[petsc-users] Petsc makefile and PETSC_COMPILE variable
Jed Brown
jed at jedbrown.org
Wed Dec 16 16:57:38 CST 2020
Alex Koshkarov <okoshkarov at tae.com> writes:
> Thanks for this.
> I now use modified version of `share/petsc/Makefile.user`. However, now I am not sure if I do linking correctly. All my code is pure C, so I use
> $(OBJ) - variable with all object files
> driver: $(OBJ)
> $(LINK.c) $^ $(LDFLAGS) $(LDLIBS) -o $@
> I am not sure if I need to pass variable $(LDFLAGS) or not, since in Makefile.user examples does not, it uses only $(LDLIBS).
It's part of LINK.c:
$ make -p -f /dev/null | fgrep 'LINK.c ='
make: *** No targets. Stop.
LINK.c = $(CC) $(CFLAGS) $(CPPFLAGS) $(LDFLAGS) $(TARGET_ARCH)
The variables are being extracted according to conventions.
$ make -f share/petsc/Makefile.user print
CC=mpicc
CXX=mpicxx
FC=mpif90
CFLAGS=-fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O2 -march=native -ffp-contract=fast -g
CXXFLAGS=-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC
FFLAGS=-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O
CPPFLAGS=-I/home/jed/petsc/ompi-optg/include -I/home/jed/petsc/include
LDFLAGS=-L/home/jed/petsc/ompi-optg/lib -Wl,-rpath,/home/jed/petsc/ompi-optg/lib
LDLIBS=-lpetsc -lm
CUDAC=
CUDAC_FLAGS=
CUDA_LIB=
CUDA_INCLUDE=
> Also, after reading Jed's and mine petsc.pc, I noticed that I do not have optimization flags, however I compile petsc with optimization flags. (I also add additional -O3 into compilation rule when compile my code)
> Namely, I add during petsc configuration/compilation (I use gcc and openmpi):
> --with-debugging=0 COPTFLAGS='-O3 -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3 -march=native -mtune=native'
> So how do I check if my petsc is compiled with optimizations?
petsc.pc only provides what is necessary to compile your code with PETSc. There are lots of circumstances in which you might want a debugging build of your application linked with release PETSc (suppose all your development is unrelated from PETSc).
> And my petsc.pc is:
> prefix=/home/kosh/Documents/NEPIC/libs/petsc-3.14.2/optim
> exec_prefix=${prefix}
> includedir=${prefix}/include
> libdir=${prefix}/lib
> ccompiler=mpicc
> cflags_extra=-fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden
> cflags_dep=-MMD -MP
> ldflag_rpath=-Wl,-rpath,
> cxxcompiler=mpicxx
> cxxflags_extra=-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -fPIC
> fcompiler=mpif90
> fflags_extra=-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument
> Description: Library to solve ODEs and algebraic equations
> Version: 3.14.2
> Cflags: -I${includedir} -I/home/kosh/Documents/NEPIC/libs/petsc-3.14.2/include
> Libs: -L${libdir} -lpetsc
> Libs.private: -L/home/kosh/Documents/NEPIC/libs/petsc-3.14.2/optim/lib -L/usr/lib/openmpi -L/usr/lib/gcc/x86_64-pc-linux-gnu/10.2.0 -lHYPRE -lscalapack -llapack -lblas -lX11 -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lm -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath -lstdc++ -ldl
> Thank you and best regards,
> Alex.
> > Thanks Barry,
> > It makes much more sense! And thanks for clarifying what “P” indicates. I like this explicit approach over implicit because I am bad with makefile syntax. However, share/petsc/Makefile.user looks much cleaner, but I need to learn how pkg-config works to understand it.
> Open a petsc.pc to see what is specified there. We define a number of extra variables that can help with checking for common compilers/wrappers and how to use RPATH if needed.
> prefix=/home/jed/petsc/ompi-optg
> ccompiler=mpicc
> cflags_extra=-fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O2 -march=native -ffp-contract=fast -g
> cflags_dep=-MMD -MP
> cxxcompiler=mpicxx
> cxxflags_extra=-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O -fPIC
> fcompiler=mpif90
> fflags_extra=-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O
> Version: 3.13.99
> Cflags: -I${includedir} -I/home/jed/petsc/include
> Libs.private: -L/home/jed/petsc/ompi-optg/lib -L/usr/lib/openmpi -L/usr/lib/gcc/x86_64-pc-linux-gnu/10.1.0 -lHYPRE -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lsuperlu -lsuperlu_dist -lml -llapack -lblis -ltriangle -lX11 -lexodus -lnetcdf -lpnetcdf -lcgns -lmedC -lmed -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lparmetis -lmetis -lm -lz -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath -lstdc++ -ldl
