[petsc-users] Setting an unknown initial guess
David Schneider
dav.schneider at tum.de
Tue Dec 8 07:58:45 CST 2020
Dear all,
I'm using a KSPLSQR solver without preconditioning and configure the
solver once in the beginning. Afterwards, I solve my system multiple
times in a time-dependent system and I would like to use an initial
guess (from the previous solution). Currently, I use
`KSPSetInitialGuessNonzero` for this purpose, but it may happen that the
actual guess is zero. If the initial guess is zero, the solver fails to
converge, at least with the default configuration. Setting
`KSPSetInitialGuess` with `PETSC_FALSE` (which should also be the
default) zeros the guess out. Is there a (native) way to preserve the
initial guess, but still ensure convergence in the KSPsolver in case the
guess is zero?
Thanks in advance,
David
