[petsc-users] incredibly good performance of scipy lgmres
Pierre Seize
pierre.seize at onera.fr
Wed Dec 9 10:34:15 CST 2020
I think that `callback` is called once for each outer cycle, and the
default inner number of iterations is 30, so 30 x 5 = 150 iterations, it
seems more realistic.
Pierre Seize
On 09/12/20 17:25, Stefano Zampini wrote:
> Could it be that scipy lgmres is reporting the wrong number of
> iterations?
> I would try to replicate the scipy code first
> https://github.com/scipy/scipy/blob/master/scipy/sparse/linalg/isolve/lgmres.py
> Il Mer 9 Dic 2020, 19:17 Florian Bruckner <e0425375 at gmail.com
> <mailto:e0425375 at gmail.com>> ha scritto:
> Dear PETSc developers,
> I am currently re-implementing our FEM-BEM code using Firedrake.
> The original code we were using is based on FEniCS and uses scipy
> sparse solvers for the solution of the coupled FEM / BEM system.
> For some reason the scipy lgmres method seems to outperform all
> other methods which we tried. E.g. for the strayfield-calculation
> of a 10x10x10 unit cube scipy-lgmres needs 5 iterations (without
> preconditioner), whereas scipy-gmres needs 167. The new
> implementation uses petsc-gmres and petsc-lgmres, but both need
> around 170 iterations.
> If I understand lgmres correctly it only improves convergence if
> gmres is restarted. Since it only needs 5 iterations i think this
> cannot be the reason. But nevertheless since the method seems to
> perform very good, it would be worth looking at the differences in
> detail. I provide the dense data of the system-matrix and
> right-hand-side vector that I used, as well as scripts for the
> different considered methods.
> Any ideas how scipy-lgmres could be that good? It would be nice if
> someone could validate my results (lgmres solves within 5
> iterations). For me the next step will be to wrap scipy-lgmres
> using petsc4py. I know how to do it with petsc4py directly, but I
> am not exactly sure how it works with the firedrake interface.
> best wishes
> Florian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201209/c41b8493/attachment.html>
