[petsc-users] Petsc makefile and PETSC_COMPILE variable
Satish Balay
balay at mcs.anl.gov
Tue Dec 15 11:55:46 CST 2020
Its internal organization of some old code.
Previously we had 2 things:
- PETSC_COMPILE (perhaps PETSC_COMPILE_MULTIPLE is a more appropriate name) did something equivalent to 'gcc -c a.c b.c c.c' - i.e compile multiple files at the same time.
- PETSC_COMPILE_SINGLE used was to compile one file at a time. [gcc -c a.c]
Some of the old build infrastructure that uses PETSC_COMPILE is no longer used and removed [ i.e make target 'libfast']
And somehow the remaining *_SINGLE targets had this error [i.e PETSC_COMPILE was used incorrectly instead of PETSC_COMPILE_SINGLE] which got fixed.
Satish
On Tue, 15 Dec 2020, Alex Koshkarov wrote:
> Thank you!
> It makes sense to use share/petsc/Makefile.user - I will try to understand it. However, can you please tell me what is the meaning of "_SINGLE" in "PETSC_COMPILE_SINGLE"? Does it mean compile only one source file?
> Best regards,
> Alex Koshkarov.
> > Hi All,
> > I have been using trivial makefile (see below) for the code which uses petsc. The makefile relies on variable PETSC_COMPILE which disappeared in new petsc version (absent in 3.14.2, but present in 3.13.4). What would be the right way to fix the makefile? (should I use something like PETSC_COMPILE_SINGLE ?).
> Yes - this change was a bugfix.
> > Is it a very bad practice to use such makefile?
> For most use cases the default targets work. However this usage [where sources and obj files are in different dirs] is not covered by them.
> So - I think using such targets is appropriate.
> There is also share/petsc/Makefile.user - which attempts to provide a portable way to create user makefiles [that don't rely on internals like PETSC_COMPILE_SINGLE] - but requires gnumake and pkgconfig
> Satish
> > p.s. sorry if this is a duplicate message, I believe I sent the first one to the wrong address.
> > Thank you very much,
> > Alex Koshkarov.
> > Example of makefile, it assumes sources in “src” and creats objects in “objects”:
> > CPP := $(wildcard src/*.c)
> > DEP := $(wildcard src/*.h)
> > OBJ := $(addprefix objects/,$(notdir $(CPP:.c=.o)))
> > include ${PETSC_DIR}/lib/petsc/conf/variables
> > include ${PETSC_DIR}/lib/petsc/conf/rules
> > driver: $(OBJ)
> > -${CLINKER} -o $@ $^ ${PETSC_LIB} ${EXTRALIBS} ${CFLAGS}
> > objects/%.o: src/%.c $(DEP)
> > ${PETSC_COMPILE} -c $< -o $@
