFunction)func,mctx);
> >> >>>>>>>     *ierr =
> >> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.mondestroy,(PetscVoidFunction)d,mctx);
> >> >>>>>>>     *ierr = TSMonitorSet(*ts,ourmonitor,*ts,ourmonitordestroy);
> >> >>>>>> <wrapper_petsc.h90><wrapper_petsc.c>
> > Eng, MSc, PhD
> > Research Engineer
> > CEA/CESTA
> > 33114 LE BARP
> > Tel.: (+33)557046924
> > Mob.: (+33)611025322
> > Mail: thibault.bridelbertomeu at gmail.com <mailto:thibault.bridelbertomeu at gmail.com>
>> Eng, MSc, PhD
> Research Engineer
> CEA/CESTA
> 33114 LE BARP
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201228/d4be5e33/attachment-0001.html>
