[petsc-users] PETSc with MUMPS
Luo Chenyi
cheluo at ethz.ch
Wed Dec 9 15:59:24 CST 2020
Hi Satish,
many thanks for this detailed cooking recipe (very practical for a beginner)!
Now I receive the following message
“luochengyi at macbook-pro-2 petsc % make PETSC_DIR=/Users/luochengyi/Downloads/petsc PETSC_ARCH=arch-darwin-c-debug check
Running check examples to verify correct installation
Using PETSC_DIR=/Users/luochengyi/Downloads/petsc and PETSC_ARCH=arch-darwin-c-debug
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
C/C++ example src/snes/tutorials/ex19 run successfully with mumps
Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
So I think the installation is complete. However, when I run my dealii codes, I still received the same error message
Additional information:
Your PETSc installation does not include a copy of the MUMPS package necessary for this solver. You will need to configure PETSc so that it includes MUMPS, recompile it, and then re-configure and recompile deal.II as well.
I think I’ve already configure the PETSc including MUMPS and recompiled it.
I also use cmake to link the necessary libraries. Is there anything else I need to do?
Best,
Chenyi
On Dec 9, 2020, at 10:35 PM, Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>> wrote:
On Wed, 9 Dec 2020, Satish Balay via petsc-users wrote:
Its best to reinstall brew (packages) and retry.
And here is one way to do this:
1. Make list of pkgs to reinstall
brew leaves > reinstall.lst
2. delete all installed brew packages.
brew cleanup
brew list > delete.lst
brew remove `cat delete.lst`
3. Now reinstall all required packages
brew update
brew install `cat reinstall.lst`
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201209/546a439e/attachment.html>
