[petsc-users] Usage of parallel FFT for doing batch 1d-FFTs over the columns of a dense 2d-matrix
Roland Richter
roland.richter at ntnu.no
Tue Dec 8 07:39:48 CST 2020
Dear all,
I tried the following code:
/int main(int argc, char **args) {//
// Mat C, F;//
// Vec x, y, z;//
// PetscViewer viewer;//
// PetscMPIInt rank, size;//
// PetscInitialize(&argc, &args, (char*) 0, help);//
// MPI_Comm_size(PETSC_COMM_WORLD, &size);//
// MPI_Comm_rank(PETSC_COMM_WORLD, &rank);//
// PetscPrintf(PETSC_COMM_WORLD,"Number of processors = %d, rank =
%d\n", size, rank);//
// // std::cout << "From rank " << rank << '\n';//
// //MatCreate(PETSC_COMM_WORLD, &C);//
// PetscViewerCreate(PETSC_COMM_WORLD, &viewer);//
// PetscViewerSetType(viewer, PETSCVIEWERASCII);//
// arma::cx_mat local_mat, local_zero_mat;//
// const size_t matrix_size = 5;//
// MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
matrix_size, matrix_size, NULL, &C);//
matrix_size, matrix_size, NULL, &F);//
// if(rank == 0) {//
// arma::Col<int> indices = arma::linspace<arma::Col<int>>(0,
matrix_size - 1, matrix_size);//
// //if(rank == 0) {//
// local_mat = arma::randu<arma::cx_mat>(matrix_size, matrix_size);//
// local_zero_mat = arma::zeros<arma::cx_mat>(matrix_size,
matrix_size);//
// arma::cx_mat tmp_mat = local_mat.st();//
// MatSetValues(C, matrix_size, indices.memptr(), matrix_size,
indices.memptr(), tmp_mat.memptr(), INSERT_VALUES);//
// MatSetValues(F, matrix_size, indices.memptr(), matrix_size,
indices.memptr(), local_zero_mat.memptr(), INSERT_VALUES);//
// MatAssemblyBegin(C, MAT_FINAL_ASSEMBLY);//
// MatAssemblyEnd(C, MAT_FINAL_ASSEMBLY);//
// MatAssemblyBegin(F, MAT_FINAL_ASSEMBLY);//
// MatAssemblyEnd(F, MAT_FINAL_ASSEMBLY);//
// //FFT test//
// Mat FFT_A;//
// Vec input, output;//
// int first_owned_row_index = 0, last_owned_row_index = 0;//
// const int FFT_length[] = {matrix_size};//
// MatCreateFFT(PETSC_COMM_WORLD, 1, FFT_length, MATFFTW, &FFT_A);//
// MatCreateVecsFFTW(FFT_A, &x, &y, &z);//
// VecCreate(PETSC_COMM_WORLD, &input);//
// VecSetFromOptions(input);//
// VecSetSizes(input, PETSC_DECIDE, matrix_size);//
// VecCreate(PETSC_COMM_WORLD, &output);//
// VecSetFromOptions(output);//
// VecSetSizes(output, PETSC_DECIDE, matrix_size);//
// MatGetOwnershipRange(C, &first_owned_row_index,
&last_owned_row_index);//
// std::cout << "Rank " << rank << " owns row " <<
first_owned_row_index << " to row " << last_owned_row_index << '\n';//
// //Testing FFT//
// fftw_plan fplan,bplan;//
// fftw_complex *data_in,*data_out,*data_out2;//
// ptrdiff_t alloc_local, local_ni, local_i_start,
local_n0,local_0_start;//
// PetscRandom rdm;//
// // if (!rank)//
// // printf("Use FFTW without PETSc-FFTW interface\n");//
// fftw_mpi_init();//
// int N = matrix_size * matrix_size;//
// int N0 = matrix_size;//
// int N1 = matrix_size;//
// const ptrdiff_t n_data[] = {N0, 1};//
// //alloc_local =
fftw_mpi_local_size_2d(N0,N1,PETSC_COMM_WORLD,&local_n0,&local_0_start);//
// alloc_local = fftw_mpi_local_size_many(1, n_data,//
// matrix_size,//
// FFTW_MPI_DEFAULT_BLOCK,//
// PETSC_COMM_WORLD,//
// &local_n0,//
// &local_0_start);//
// //data_in =
(fftw_complex*)fftw_malloc(sizeof(fftw_complex)*alloc_local);//
// PetscScalar *C_ptr, *F_ptr;//
// MatDenseGetArray(C, &C_ptr);//
// MatDenseGetArray(F, &F_ptr);//
// data_in = reinterpret_cast<fftw_complex*>(C_ptr);//
// data_out = reinterpret_cast<fftw_complex*>(F_ptr);//
// data_out2 =
// VecCreateMPIWithArray(PETSC_COMM_WORLD,1,(PetscInt)local_n0 *
N1,(PetscInt)N,(const PetscScalar*)data_in,&x);//
// PetscObjectSetName((PetscObject) x, "Real Space vector");//
N1,(PetscInt)N,(const PetscScalar*)data_out,&y);//
// PetscObjectSetName((PetscObject) y, "Frequency space vector");//
N1,(PetscInt)N,(const PetscScalar*)data_out2,&z);//
// PetscObjectSetName((PetscObject) z, "Reconstructed vector");//
// int FFT_rank = 1;//
// const ptrdiff_t FFTW_size[] = {matrix_size};//
// int howmany = last_owned_row_index - first_owned_row_index;//
// //std::cout << "Rank " << rank << " processes " << howmany << "
rows\n";//
// int idist = matrix_size;//1;//
// int odist = matrix_size;//1;//
// int istride = 1;//matrix_size;//
// int ostride = 1;//matrix_size;//
// const ptrdiff_t *inembed = FFTW_size, *onembed = FFTW_size;//
// fplan = fftw_mpi_plan_many_dft(FFT_rank, FFTW_size,//
// howmany,//
// data_in, data_out,//
// FFTW_FORWARD, FFTW_ESTIMATE);//
// bplan = fftw_mpi_plan_many_dft(FFT_rank, FFTW_size,//
// howmany,//
// data_out, data_out2,//
// FFTW_BACKWARD, FFTW_ESTIMATE);//
// if (false) {VecView(x,PETSC_VIEWER_STDOUT_WORLD);}//
// fftw_execute(fplan);//
// if (false) {VecView(y,PETSC_VIEWER_STDOUT_WORLD);}//
// fftw_execute(bplan);//
// double a = 1.0 / matrix_size;//
// double enorm = 0;//
// VecScale(z,a);//
// if (false) {VecView(z, PETSC_VIEWER_STDOUT_WORLD);}//
// VecAXPY(z,-1.0,x);//
// VecNorm(z,NORM_1,&enorm);//
// if (enorm > 1.e-11) {//
// PetscPrintf(PETSC_COMM_SELF," Error norm of |x - z|
%g\n",(double)enorm);//
// /* Free spaces *///
// fftw_destroy_plan(fplan);//
// fftw_destroy_plan(bplan);//
// fftw_free(data_out2);//
// //Generate test matrix for comparison//
// arma::cx_mat fft_test_mat = local_mat;//
// fft_test_mat.each_row([&](arma::cx_rowvec &a){//
// a = arma::fft(a);//
// std::cout <<
"-----------------------------------------------------\n";//
// std::cout << "Input matrix:\n" << local_mat << '\n';//
// MatView(C, viewer);//
// std::cout <<
// std::cout << "Expected output matrix:\n" << fft_test_mat << '\n';//
// MatView(F, viewer);//
// std::cout <<
// MatDestroy(&FFT_A);//
// VecDestroy(&input);//
// VecDestroy(&output);//
// VecDestroy(&x);//
// VecDestroy(&y);//
// VecDestroy(&z);//
// MatDestroy(&C);//
// MatDestroy(&F);//
// PetscViewerDestroy(&viewer);//
// PetscFinalize();//
// return 0;//
For *mpirun -n 1* I get the expected output (i.e. armadillo and
PETSc/FFTW return the same result), but for *mpirun -n x* with x > 1
every value which is not assigned to rank 0 is lost and set to zero
instead. Every value assigned to rank 0 is calculated correctly, as far
as I can see. Did I forget something here?
Roland
Am 05.12.20 um 01:59 schrieb Barry Smith:
> Roland,
> If you store your matrix as described in a parallel PETSc dense
> matrix then you should be able to call
> fftw_plan_many_dft() directly on the value obtained with
> MatDenseGetArray(). You just need to pass the arguments regarding
> column major ordering appropriately. Probably identically to what you
> do with your previous code.
> Barry
>> On Dec 4, 2020, at 6:47 AM, Roland Richter <roland.richter at ntnu.no
>> <mailto:roland.richter at ntnu.no>> wrote:
>> Ideally those FFTs could be handled in parallel, after they are not
>> depending on each other. Is that possible with MatFFT, or should I
>> rather use FFTW for that?
>> Thanks,
>> Roland
>> Am 04.12.20 um 13:19 schrieb Matthew Knepley:
>>> On Fri, Dec 4, 2020 at 5:32 AM Roland Richter
>>> <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>>> Hei,
>>> I am currently working on a problem which requires a large amount of
>>> transformations of a field E(r, t) from time space to Fourier
>>> space E(r,
>>> w) and back. The field is described in a 2d-matrix, with the
>>> r-dimension
>>> along the columns and the t-dimension along the rows.
>>> For the transformation from time to frequency space and back I
>>> therefore
>>> have to apply a 1d-FFT operation over each row of my matrix. For my
>>> earlier attempts I used armadillo as matrix library and FFTW for
>>> doing
>>> the transformations. Here I could use fftw_plan_many_dft to do
>>> all FFTs
>>> at the same time. Unfortunately, armadillo does not support MPI, and
>>> therefore I had to switch to PETSc for larger matrices.
>>> Based on the examples (such as example 143) PETSc has a way of doing
>>> FFTs internally by creating an FFT object (using MatCreateFFT).
>>> Unfortunately, I can not see how I could use that object to
>>> conduct the
>>> operation described above without having to iterate over each
>>> row in my
>>> original matrix (i.e. doing it sequential, not in parallel).
>>> Ideally I could distribute the FFTs such over my nodes that each
>>> node
>>> takes several rows of the original matrix and applies the FFT to
>>> each of
>>> them. As example, for a matrix with a size of 4x4 and two nodes
>>> node 0
>>> would take row 0 and 1, while node 1 takes row 2 and 3, to avoid
>>> unnecessary memory transfer between the nodes while conducting
>>> the FFTs.
>>> Is that something PETSc can do, too?
>>> The way I understand our setup (I did not write it), we use
>>> plan_many_dft to handle
>>> multiple dof FFTs, but these would be interlaced. You want many FFTs
>>> for non-interlaced
>>> storage, which is not something we do right now. You could
>>> definitely call FFTW directly
>>> if you want.
>>> Second, above it seems like you just want serial FFTs. You can
>>> definitely create a MatFFT
>>> with PETSC_COMM_SELF, and apply it to each row in the local rows, or
>>> create the plan
>>> yourself for the stack of rows.
>>> Thanks,
>>> Matt
>>> Thanks!
>>> Regards,
>>> Roland
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201208/7728c6b1/attachment.html>
