[petsc-users] Petsc makefile and PETSC_COMPILE variable
    Alex Koshkarov
    okoshkarov at tae.com
    Wed Dec 16 11:09:22 CST 2020
Thanks Barry,
It makes much more sense! And thanks for clarifying what “P” indicates. I like this explicit approach over implicit because I am bad with makefile syntax. However, share/petsc/Makefile.user looks much cleaner, but I need to learn how pkg-config works to understand it.
Thank you,
Alex.
Date: Tuesday, December 15, 2020 at 7:41 PM
To: Alex Koshkarov <okoshkarov at tae.com>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Petsc makefile and PETSC_COMPILE variable
  Alex,
   Since you are explicitly defining your rules you might as well just do it completely, so use something like
objects/%.o: src/%.c $(DEP)
               ${PCC} -c $< -o $@ ${PCC_FLAGS} ${PFLAGS} ${CCPPFLAGS}
The P indicates either C and C flags or C++ compiler and its  flags if configure was run with --with-clanguage=c++ (not recommended).
So if your code is C you can use
${CC} -c $< -o $@ ${CC_FLAGS} ${CPP_FLAGS}
if C++ use
${CXX} -c $< -o $@ ${CXXPP_FLAGS} ${CXX_FLAGS}
With this you don't need the COMPILE macros that are really internal for PETSc's use.
  Barry
  We have not been completely successful at getting share/petsc/Makefile.user to be bullet proof yet, but if you can get it to work in your case great.
On Dec 15, 2020, at 11:46 AM, Alex Koshkarov <okoshkarov at tae.com<mailto:okoshkarov at tae.com>> wrote:
Thank you!
It makes sense to use share/petsc/Makefile.user - I will try to understand it. However, can you please tell me what is the meaning of "_SINGLE" in "PETSC_COMPILE_SINGLE"? Does it mean compile only one source file?
Best regards,
Alex Koshkarov.
On 12/15/20, 9:25 AM, "Satish Balay" <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
   On Tue, 15 Dec 2020, Alex Koshkarov wrote:
Hi All,
I have been using trivial makefile (see below) for the code which uses petsc. The makefile relies on variable PETSC_COMPILE which disappeared in new petsc version (absent in 3.14.2, but present in 3.13.4). What would be the right way to fix the makefile? (should I use something like PETSC_COMPILE_SINGLE ?).
   Yes - this change was a bugfix.
Is it a very bad practice to use such makefile?
   For most use cases the default targets work. However this usage [where sources and obj files are in different dirs] is not covered by them.
   So - I think using such targets is appropriate.
   There is also share/petsc/Makefile.user - which attempts to provide a portable way to create user makefiles [that don't rely on internals like PETSC_COMPILE_SINGLE] - but requires gnumake and pkgconfig
   Satish
p.s. sorry if this is a duplicate message, I believe I sent the first one to the wrong address.
Thank you very much,
Alex Koshkarov.
Example of makefile, it assumes sources in “src” and creats objects in “objects”:
CPP := $(wildcard src/*.c)
DEP := $(wildcard src/*.h)
OBJ := $(addprefix objects/,$(notdir $(CPP:.c=.o)))
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
driver: $(OBJ)
               -${CLINKER} -o $@ $^ ${PETSC_LIB} ${EXTRALIBS} ${CFLAGS}
               ${PETSC_COMPILE} -c $< -o $@
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201216/1f468fe8/attachment-0001.html>
