[petsc-users] TS tutorial ex11 in Fortran
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Fri Dec 18 04:02:29 CST 2020
Aah that is a nice trick, I was getting ready to fork, clone the fork and
redo the work, but that worked fine ! Thank you Barry !
The MR will appear in a little while !
Thibault
Le ven. 18 déc. 2020 à 10:16, Barry Smith <bsmith at petsc.dev> a écrit :
> Good question. There is a trick to limit the amount of work you need to
> do with a new fork after you have already made changes with a PETSc clone,
> but it looks like we do not document this clearly in the webpages. (I
> couldn't find it).
> Yes, you do need to make a fork, but after you have made the fork on the
> GitLab website (and have done nothing on your machine) edit the file
> $PETSC_DIR/.git/config for your clone on your machine
> Locate the line that has url = git at gitlab.com:petsc/petsc.git (this
> may have an https at the beginning of the line)
> Change this line to point to the fork url instead with git@ not https,
> which will be pretty much the same URL but with your user id instead of
> petsc in the address. Then git push and it will push to your fork.
> Now you changes will be in your fork and you can make the MR from your
> fork URL on Gitlab. (In other words this editing trick converts your PETSc
> clone on your machine to a PETSc fork).
> I hope I have explained this clearly enough it goes smoothly.
> Barry
> On Dec 18, 2020, at 3:00 AM, Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
> Hello Barry,
> I'll start the MR as soon as possible then so that specialists can indeed
> have a look. Do I have to fork PETSc to start a MR or are PETSc repo
> settings such that can I push a branch from the PETSc clone I got ?
> Thibault
> Le mer. 16 déc. 2020 à 07:47, Barry Smith <bsmith at petsc.dev> a écrit :
>> Thibault,
>> A subdirectory for the example is fine; we have other examples that use
>> subdirectories and multiple files.
>> Note: even if you don't have something completely working you can still
>> make MR and list it as DRAFT request for comments, some other PETSc members
>> who understand the packages you are using and Fortran better than I may be
>> able to help as you develop the code.
>> Barry
>> On Dec 16, 2020, at 12:35 AM, Thibault Bridel-Bertomeu <
>> Hello everyone,
>> Thank you Barry for the feedback.
>> OK, yes I'll work up an MR as soon as I have got something working. By
>> the way, does the fortran-version of the example have to be a single file ?
>> If my push contains a directory with several files (different modules and
>> the main), and the Makefile that goes with it, is that ok ?
>> Le mer. 16 déc. 2020 à 04:46, Barry Smith <bsmith at petsc.dev> a écrit :
>>> This is great. If you make a branch off of the PETSc git repository
>>> with these additions and work on ex11 you can make a merge request and we
>>> can run the code easily on all our test systems (for security reasons one
>>> of use needs to launch the tests from your MR).
>>> https://docs.petsc.org/en/latest/developers/integration/
>>> Barry
>>> On Dec 15, 2020, at 5:35 AM, Thibault Bridel-Bertomeu <
>>> Hello everyone,
>>> So far, I have the wrappers in the files attached to this e-mail. I
>>> still do not know if they work properly - at least the code compiles and
>>> the calls to the wrapped-subroutine do not fail - but I wanted to put this
>>> here in case someone sees something really wrong with it already.
>>> Thank you again for your help, I'll try to post updates of the F90
>>> version of ex11 regularly in this thread.
>>> Stay safe,
>>> Le dim. 13 déc. 2020 à 16:39, Jed Brown <jed at jedbrown.org> a écrit :
>>>> Thibault Bridel-Bertomeu <thibault.bridelbertomeu at gmail.com> writes:
>>>> > Thank you Mark for your answer.
>>>> > I am not sure what you think could be in the setBC1 routine ? How to
>>>> make
>>>> > the connection with the PetscDS ?
>>>> > On the other hand, I actually found after a while TSMonitorSet has a
>>>> > fortran wrapper, and it does take as arguments two function pointers,
>>>> so I
>>>> > guess it is possible ? Although I am not sure exactly how to play
>>>> with the
>>>> > PetscObjectSetFortranCallback & PetscObjectUseFortranCallback macros -
>>>> > could anybody advise please ?
>>>> tsmonitorset_ is a good example to follow. In your file, create one of
>>>> these static structs with a member for each callback. These are IDs that
>>>> will be used as keys for Fortran callbacks and their contexts. The salient
>>>> parts of the file are below.
>>>> static struct {
>>>> PetscFortranCallbackId prestep;
>>>> PetscFortranCallbackId poststep;
>>>> PetscFortranCallbackId rhsfunction;
>>>> PetscFortranCallbackId rhsjacobian;
>>>> PetscFortranCallbackId ifunction;
>>>> PetscFortranCallbackId ijacobian;
>>>> PetscFortranCallbackId monitor;
>>>> PetscFortranCallbackId mondestroy;
>>>> PetscFortranCallbackId transform;
>>>> #if defined(PETSC_HAVE_F90_2PTR_ARG)
>>>> PetscFortranCallbackId function_pgiptr;
>>>> #endif
>>>> } _cb;
>>>> Note ctx is the same as ts so we need to get the Fortran context out
>>>> of the TS; this gets put in _ctx using the callback ID
>>>> static PetscErrorCode ourmonitor(TS ts,PetscInt i,PetscReal d,Vec
>>>> v,void *ctx)
>>>> PetscObjectUseFortranCallback(ts,_cb.monitor,(TS*,PetscInt*,PetscReal*,Vec
>>>> *,void*,PetscErrorCode*),(&ts,&i,&d,&v,_ctx,&ierr));
>>>> Then follow as in tsmonitorset_, which sets two callbacks.
>>>> PETSC_EXTERN void tsmonitorset_(TS *ts,void
>>>> (*func)(TS*,PetscInt*,PetscReal*,Vec*,void*,PetscErrorCode*),void
>>>> *mctx,void (*d)(void*,PetscErrorCode*),PetscErrorCode *ierr)
>>>> CHKFORTRANNULLFUNCTION(d);
>>>> if ((PetscVoidFunction)func == (PetscVoidFunction) tsmonitordefault_)
>>>> *ierr = TSMonitorSet(*ts,(PetscErrorCode
>>>> (*)(TS,PetscInt,PetscReal,Vec,void*))TSMonitorDefault,*(PetscViewerAndFormat**)mctx,(PetscErrorCode
>>>> (*)(void **))PetscViewerAndFormatDestroy);
>>>> } else {
>>>> *ierr =
>>>> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.monitor,(PetscVoidFunction)func,mctx);
>>>> *ierr =
>>>> PetscObjectSetFortranCallback((PetscObject)*ts,PETSC_FORTRAN_CALLBACK_CLASS,&_cb.mondestroy,(PetscVoidFunction)d,mctx);
>>>> *ierr = TSMonitorSet(*ts,ourmonitor,*ts,ourmonitordestroy);
>>> <wrapper_petsc.h90><wrapper_petsc.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201218/0a56c01f/attachment.html>
