[petsc-users] valgrind with petscmpiexec
Fande Kong
fdkong.jd at gmail.com
Mon Dec 14 23:59:52 CST 2020
Hi All,
I tried to use valgrind to check if the simulation is valgrind clean
because I saw some random communication fails during the simulation.
I tried this command-line
petscmpiexec -valgrind -n 576 ../../../moose-app-oprof -i input.i
-log_view -snes_view
But I got the following error messages:
valgrind: Unable to start up properly. Giving up.
==75586== VG_(mkstemp): failed to create temp file:
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_8c3fabf2
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_8cac2243
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_da8d30c0
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_877871f9
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_c098953e
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_aa649f9f
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_097498ec
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_bfc534b5
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_7604c74a
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_a1fd96bb
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75586_cmdline_4c8857d8
valgrind: Startup or configuration error:
valgrind: Can't create client cmdline file in
==75596== VG_(mkstemp): failed to create temp file:
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75596_cmdline_bc5492bb
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75596_cmdline_ec59a3d8
==75597== VG_(mkstemp): failed to create temp file:
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_b036bdf2
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_105acc43
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_9fb792c0
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_30602bf9
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_21eec73e
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_0b53e99f
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_73e31aec
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_486e8eb5
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_db8c194a
/var/tmp/pbs.3110013.sawtoothpbs/valgrind_proc_75597_cmdline_839780bb
I did a bit search online, and found something related
https://stackoverflow.com/questions/13707211/what-causes-mkstemp-to-fail-when-running-many-simultaneous-valgrind-processes
But do not know what is the right way to fix the issue.
Thanks so much,
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201214/935adf9b/attachment.html>
