[petsc-users] How do constraint dofs work?
    Alexis Marboeuf
    alexis.marboeuf at hotmail.fr
    Sun Dec  6 12:46:34 CST 2020
Hello,
I intend to contribute to the Petsc documentation, especially on PetscSF and PetscSection objects. I'm writing an example where I solve a linear elasticity problem in parallel on unstructured meshes. I discretize the system with a finite element method and P1 Lagrange base functions. I only use Petsc basics such as PetscSF, PetscSection, Mat, Vec and SNES objects and I need to implement Dirichlet and/or Neuman boundary conditions. PetscSectionSetConstraintDof and related routines allow to define which dofs are removed from the global system but are kept in local Vec. I don't find much more information about constraint dofs. Can someone explain me how it works? In particular, do I have to manually add terms related to inhomogeneous Dirichlet boundary condition in the RHS? Am I missing something?
Alexis Marboeuf
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20201206/7f118edd/attachment.html>
